Quote: Originally Posted by
Nola111
... or, even easier, use Microsoft Virtual PC, and use XP as the OS on your Virtual PC.
I actually tried that, but no go. SD require direct3d.MS Virtual PC uses a software virtual video card, which obviously has no hardware 3d rendering capabilities. Now you can use the -gdi command line switch to force SD to open without it, but not in the development environment.
god_of_cpu
The development enviornment does not support vista yet. It will startup and you can do somethings, but the menus are non-functional.
I've been using SD on my Vista laptop the past few days fine (finally!) Try switching of UAC from the control panel if you are having problems, if you can't get SD to even open in Vista
this thread discusses what may need to be done.
