Here is the last log file from the TPMS....I see errors, but that's all I know. Anyone care to have a look?
Thanks...
40:59:30> Click_Action(): CurrValue=2
41:04:70> Click_Action(): CurrValue=1
41:04:90> Click_Action(): CurrValue=2
41:05:10> Click_Action(): CurrValue=3
41:05:43> Click_Action(): CurrValue=4
12:56:06> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.EndWrite(IAsyncResult asyncResult)
at System.IO.FileStream.FlushWrite(Boolean calledFromFinalizer)
at System.IO.FileStream.Dispose(Boolean disposing)
at System.IO.Stream.Close()
at tpms.HIDDevice.Dispose(Boolean bDisposing)
at tpms.HIDDevice.Dispose()
at tpms.HIDDevice.Write(OutputReport oOutRep)
at tpms.TpmsDevice.WriteReport(TpmsOutputReport outputReport)
at tpms.tpms.GetDataFromDevice()(): A device attached to the system is not functioning.<CR><LF>
54:33:78> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
54:34:78> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
54:56:33> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.BeginWriteCore(Byte[] bytes, Int32 offset, Int32 numBytes, AsyncCallback userCallback, Object stateObject)
at tpms.tpms.GetDataFromDevice()(): Unable to find the specified file.
56:03:94> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
19:14:80> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
19:17:57> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
19:25:63> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
19:31:52> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
19:39:30> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
19:55:39> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
20:02:64> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
20:10:06> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
22:55:40> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
23:17:72> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
23:55:61> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
04:50:83> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
04:51:88> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
05:17:66> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
05:44:16> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
06:44:96> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
08:28:66> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
09:28:82> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
14:30:37> Click_Action(): CurrValue=2
14:33:46> Click_Action(): CurrValue=1
14:33:65> Click_Action(): CurrValue=2
14:33:84> Click_Action(): CurrValue=3
14:34:04> Click_Action(): CurrValue=4
24:19:08> Click_Action(): CurrValue=2
24:20:40> Click_Action(): CurrValue=1
24:20:58> Click_Action(): CurrValue=2
24:20:75> Click_Action(): CurrValue=3
24:20:93> Click_Action(): CurrValue=4
17:25:23> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
18:24:93> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
19:32:73> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
19:52:79> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
56:26:95> loadSettings(): START
56:26:96> loadSettings(): END
56:26:97> LoadValues(): START
56:26:97> CF_localskinsetup(): START
56:27:07> CF_localskinsetup(): END
56:27:07> CF_pluginInit(): END
56:32:67> TPMS_Loaded(): START
56:32:68> TPMS_Loaded(): END
56:33:72> GetDataFromDevice(): START
56:34:60> GetDataFromDevice(): END
56:35:64> GetDataFromDevice(): START
56:36:17> GetDataFromDevice(): END
56:37:19> GetDataFromDevice(): START
56:37:74> GetDataFromDevice(): END
56:38:73> GetDataFromDevice(): START
56:39:27> GetDataFromDevice(): END
56:40:27> GetDataFromDevice(): START
56:40:89> GetDataFromDevice(): END
56:41:04> Btn_Click(): START
56:41:04> Btn_Click(): EMD
56:41:88> GetDataFromDevice(): START
56:42:39> GetDataFromDevice(): END
56:43:39> GetDataFromDevice(): START
56:43:90> GetDataFromDevice(): END
56:44:91> GetDataFromDevice(): START
56:45:43> GetDataFromDevice(): END
56:46:65> GetDataFromDevice(): START
56:46:97> GetDataFromDevice(): END
56:47:97> GetDataFromDevice(): START
56:48:49> GetDataFromDevice(): END
56:49:50> GetDataFromDevice(): START
56:49:92> GetDataFromDevice(): END
56:50:95> GetDataFromDevice(): START
56:51:46> GetDataFromDevice(): END
56:52:47> GetDataFromDevice(): START
56:52:99> GetDataFromDevice(): END
56:54:05> GetDataFromDevice(): START
56:54:57> GetDataFromDevice(): END
56:55:26> CF_pluginInit(): END
56:55:27> CF_localskinsetup(): START
56:55:41> loadSettings(): START
56:55:41> loadSettings(): END
56:55:41> CF_localskinsetup(): END
56:55:41> CF_pluginInit(): END
56:55:66> GetDataFromDevice(): START
56:56:18> GetDataFromDevice(): END
56:57:17> GetDataFromDevice(): START
56:57:69> GetDataFromDevice(): END
56:58:69> GetDataFromDevice(): START
56:59:21> GetDataFromDevice(): END
57:00:20> GetDataFromDevice(): START
57:00:72> GetDataFromDevice(): END
57:01:72> GetDataFromDevice(): START
57:02:23> GetDataFromDevice(): END
57:03:25> GetDataFromDevice(): START
57:03:77> GetDataFromDevice(): END
57:04:72> Setup_Click(): START
57:04:72> Setup_Click(): END
57:04:79> GetDataFromDevice(): START
57:05:31> GetDataFromDevice(): END
57:06:31> GetDataFromDevice(): START
57:06:83> GetDataFromDevice(): END
57:07:82> GetDataFromDevice(): START
57:08:34> GetDataFromDevice(): END
57:08:35> Setup_Click(): START
57:08:35> CF_localskinsetup(): START
57:08:56> loadSettings(): START
57:08:57> loadSettings(): END
57:08:57> CF_localskinsetup(): END
57:08:57> Setup_Click(): END
57:09:35> GetDataFromDevice(): START
57:09:87> GetDataFromDevice(): END
57:10:86> GetDataFromDevice(): START
57:11:37> GetDataFromDevice(): END
57:12:25> Setup_Click(): START
57:12:25> Setup_Click(): END
57:12:45> GetDataFromDevice(): START
57:12:87> GetDataFromDevice(): END
57:13:86> GetDataFromDevice(): START
57:14:37> GetDataFromDevice(): END
57:15:37> GetDataFromDevice(): START
57:15:89> GetDataFromDevice(): END
57:15:90> Setup_Click(): START
57:15:90> GetNewPressure(): START
57:16:90> GetDataFromDevice(): START
57:17:42> GetDataFromDevice(): END
57:18:42> GetDataFromDevice(): START
57:18:94> GetDataFromDevice(): END
57:19:95> GetDataFromDevice(): START
57:20:47> GetDataFromDevice(): END
57:21:47> GetDataFromDevice(): START
57:21:99> GetDataFromDevice(): END
57:22:08> Setup_Click(): END
57:23:00> GetDataFromDevice(): START
57:23:52> GetDataFromDevice(): END
57:24:29> Setup_Click(): START
57:24:30> GetNewPressure(): START
57:24:51> GetDataFromDevice(): START
57:25:04> GetDataFromDevice(): END
57:26:03> GetDataFromDevice(): START
57:26:55> GetDataFromDevice(): END
57:27:62> Setup_Click(): END
57:27:65> GetDataFromDevice(): START
57:28:17> GetDataFromDevice(): END
57:29:18> GetDataFromDevice(): START
57:29:70> GetDataFromDevice(): END
57:30:69> Setup_Click(): START
57:30:70> GetNewPressure(): START
57:30:85> GetDataFromDevice(): START
57:31:37> GetDataFromDevice(): END
57:32:37> GetDataFromDevice(): START
57:32:89> GetDataFromDevice(): END
57:33:89> GetDataFromDevice(): START
57:34:41> GetDataFromDevice(): END
57:34:42> Setup_Click(): END
57:35:41> GetDataFromDevice(): START
57:35:93> GetDataFromDevice(): END
57:36:40> Setup_Click(): START
57:36:40> GetNewPressure(): START
57:36:92> GetDataFromDevice(): START
57:37:43> GetDataFromDevice(): END
57:38:45> GetDataFromDevice(): START
57:38:97> GetDataFromDevice(): END
57:39:97> GetDataFromDevice(): START
57:40:48> GetDataFromDevice(): END
57:41:48> GetDataFromDevice(): START
57:42:01> GetDataFromDevice(): END
57:42:02> Setup_Click(): END
57:43:01> GetDataFromDevice(): START
57:43:53> GetDataFromDevice(): END
57:44:53> GetDataFromDevice(): START
57:45:05> GetDataFromDevice(): END
57:46:05> GetDataFromDevice(): START
57:46:56> GetDataFromDevice(): END
57:47:58> GetDataFromDevice(): START
57:48:11> GetDataFromDevice(): END
57:48:11> Setup_Click(): START
57:49:11> GetDataFromDevice(): START
57:49:63> GetDataFromDevice(): END
57:49:65> Setup_Click(): END
24:18:62> Click_Action(): CurrValue=2
24:21:68> Click_Action(): CurrValue=1
24:21:85> Click_Action(): CurrValue=2
24:22:04> Click_Action(): CurrValue=3
24:22:23> Click_Action(): CurrValue=4
28:00:10> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at tpms.tpms.GetDataFromDevice()(): The parameter is incorrect.<CR><LF>
42:02:30> Click_Action(): CurrValue=2
42:05:51> Click_Action(): CurrValue=1
42:05:68> Click_Action(): CurrValue=2
42:05:84> Click_Action(): CurrValue=3
42:06:02> Click_Action(): CurrValue=4
58:15:03> Click_Action(): CurrValue=5
58:24:80> Click_Action(): CurrValue=2
58:27:26> Click_Action(): CurrValue=1
58:27:44> Click_Action(): CurrValue=2
58:27:63> Click_Action(): CurrValue=3
58:27:82> Click_Action(): CurrValue=4
00:59:02> at tpms.tpms.GetDataFromDevice()(): Object reference not set to an instance of an object.
01:21:64> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
01:28:99> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
01:36:73> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
01:44:02> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
01:51:53> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
01:59:02> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
02:06:64> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
02:14:05> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
02:21:65> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
02:29:28> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
02:36:66> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
02:44:02> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
02:51:41> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
02:59:10> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
03:06:48> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
03:14:30> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
03:21:73> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
03:29:32> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
03:36:71> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
03:44:32> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
03:51:67> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
03:58:99> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
04:06:69> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
04:14:11> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
04:21:54> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
04:29:04> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
04:36:94> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
04:44:31> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
04:51:50> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
04:59:39> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
05:07:04> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
05:14:04> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
05:21:46> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
05:29:15> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
05:36:64> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
05:44:11> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
05:51:54> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
05:59:16> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
06:06:56> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
06:14:01> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
06:21:49> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
06:29:34> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
