Quote: Originally Posted by
syberkowboy
Hey Beehphy is the aux output auto selected or is there some jumper inside.
Sorry bud, You have a v1 which only has 5V regulated. The 12V output, is just the 12V input switched to that pin when the ACPPS is turned on. Any fluctuations of the cars power system will be present on that 12V output pin.
The Prototype ACPPSv2 has a jumper that selects the output voltage.
On to other topics.
The next run of ACPPSv1 r1.03 is almost ready to start shipping (See the stack of circuit boards below). There have been some improvements and refinments since the last run that make the current models better in many ways. The most recent improvement is the Finish on the case, It is now completely poweder coated, for improved durability.
I had to machine 200 end caps (seen in the pic) to make the best use of the $200 minimum order at the powder coater. It took me ~80 hours to machine all of the end caps, by hand on my minimill. I spun the handles of the mill aproximately 80,000 times over the two weeks while I was building them. I had to jimmy rig a power drill to help me with some of it (one particular step of machining took ~40,000 turns of the handle all by itself).
And after all that work, I've decided I'm upgrading my mill to NC/CNC control. It will cost ~$1200 to do all the upgrades I want, but It will be well worth it. The end caps will be more accurate and take less time to cut. But, beyond making production of ACPPS easier, the CNC mod will make all my projects more refined.
Also, this production run, the circuit boards have silk screens and solder masks. The previous run, the PCB's had exposed tinned copper traces. With a solder masked PCB it is more difficult for a piece of debris to short things together if it gets inside.
The new design (r1.03) still includes the expanded temperature range and smaller output ripple voltage as discussed in previous posts.
I should (hope) be sending out bills for the preorders later this week. If you are interested in purchasing an ACPPS, now is the time to make your reservation.
Jesse
PS. Sorry the pics are crap, they were taken with my phone.
