Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > User Innovations
Old 01-14-2009, 08:41 AM   #106
jdmagoo1 is an unknown quantity at this point
Hey Beehphy, finally got around to installing the ACCPS today ( i think i ordered it from you about August last year). And what can i say WOW it works like a dream. Great product.
Tip for newbies ( like me) don't run your 12 volt input wire from the same wire your amp runs on. Because after the amp delay and the amp powers on there is a slight momentary voltage drop which is enough to turn the USB hub on and off. This was playing havic with my sound card drivers etc. But the problem was easy fixed, just ran another 12 volt input wire from a different souce and all is better.
Thanks Beehphy for an awesome product, the perfect solution for powered USB hubs.
Cheers
James
P.S Bloody hot down under at the moment!!!!
jdmagoo1 is offline   Reply With Quote
Old 01-14-2009, 03:51 PM   #107
Sal R.'s Avatar
Sal R. is an unknown quantity at this point
So after testing the ACCPS for a few weeks, it is working flawlessly, despite being manhandled by UPS.
This unit has really simplified my wiring and it's nice to have an auxilary output without having to tie into the main power line.
I have it placed under my rear passenger seat, but have yet to get any complaints about heat. However, I don't carry many passengers either (dead weight).
Support has been addressed in a timely manner.
Overall, a great product and am very pleased with it.
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
Sal R. is offline   Reply With Quote
Old 06-14-2009, 05:29 PM   #108
Carz is an unknown quantity at this point
Is this still available for sale or are there other alternatives for use with Infill G4? I'm looking to power 1 if not 2 x 4-port usb hubs (read it's better if usb syncronised) and wireless 3g router (12v?).
Since Infill G4 already has it's own psu, would CNX-P2140 still works for my needs? If it does but is overkill, I would not mind since I could reuse it if I ever switch to standalone car pc.
Sorry, I've no background in electrical engineering and so would like minimum wiring solution though I've access to someone who can help me with the wiring if needed.
Carz is offline   Reply With Quote
Old 06-15-2009, 11:14 AM   #109
Beehphy's Avatar
Beehphy is an unknown quantity at this point
Yes, the ACPPS and USBi are still available. I actually just began another production run of each product.
The ACPPS has more than enough power for your USB system, but I'm not sure I understand what a wireless 3g router is. I know of Wifi A/B/G/N and 3g Cellular Wireless networks... It would also be good to understand its power requirements before designing your system as ACPPSv1 does not include a regulated 12V output.
I'm sure you could get it to work. If your Wireless thing needs 12V this might be a better option.
You might need some help. My minimum wiring solution is in the ACPPS manual. Available for download from the first post in this thread.
Beehphy is offline   Reply With Quote
Old 06-15-2009, 05:02 PM   #110
This is the router I'm referring. It says 12V @ 1A DC. Not sure the difference between regulated and unregulated. What would you advise?
Old 06-23-2009, 04:22 PM   #111
ElToro is an unknown quantity at this point
Just got the power supply installed this past weekend. After a little mis wiring, got it working perfectly, actually made wiring up the HD radio I was also installing super easy.
2 small suggestions that aren't really a big deal, but would have been a little helpful was 1.) not making the removal fuse flush with the casing , made it a bit difficult to remove while I was trying to figure out my wiring mistake without causing a short (or make the opening wider to get a needle-nose in it). 2.) It would be nice to have the same amount of ground ports as 5v power ports (not really a big deal since they are all connected anyways, but would have made wiring easier).
ElToro is offline   Reply With Quote
FAQ: Power Supplies Explained (Part 1) Bugbyte The FAQ Emporium 14 06-10-2007 08:45 AM
-5V power supply gizmomkr General Hardware Discussion 7 05-30-2007 03:00 PM
USB GPS on a PS2 Power Supply mgeorgiades GPS 1 04-28-2006 10:29 AM
FS: Mint USB 2.0 to IDE adapter with Power Supply - Only $15!! hd54321 Classified Archive 6 04-24-2005 09:32 PM
HELP!! Power Supply wont supply power Saab General Hardware Discussion 3 08-28-2000 10:33 AM
