Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > User Innovations
Old 12-10-2007, 01:04 PM   #151
Raw Wave
mitchjs is on a distinguished road
sonicxtacy02, tell me more about you're car?
are we talking about the 1995 honda?
thats a mast antenna right? (not glass)
is that a power antenna in the trunk?
that car is OLD, i would replace the antenna, the whole thing, then
DO NOT EXTEND the antenna wire, move the the tuner!
ONLY USE OEM antenna, dont use anything from metra
i have a 2002 mitsu, and i replaced my antenna, and its was like night and day
over time the antenna ground, and the mast system becomes worn, and doesnt make good connections...
also... some amplifers produce RFI which kills recpetion
(BLADE is a good example)
oh a good test of an antenna.... is AM with engine running... is it clean and free of noise...
mitch
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline   Reply With Quote
Old 12-10-2007, 08:42 PM   #152
Iceman_jkh is on a distinguished road
Quote: Originally Posted by mitchjs View Post
AUs? = Australia?
i can assure you it wont get HD
and im coded for 10k tuning
ie in america 94.1, 97.5 and our am 1060, 1120 1210
it might be able to tune like 94.2 and 9k am, but i dont know
never bothered to explore it
mitch
Mitch,
Yes I know theres no HD in Australia .. so I'm only using it for AM/FM/RDS.
Our stations are FM 100.3,101.1,101.9,102.7,105.1 [88-108Mhz I believe]
and AM 621, 693, 774, 855, 927, 1026, 1116 Khz. Is it possible to make a 9kHz tuning option for AM in Aus/other countries?
Do you ship your cables to Aus? Is there a USB version planned? - this would fix the DTR signal going high/low during POST, and turning the radio on.
Iceman_jkh is offline   Reply With Quote
Old 12-10-2007, 09:12 PM   #153
Sal R.'s Avatar
Sal R. is an unknown quantity at this point
How are you guys bench testing your HD radio to configure for the carPC?
I have a 15amp 13.8V power source that I use to bench test my carPC. Can I just hook it up to that?
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
Sal R. is offline   Reply With Quote
Old 12-10-2007, 10:31 PM   #154
High Voltage
blk02si's Avatar
blk02si will become famous soon enough
That should be fine, when the car is running it puts out 14.4 volts so the tuner has to have some built in regulator.
Im still trying to figure out how to have roadrunner save a list with this tuner, and also to return to HD menu and save the station it was on. Right now any time I leave the HD menu and come back it is at 87.5 and I have to retune it.
blk02si is offline   Reply With Quote
Old 12-11-2007, 12:22 AM   #155
Raw Wave
iceman, no plans for USB...
i dont think this tuner will last anyway...
this is a new technolgy, if this is a 2nd generation tuner
i expect new tuners next year...
i have no idea whats coming, and/or i will interface it to pc
i dont know how to make it do 9khz
remember i reverse engineered this (aka hack)
and if the display dont have the option... i never saw the command
-Mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 12-11-2007, 12:34 AM   #156
mitch> yep. i understand.
Can I buy your cable and get you to ship it to Aus?
Old 12-11-2007, 05:51 AM   #157
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
I am not sure how to fix it, but am pretty sure it is in RR"s code, and nothing to do with the plugin, DLL ect.
RR needs to keep track if the radio is playing or not, and know that when going to the screen.
It is especially annoying when I hear a song on the radio, and switch to the skin to see the title and such, and it tunes to another station!
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 12-11-2007, 09:06 AM   #158
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
mitch
Yes its for my 95 accord and unfortunately it is in the glass This particular year of the car never came with an external mast. My tuner has been in two different locations.. the trunk.. and behind the monitor up front in my car. The difference is barely noticable. Is there anything i can place my tuner in that would reduce the amount of RFI affecting it? I did notice that when i had it in the trunk next to a boss amp i have the reception sucked unless i put my rear seats down. In its current location behind the monitor it works better but its certainly nowhere near as strong as the stock radio in my van is.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 12-11-2007, 09:55 PM   #159
BimmaDrew is on a distinguished road
dang-it! I manage to snag a half hour before it was too dark out to install my HD radio only to find that I need an adapter for my antenna. GRRR now I have to wait one more week......
Epia EN15000, Evga PCI Video, 60GB, Travla C138
Xenarc 7", Carnetix P1900 & P5V, Audigy 2NX, XMPCR
RR, iGuidance 4, I-Bus
Kenwood ZX1000.1, Audiobahn AW1200Q & 1F Cap
PPI PC450, Diamond Audio S600s
BimmaDrew is offline   Reply With Quote
Old 12-11-2007, 10:45 PM   #160
Raw Wave
sonicxtacy02, i would conside getting a TRUNK mounted Power Antenna installed
I bet you could get a honda one...
ah i do remember accords with the glass antenna, is it passive or is there an amplifer?
i know they had trunk mounted antennas around that year
might only be for sedans...but check anyway...
I did a quick check in alldata, shows a power antenna... for 1995 coupe
and i bet the mount is there, just need the hole in the body
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 12-11-2007, 10:47 PM   #161
Raw Wave
as for rfi, only way would be to dump the amp
now rfi really shows up on AM as high pitched noise
class D amps could have this, with their hight freq switched power supply
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 12-12-2007, 10:53 AM   #162
High Voltage
blk02si's Avatar
Have you looked into RR and the tuner at all mitch?
Old 12-12-2007, 08:43 PM   #163
Sal R.'s Avatar
Finally...I get decent radio again.
Thanks again mitch for all you hardwork on this.
Old 12-12-2007, 08:57 PM   #164
greatwhite's Avatar
greatwhite is an unknown quantity at this point
Anyone else having a problem with config overwriting your hd radio settings everytime you save an config change?
I manually edit the rr.ini, but config overwrites as there is no option for HD radio in the config utility yet.....
Only when I Make a change and save though Config..............
*edit- nevermind, I was using an older version of config. Solved*
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 12-12-2007, 11:30 PM   #165
High Voltage
blk02si's Avatar
I agree and believe this is in the RR code also. I know my HQCT had a ini file in the hqct directory in RR to save presets. I have great functionality with this tuner and RR so far, can tune really good signal and sounds great with no noise (yes i did your ground mod mitch )
Anyway I do think RR just needs some more coding to make this happen. It also seems that RR will lose communication with the tuner if I go 3 or more menus deep away from my HD skin. Only fix is to go to mp3 or vid, then back to HD which sets me back at 87.5.
I know the software will catch up soon This is the newest tuner available to RR so I did not expect it to be perfected just yet. I am going to be releasing my new skin very soon with the note that HD is still in beta. Hopefully we can get some more heads working on this to get it solved.
PC Card for HD Radio Spotted General MP3Car Discussion 13 09-03-2008 08:01 PM
HD Radio skyhawk2114 StreetDeck 12 06-04-2008 02:17 PM
HD radio in my BMW DAMBRO24 Car Audio 3 11-14-2007 06:19 PM
Someone here has be be able to crack this HDRadio for the car! Kamakazie2 Hardware Development 243 09-20-2007 09:04 PM
HD Radio? peecee Car Audio 3 12-31-2006 03:48 AM
