Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > User Innovations
Old 02-27-2008, 09:16 PM   #451
krnpimpsta's Avatar
Yeah, what he said. -^
Also, I struggled until I capitalized hdradioport as "HdRadioPort" or "HDRadioPort" - I don't remember. I'm under the impression it's case sensitive because it began working after that.
2008 Mustang GT CarPC
krnpimpsta is offline   Reply With Quote
Old 02-27-2008, 10:21 PM   #452
smp4488's Avatar
blk02si, Still no luck. I never hear the radio "click" on when i go to the radio page. Any more ides?
smp4488 is offline   Reply With Quote
Old 02-27-2008, 10:32 PM   #453
blk02si's Avatar
make sure your roadrunner.exe is the newest available. Unregister and reregister the DLL.
Make sure your port setting is correct, sometimes PC's will do weird things with the ports if you have multiple things connected.
My carPC - www.shocknet.us
blk02si is offline   Reply With Quote
Old 02-28-2008, 12:21 AM   #454
it seems, just about everytime this happens, its because you're using the "test" version of the .dll
the newest .dll is in this thread...
drop it in, and "runme1st.cmd"
mitch
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline   Reply With Quote
Old 02-28-2008, 12:23 PM   #455
here is that post!!
http://www.mp3car.com/vbulletin/1162527-post298.html
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 02-29-2008, 08:01 AM   #456
smp4488's Avatar
Ok, I have swapped out the dll's and re ran the batch file still no luck. RR is the latest version as well as all my skin item. The config has been edited with all the suggestions and still no luck. What am i missing?
Old 02-29-2008, 08:09 AM   #457
blk02si's Avatar
are you running a USB > RS232 adaptor or running straight to the serial port?
If all is done as you say, and mitch's app works, RR has to be stealing your HD port assignment when it launches.
I know it can happen because when I upgraded to IG4 it stole COM1 from the HD. When I launched IG4 it would turn on the relays in the HD radio and then turn them right off, and it rendered the HD menu useless.
What other devices do you have plugged into the PC? Please list any USB.
Old 02-29-2008, 08:30 AM   #458
smp4488's Avatar
Im not using the adaptor and i do have IG4. I changed the port in IG but right now the only usb devices pluged in are a hub and mouse. Nothing is plugged into the hub. I know what your talking about with IG because i hear the click when it launches also. I change the port, close it, relaunch to make sure its not on the same port.
Old 02-29-2008, 09:28 AM   #459
krnpimpsta's Avatar
Did you try messing with the capitalization of "HDRadioport" in "HDRadioport=1"? I found that mine didn't work until I got the capitalizaiton just right.
EDIT: Ok, just searched through forums (not by my carputer right now) and the correct capitalization should be:
HDRadioport=1
Old 02-29-2008, 09:42 AM   #460
blk02si's Avatar
Your problem is discovered then. If its clicking upon IG launching then its probing your HD radio port looking for the GPS dongle. Try changing the GPS dongle to a diff. usb slot and setting it to port 6 or 7.
Also you can try what krnpimpsta has suggested although my HD radio works fine with all lower case in the rr.ini
Old 02-29-2008, 10:49 AM   #461
smp4488's Avatar
The GPS dongle is not plugged in at all right now. Should i plug it in and then try?
Old 03-03-2008, 02:39 PM   #462
smp4488, get it working?
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 03-03-2008, 05:37 PM   #463
fixinstuff's Avatar
I got mine HD Radio installed over the weekend. I recieved my cable today (thanks Mitch). I cant wait to see it running on my computer. Now the problem is I fried my harddrive. Wired the IDE cable to the harddrive incorrectly. If anyone can help please reply to the post below.
IDE to Mini IDE Question
Once again thanks for the quick delivery Mitch. I am so excited to get it working. The reciever alone sounds awesome.
Plan for project = 100%
Part the project. = 99%
Built...................= 90%
Install ...............= 99%
Forever In Progress
Scott AFB, IL
fixinstuff is offline   Reply With Quote
Old 03-03-2008, 07:13 PM   #464
HiJackZX1's Avatar
For the HD Radio, I see that there are 2 HD units you can buy....... do both use the same software and drivers or does each have its own? I ask because I know they will be working on a plugin for the Visteon HDZ300 for CF, but I'd prefer the cheaper one, my CarPC install is already way over budget
PS: Mitch I see under XM there is nothing. Do you make serial cables for the XM direct at all? If yes, I would like to buy one...
PLANNING [100%]
CAR PC ITEMS [100%]
INSTALL OF PC [100%]
BUG WORKOUT [75%]
INTERIOR MODS [50%]
BUDGET [380%]
HiJackZX1 Work Log
HiJackZX1 is offline   Reply With Quote
Old 03-03-2008, 10:35 PM   #465
smp4488's Avatar
Mitch, still no luck and not alot of time to work beacuse of teachers cramming before spring break. All of the above has not worked for me so i have no idea what is up.
PC Card for HD Radio Spotted General MP3Car Discussion 13 09-03-2008 07:01 PM
HD Radio skyhawk2114 StreetDeck 12 06-04-2008 01:17 PM
HD radio in my BMW DAMBRO24 Car Audio 3 11-14-2007 05:19 PM
Someone here has be be able to crack this HDRadio for the car! Kamakazie2 Hardware Development 243 09-20-2007 08:04 PM
HD Radio? peecee Car Audio 3 12-31-2006 02:48 AM
