Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > User Innovations
Old 03-04-2008, 12:40 AM   #466
Quote: Originally Posted by blk02si View Post
My radio reception is also much better than my stock headunit. When it's in HD mode its as clear a CD no doubt.
The HD tuner is by far the best AM/FM solution, and this is coming from someone who has tried them all including the expensive/rare HQCT module. In fact I own 2 HD tuners and am in the process of adding the second to my home theater PC.
Also, just a FYI, the Visteon unit is actually a standalone tuner that has been reverse engineered (by mitch) to allow PC interfacing.
Does someone have a link of a webshop who sales a good Visteon HD tuner and ships internationaly?
And is it possible to integrate it in Centrafuse?
GreenBeauty is offline   Reply With Quote
Old 03-04-2008, 03:16 AM   #467
thanks mitch. got the cable today. i didn't even expect the audio cables as well. nice touch. now off to try install this fricken thing
shdw03 is offline   Reply With Quote
Old 03-04-2008, 05:13 AM   #468
greatwhite's Avatar
Quote: Originally Posted by HiJackZX1 View Post
For the HD Radio, I see that there are 2 HD units you can buy....... do both use the same software and drivers or does each have its own? I ask because I know they will be working on a plugin for the Visteon HDZ300 for CF, but I'd prefer the cheaper one, my CarPC install is already way over budget
PS: Mitch I see under XM there is nothing. Do you make serial cables for the XM direct at all? If yes, I would like to buy one...
The visteon and the (can't remember the name of the other) are the same unit but "rebadged".
Both work fine with the rr plugin and mitch's software.
Cheers
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 03-04-2008, 01:35 PM   #469
Has anyone started on the centrafuse support??
jayrod7387 is offline   Reply With Quote
Old 03-04-2008, 08:38 PM   #470
HiJackZX1's Avatar
David (creater of CF), is going to be working on a plugin. He says he has purchased the Visteon and Mitch's cable, so im sure it will be avaliable soon. He said he wants to get CF v1.48 out first before working on it. Go to Fluxmedia.net and check out the forums, it has everything you want to know.
PS: Thanx for the info GreatWhite
PLANNING [100%]
CAR PC ITEMS [100%]
INSTALL OF PC [100%]
BUG WORKOUT [75%]
INTERIOR MODS [50%]
BUDGET [380%]
HiJackZX1 Work Log
HiJackZX1 is offline   Reply With Quote
Old 03-04-2008, 08:54 PM   #471
Thump
I don't know if i'm the only one having these probles but i'm using the DigitalFX 2.0 skin, with a Visteon HD radio , and one of Mitch's cables (awesome). But when I switch to the radio skin, I hear a click, and everything but then there is a thump through the speakers! Not good! lol Also I noticed that the station that I start on is much louder then all of the others, once I switch stations then they are all the same loudness.
I'm guessing that the thump is from the radio turning on, is there a way to stop this?
2001 Camaro SS #2070
CoryF is offline   Reply With Quote
Old 03-04-2008, 10:32 PM   #472
try grounding the rcas!
check for noise
mitch
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is online now   Reply With Quote
Old 03-04-2008, 11:41 PM   #473
check for noise
mitch
Ok I did the grounding thing and it didnt help, the sound when it first turns on sounds like a spike. Its like all the components are being powered up and before there is music there is the noise of everything turning on...
Old 03-05-2008, 01:31 PM   #474
thanks for the info hijack
Old 03-05-2008, 01:54 PM   #475
HiJackZX1's Avatar
Your welcome..... its good to know I actually know something, lol
PLANNING [100%]
CAR PC ITEMS [100%]
BUG WORKOUT [75%]
INTERIOR MODS [50%]
BUDGET [380%]
HiJackZX1 Work Log
Old 03-05-2008, 03:03 PM   #476
coryF, how about set it up inside home
mine made a SMALL thump, but once i grounded the rcas, it was quiet and the audio was cleaner...
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 03-05-2008, 06:00 PM   #477
Mitch I am bench testing it using a 110V power supply, I thought it was maybe because i was running it off of the computer power supply, so i brought in my red top optima and hooked it up to that and there was still no change. There is still a sound when i turn it on and the first station is still louder...
I also tried a different cable (I have 2 ), and it does the same thing. Then i tried a different skin still does the same thing.
So then i tried plugging in the display that came with the radio and when i turn it on and off with the display it does not make the weird noise, OR make the first station louder.
Old 03-06-2008, 03:27 PM   #478
you got some wierd gnd loop maybe...
remember when you connect up the rs232, u create a ground to your PC
and could got something wierd with the speaker power supply too
use my demo... too, dont use roadrunner for testing the volume stuff
u could prove all that, connect gnd to the computer case...
mitch
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 03-06-2008, 03:32 PM   #479
i just had a buddy test, with my app, no change in volume when u tune from channel to channel...
use HDRADIO PCR for testing
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 03-06-2008, 04:17 PM   #480
Mitch, I tested the problem outside of RR using the "HD Radio PCR" and still the same thing. I noticed that there is still the same static/thump when it turns on. Also when I turn off the radio inside the PCR program and then turn back on the radio there is another smaller static thump.
Next I tried testing not using my sound card or any of the audio parts of the computer. I hooked the RCAs up directly to my home stereo. Same thing when I start the program there is the thump and when I turn on and off the radio there is a smaller lighter thump.
One thing that I did notice is that the controller that comes with the radio, when it turns everything on it does like a "soft start." First the display lights up then the radio fades in. Does the cable just tell everything to turn everything on at once? This could be the cause of the spike...
The HD Radio PCR program removed the loudness in the first tuned channel so that is a plus
PC Card for HD Radio Spotted General MP3Car Discussion 13 09-03-2008 07:01 PM
HD Radio skyhawk2114 StreetDeck 12 06-04-2008 01:17 PM
HD radio in my BMW DAMBRO24 Car Audio 3 11-14-2007 05:19 PM
Someone here has be be able to crack this HDRadio for the car! Kamakazie2 Hardware Development 243 09-20-2007 08:04 PM
HD Radio? peecee Car Audio 3 12-31-2006 02:48 AM
