The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > User Innovations
Thread Tools Search this Thread Display Modes
Old 03-18-2008, 12:23 AM   #511
utd09bry's CarPC Specs
utd09bry's Avatar
Vehicle: 2002 Ford Explorer
My Photos: (15)
Quote: Originally Posted by jayrod7387 View Post
my soundcard uses mic and line in as rear and sub out when a setting is changed. not a true 6 or 7 channel......
wait... what are you connecting your sound card's output to? 2/4 channel receiver? headunit?
i agree that you should use line-in for any inputs and not the MIC port. it's true that it might only be a mono-in.
anyways, if you are saying that MIC is normally your rear channel output, then unplugging that and using it for input would disable your rear channel (if you were, say, using a 4 channel amp.) I'm really hoping its more complicated than that.. but might as well ask the obvious.
utd09bry is offline   Reply With Quote
Sponsored Links
Old 03-20-2008, 06:54 PM   #512
Bivio's CarPC Specs
Vehicle: 2003 Jeep Grand Cherokee
My Photos: (17)
length?
Hey mitch,
Cable works great, only thing im wondering, can i cut off the end of your cable and add the cut off length of the one that came with the HD HU? If i needed more length for example. What i mean to as is this, are all the electronics and such that you added to the cable on the rj232 jack?
Bivio is offline   Reply With Quote
Old 03-20-2008, 07:25 PM   #513
My Photos: (0)
sure, kiinda, but dont do that.... very hard to solder
just purchase a mac straight male to female extension
http://www.monoprice.com/products/pr...seq=1&format=2
-Thanks
Mitch
www.rush2112.net
mitchjs is offline   Reply With Quote
Old 03-25-2008, 01:43 PM   #514
My Photos: (0)
you get some cables in yet mitch?
frollo is offline   Reply With Quote
Old 03-25-2008, 01:48 PM   #515
My Photos: (0)
THEY Coming, i got my fedex trackin number yesterday!!!
i will be shipping a bunch this week!!!
woo!
mitch
-Thanks
Mitch
www.rush2112.net
Old 03-27-2008, 06:39 PM   #516
My Photos: (0)
yes i am running my front and rear output to a 4 channel amp. I really need an input channel....
jayrod7387 is offline   Reply With Quote
Old 03-27-2008, 11:07 PM   #517
RipplingHurst's CarPC Specs
Vehicle: 06 Infiniti M35 & 07 Infiniti FX35
My Photos: (28)
I'm still waiting for my cable since last week, just bought the HD radio at the Best Buy Outlet store for 28.99. Hopefully I'll get the cables soon, thanks!
Mitch, what RS232-to-USB brand do you use? I found a couple of them at my local Fry's, but none of them inspired confidence. Which one uses the FTDI chip? Air link?
Thanks.
RipplingHurst is offline   Reply With Quote
Old 03-28-2008, 07:27 AM   #518
My Photos: (0)
Got my cable two days ago...thanx Mitch!!
eribs4e is offline   Reply With Quote
Old 03-28-2008, 02:06 PM   #519
greatwhite's CarPC Specs
greatwhite's Avatar
Vehicle: 2004 Chrysler 300M Special
My Photos: (1)
Quote: Originally Posted by greatwhite View Post
Well, removed teh rca ground jumper and all my "ground loop" noise is gone. The beeping/buzing/alternator whine is completely gone.
Now there's a base sizzle noise in the system. It's definately induced by the radio as unplugging or muting the line in for the sound card makes it completely dissapear.
I did notice that it could be made louder or quiter by handling the black box on the constant 12v in. I had to resoldier the connections in the box when I got it as the wires came completely out (fell out when I turned it over in my hands). I'm going to investigate that next.
I'm beginning to think the build quality on these units isn't so high.........
OMFG I found it!
After a month or so of just running without the radio plugged into the sound card because of the interference noise, I went back to trying to get it to work (it's been pretty cold here lately, didn't feel like freezing "you know what" off in the garage).
OPlugged it back in and the noise returned to the sytem like "ol' faithful".
Chased settings around in the KXdriver, same results no matter what I tried.
Started thinking about rewiring, moving stuff and grounding schemes but Everything looked proper as I worked through the installation.
I got to the 3.5 mm jack at the soundcard. Now, keep in mind, my sound card jacks are very difficult to see where the Mputer is installed. I usually have to use a mirror to confirm things are plugged in correctly.
Plugged in, good solid connection........but waita minute.............somehow I've got it in the MIC in jack. Hmmmm, maybe I'll try the "Line in" jack like I thought I had it hooked up.
Plugged it into the LINE IN port, unmuted the corresponding line in the driver and............
SUCCESS!
No noise!
For some reason either the KXdriver or the audigy 4 didn't like having the sound fed into the MIC port. Go figure................
I knew it had to be something simple, another "fumble" on my part I guess.
Now, I just have to find a way to improve reception on the analog mode as I don't have HD feeds in my area.
So, finally to the point:
MITCH, I'm using the in glass antenna (yes, I know you don't like them) as my car is rather expensive (300M Special) and I'm not going to install a mast antenna on it.
You seem to have a pretty good grip on how radio works and my antenna must have been amplified in the old head unit as the adapter (small black box, no power lines) to the glass antenna only has the coax running out of it.
Is it possible to for you to build a signal amplifier (or buy one) to go in line between the antenna and the Visteon for improved signal?
Would it even do any good?
I'm almost back to the radio quality of a stock Head unit, the visteon just seems to have more static cutting in and out as I drive or turn the car certain ways (probably masking the signal and the unit is dropping in and out).
My stock Head unit worked great with the in glass, Pulling in stations clearly from unbelievable distances sometimes. Now, obviously, the factory unit was matched to the antenna and this is why it worked so well. But there must be a way to adapt the visteon to this receiving method.....
I noticed what appears to be an antenna "trim pot" in the Visteon. Would there be any sense in trying to tune the unit to my antenna (like old aftermarket units used to be able to)?
The visteon manual makes no reference to tuning to the antenna or an "antenna trim pot", but it sure looks like one and I know I always used to tune my aftermarket units to my vehicles antenna for proper reception..........
Or am I totally out in left field on this?
Cheers
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 03-28-2008, 02:23 PM   #520
My Photos: (0)
oooh, antenna stuff is waaaay over my head, that RF stuff is a ton of science and bit of black magic...
yes... the factory antenna is designed to work with the factory radio... now sometimes the antennas electronics are outside the radio... sometimes they not...
when they are, maybe you can get the amp powered on...
id say hit up a car audio forum, but i bet NO ONE replaces the stock 300 radio!
good luck
mitch
-Thanks
Mitch
www.rush2112.net
Sponsored Links
Old 03-28-2008, 02:29 PM   #521
My Photos: (0)
hmm, i dont know what fry carries, dont got them around here...
i know i buy one at mouser, its not cheap, but i know who makes it...
i think i posted the url... in another post... i look
course out of stock
http://www.mouser.com/Search/Product...zrx5IjRQ%3d%3d
there is this too... i got one its ftdi
http://www.cablewholesale.com/specs/10u1-06103.htm
mitch
mitch
-Thanks
Mitch
www.rush2112.net
Old 03-28-2008, 06:30 PM   #522
greatwhite's Avatar
My Photos: (1)
good luck
mitch
nah, the 300 radio is just like any other factory radio, marginal at best. Mine was the factory RB1 sat nav radio and it hit the shelf about 4 weeks after I bought the car. The chrysler 380w amp was right behind it..............
Pretty much crap. Fit the dash and interior look nicely though..............
So the quest for a non-mast antenna began.
who do I turn to?
Why Google of course!
Seems moptorcycles and hot rods have already figured this one out.
A quick "peruse" of a couple hot rod forums later turned up something they use for radio instead of the mast antenna (and something I knew about a long time ago but forgot):
Dakota Digital amplified antenna
Supposed to be as good as a 31" mast antenna and it receives FM AND AM unlike the non-amplified "stick on" antenna's which, according to what I've read lately, only do FM (not a piece of info that's easy to find either)
But......yipes! They sell for 80 bucks plus shipping!
That won't do.
Then a quick sidestep over to ebay grabs me a dakota digital ant 1000 for 35 bucks and 3 bucks shipping. Shipped for less than half the asking price on the Hot Rod and Harley shops. Cool.
The Harley forums and the Hot Rod forums I visited said it works as good as if not better than thier stock antenna. Probably a little optomistic, but it is 12v powered antenna with amplifier built in. If it works anywhere near thier claims, it may be a viable alternative to the mast. In my case, the only alternative (not drilling a hole in that nice 300M body)
I'll post a quick review after it gets here for those not wanting to install a mast antenna on their in-glass antenna equipped cars (or those that just want to shave the bloody thing off).
I'm so close now:
Mputer radio integration (thanks to mitch for the cable and Hugenious for the Void skin)
Hd/ananlog am/fm (thank visteon)
no noise! (thank to me finding my screw up ie;mic in vice line in)
Dakota digital (hopefully for a decent amplified antenna
Here's hoping the visteon, mitch's cable and the ant 1000 are a match to my radio hopes......
Hey waita minute! Anyone ever stop to realize how much they've spent to get sound like the factory radio already has?
Leonardo Da Vinci
Old 03-30-2008, 07:51 AM   #523
My Photos: (0)
Got everything working beautifully on my test bench. Made the changes described in the thread and everything fired up first try!
Thanx for the great work mitch...you absolutely
Old 03-30-2008, 01:57 PM   #524
My Photos: (0)
thanks
shipping update, everyone who has ordered before today (3/30) has shipped
YEAAH!
i got a few ready to go, so if your on the fence, order now... else
it might be another 10 day wait
-Thanks
Mitch
www.rush2112.net
Old 03-30-2008, 04:58 PM   #525
My Photos: (0)
Mitch, I'll take one...
If, of course, when the latest CF update comes out, it'll need this cable to interface it...
PM me
WuNgUn is offline   Reply With Quote
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
PC Card for HD Radio Spotted General MP3Car Discussion 13 Yesterday 07:01 PM
HD Radio skyhawk2114 StreetDeck 12 06-04-2008 01:17 PM
HD radio in my BMW DAMBRO24 Car Audio 3 11-14-2007 05:19 PM
Someone here has be be able to crack this HDRadio for the car! Kamakazie2 Hardware Development 243 09-20-2007 08:04 PM
HD Radio? peecee Car Audio 3 12-31-2006 02:48 AM
Sponsored Links
Ad Management by RedTyger
