Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > User Innovations
Old 06-06-2008, 08:58 AM   #616
PontiacGA's Avatar
Quote: Originally Posted by HiJackZX1 View Post
You could also use a software called AMP CTRL. It uses pin 4 on a serial port to turn on the amps. The software waits for your soundcard to turn on, then turns on the amps. Only issue is you have to have a extra serial port. Thankfully I have 4 of them.
This is exactly what I need for my amp(s)! But, I only have 1 serial port. Will this work on the Parallel port (pin 20, I assume?)? Or can a serial port splitter be used?
Mike
My Rides:
'03 Vibe GT!
My AED GA!
PontiacGA is online now   Reply With Quote
Old 06-06-2008, 10:50 AM   #617
i saw a parallel port version!
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline   Reply With Quote
Old 06-06-2008, 12:10 PM   #618
HiJackZX1's Avatar
It has a config file... all you have to do is change the com port assignment to what ever the parrallel port is set to, and put it on pin 4 of that...... should work, wouldnt hurt to try....
PLANNING [100%]
CAR PC ITEMS [100%]
INSTALL OF PC [100%]
BUG WORKOUT [75%]
INTERIOR MODS [50%]
BUDGET [380%]
HiJackZX1 Work Log
HiJackZX1 is offline   Reply With Quote
Old 06-06-2008, 01:06 PM   #619
diggs's Avatar
I'm curious to know about the noise/grounding issue.
I hooked up the Visteon HD Radio using Mitch's cable (Thank you!) and a RadioShack RS232->USB adapter today. I had no problems configuring RR using the DFX 3.0 skin, and I can control the radio just fine. I get full reception and can tune HD and analog signals, no problem.
My problem is with audio distortion. When I turn on the radio I get sound but it is extremely distorted. The sound is very much 'cheap paper speakers about to blow'-ish.
I attempted jumping a wire from the white rca to where the ground is connected (cigarette lighter), but it made no change in the sound or amount of distortion. When I pulled the jumped wire out, I also pulled out the negative wire coming from the radio - and the radio played still at the same levels.
So since the radio sounded the same without being grounded at all through the negative wire (12V ACC & Constant only), does this mean I need to find a better ground than the cig lighter wire?
I'm thinking it's either that, or problems like greatwhite had with using mic-in instead of line-in. Which would mean another purchase for me, since my laptop only has a mic-in.
diggs is offline   Reply With Quote
Old 06-06-2008, 02:21 PM   #620
HiJackZX1's Avatar
Have you tried lowering the volume for line-in and mic-in... If its too high it will sound distorted, almost like they are talking right next to the speaker and trying to blow it out...
PLANNING [100%]
CAR PC ITEMS [100%]
BUG WORKOUT [75%]
INTERIOR MODS [50%]
BUDGET [380%]
HiJackZX1 Work Log
Old 06-06-2008, 02:25 PM   #621
diggs's Avatar
I have, and it's turned down very low (like 1 on a scale of 10), although perhaps I'm underestimating the level of lowness it needs to be at. When I get home I'll try adjusting it to just above mute and see if it makes any difference.
Old 06-06-2008, 02:25 PM   #622
u are prob over driving the MIC-IN
some mic-ins, have a MIC-boost option, in the audio settings turn that OFF
I wouldnt use the MIC-IN, i would get myself a USB AUDIO IN DEVICE
or just move all audio to usb, a usb audigy or something like that
a simple USB AUDIO IN, is dirt cheap, if u use that u need to move the audio acrross devices... so thats the winamp line in plug in...
what are u even using for audio out, the laptops 2 channel audio out?
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 06-06-2008, 02:33 PM   #623
diggs's Avatar
mitch
I'll look for that boost option and see if I have it. I'll also try to find a USB audio-in or sound card (hopefully locally).
I'm using the headphone out on the laptop.
Old 06-06-2008, 02:37 PM   #624
MySQL Error
Sonicxtacy02's Avatar
mitch brings a good point.. for those of us missing line-ins audio capture devices may just work. I'll have to test mine out.
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
HARDWARE PROGRESS: 90%[/////////-]
Developer of: RRFusion, MovieTimes, (new)RRMail
Coming Soon:RRChrome, RR Plugin Browser & CentraFusion
Old 06-06-2008, 04:17 PM   #625
diggs's Avatar
It was the Mic Boost option, I un-checked it and now it sounds great! Thanks, Mitch, for the help AND your fantastic cable
Old 06-06-2008, 09:54 PM   #626
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 06-08-2008, 06:44 PM   #627
PontiacGA's Avatar
Would it still be pin 4 on a Parallel port?
I seen the config file and figured that could be edited for the parallel port. Just wanna make sure that it's the right pin.
Mike
My Rides:
'03 Vibe GT!
My AED GA!
Old 06-12-2008, 10:03 AM   #628
Just wanted to chime in here on the echo. I know with my Audigy sound card, I have to mute the WAV input to get rid of the echo. I'm looking for a way to do this prgramatically when HD starts fromt he DFX3.0 skin. Right now I just mute it manually wehn I want to listen to the radio, but that is "clunky". Anyone know how to do this from the skin?
ccrum is offline   Reply With Quote
Old 06-15-2008, 08:43 AM   #629
PontiacGA's Avatar
Ok, so I take it DTR is pin 20 on a 25 pin parallel port, according to this chart...same as pin 4 on a 9 pin cable. Wanna make sure so I dont fry anything.
DB-9 to DB-25 Adapter or Cable
Used to adapt serial ports to the proper size
25 Pin 9 Pin Signal-RS232
Connector Connector
1 n/a Protective Ground
2 3 TX Transmit
3 2 RX Recieve
4 7 RTS Request to Send
5 8 CTS Clear to Send
6 6 DSR Data set Ready
7 5 Signal Ground
8 1 DCD Data carrier detect
9 n/a + Transmit
11 n/a - Transmit
18 n/a + Recieve
20 4 DTR Data terminal ready
22 9 RI Ring Indicator
23 n/a DSRD Data signal-rate indicator
25 n/a - Recieve
ccrum...thanks for the info. Unfortunatley, it didnt work with mine.
Mike
My Rides:
'03 Vibe GT!
My AED GA!
Old 06-15-2008, 02:28 PM   #630
PontiacGA, thats NOT a parallel PORT!!!!
a parallel port = (old style printer port)
not used by anything anymore
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
PC Card for HD Radio Spotted General MP3Car Discussion 13 09-03-2008 07:01 PM
HD Radio skyhawk2114 StreetDeck 12 06-04-2008 01:17 PM
HD radio in my BMW DAMBRO24 Car Audio 3 11-14-2007 05:19 PM
Someone here has be be able to crack this HDRadio for the car! Kamakazie2 Hardware Development 243 09-20-2007 08:04 PM
HD Radio? peecee Car Audio 3 12-31-2006 02:48 AM
