Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > User Innovations
Old 06-15-2008, 06:55 PM   #631
PontiacGA's Avatar
ok, let me put this in easier words.......the connector on the back of the Intel D201GLY2 MB, the maroon colored one, not the smaller COM port or Video port, but the longer one......what pin is the DTR? Is it still #4 as it is on the smaller COM port? Hows that?
Mike
My Rides:
'03 Vibe GT!
My AED GA!
PontiacGA is offline   Reply With Quote
Old 06-15-2008, 08:02 PM   #632
NONE of the pins on that connector is DTR!!
DTR is a serial port pin
http://www.interfacebus.com/Design_C...l_PC_Port.html
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline   Reply With Quote
Old 06-16-2008, 07:20 AM   #633
PontiacGA's Avatar
Ok. Thanks.
Mike
My Rides:
'03 Vibe GT!
My AED GA!
Old 06-16-2008, 07:40 AM   #634
pontiacGA what are you trying to do... amp turn on... what program?
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 06-16-2008, 08:08 AM   #635
PontiacGA's Avatar
Yep. I was going to use the AMPCTRL program. Your HD cable is taking up the serial port and I'm NOT giving that up. I was thinking USB>Serial adapter. Will this work? I have plenty of USB ports.
Mike
My Rides:
'03 Vibe GT!
My AED GA!
Old 06-16-2008, 11:49 AM   #636
yes... if u get the right usb > serial... FTDI based! shouldnt be an issue
but ampctrl does have a parallel port option
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 06-16-2008, 03:59 PM   #637
maybe it dont have one...
but maybe i can make u something
what do u want to do?
how does RR talk to ampctrl?
cmd line?
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 06-16-2008, 05:40 PM   #638
HiJackZX1's Avatar
cmd line?
mitch
From my understanding AMPCTRL works by sensing sound..... When sound is active in a certain amount time the program turns on the AMPS. SAy for example when I first log into windows, there is no sound, once I activate CF sometimes the logo sound will trigger AMPCTRL, but most of the time its when a song starts to play, has nothing to do with the Front End at all, unless you guys are using a diffrent version.
PLANNING [100%]
CAR PC ITEMS [100%]
INSTALL OF PC [100%]
BUG WORKOUT [75%]
INTERIOR MODS [50%]
BUDGET [380%]
HiJackZX1 Work Log
HiJackZX1 is offline   Reply With Quote
Old 06-16-2008, 07:48 PM   #639
PontiacGA's Avatar
All I want to do is turn on my freakin' amp AFTER windows starts. How would you wire the amp to the parallel port then for ampctrl?
Mike
My Rides:
'03 Vibe GT!
My AED GA!
Old 06-16-2008, 08:02 PM   #640
why after windows starts... id want my amp on when say RR starts...
ampctrl... sounds like NO control... its just sets the dtr line when it runs
i assume ur using a transistor... to drive a relay?
i could write a program, that turns ON a bit on the parallel port...
do you want RR to control amp ?
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 06-17-2008, 07:32 AM   #641
PontiacGA's Avatar
Because after window starts and initiallized the soundcard, the VERY annoying buzzing sound stops.
Right now I have the amp turn on lead hooked to the ACC.
I'd rather have windows start it, thats why I was going to use ampctrl. My last option is just to put a damn on/off switch on the amp and turn it on after windows is running!
Mike
My Rides:
'03 Vibe GT!
My AED GA!
Old 06-17-2008, 08:29 AM   #642
well id have to make a service...
i already added something to RR, turns on a pin on LPT when RR starts, and turns it off when it stops or hibernates...
i cant easily test it... unless i can find a printer port connector, and solder in a LED
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 06-17-2008, 01:41 PM   #643
HiJackZX1's Avatar
AMPCTRL will rid you of all of your problems..... Because my soundcard is USB, I have annoying pops during windows load.... I tried the timer delay thing on my PSU and it did nothing at all, because after 10 seconds my PC is still trying to load the 13 + USB devices. Using AMPCTRL sent me to heaven. I do have a slight sound when putting the car into hibernation or shut off, but it doesnt bother me at all. It is so faint.
PLANNING [100%]
CAR PC ITEMS [100%]
BUG WORKOUT [75%]
INTERIOR MODS [50%]
BUDGET [380%]
HiJackZX1 Work Log
Old 06-17-2008, 02:10 PM   #644
hijack, are u not reading, unless u have a special version of AMPCTRL, we have no serial ports
course i could write a try app, that when run, turns on a pin of the LPT port
but i already added it to RoadRunner
pontiac, we can do anything you want... i just need direction
you skiped some of my questions i asked too
1. your using a transistor?
2. are you using RoadRunner?
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 06-17-2008, 02:12 PM   #645
pontiac, how about just buy a usb to serial, connect the HD Radio to it
get one of these...
http://www.mouser.com/Search/Refine....0895-UC232R-10
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
PC Card for HD Radio Spotted General MP3Car Discussion 13 09-03-2008 07:01 PM
HD Radio skyhawk2114 StreetDeck 12 06-04-2008 01:17 PM
HD radio in my BMW DAMBRO24 Car Audio 3 11-14-2007 05:19 PM
Someone here has be be able to crack this HDRadio for the car! Kamakazie2 Hardware Development 243 09-20-2007 08:04 PM
HD Radio? peecee Car Audio 3 12-31-2006 02:48 AM
