The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > User Innovations
Thread Tools Search this Thread Display Modes
Old 06-27-2008, 09:41 AM   #676
My Photos: (0)
NO pot inside!
we live in a DIGITAL WORLD DUDE!
mitch
-Thanks
Mitch
www.rush2112.net
mitchjs is offline   Reply With Quote
Sponsored Links
Old 06-27-2008, 09:43 AM   #677
My Photos: (0)
daniel, what guys talking about what XM cable?
i make XMD2 interface, you can buy it right here on mp3carstore!
mitch
-Thanks
Mitch
www.rush2112.net
Old 06-27-2008, 09:44 AM   #678
danielkh's CarPC Specs
danielkh's Avatar
Vehicle: 2004 Nissan 350Z
My Photos: (0)
That's the answer I was looking for. No sound card. Internal ALC883. Ports can be "told" what they are. Line in, mic in, headphones, speaker out. Checked all of them with boost turned off. Still loud. Not a really big issue. Just have to keep it turned down through the control panel.
mitch
I saw the XMD2, but they're talking about the XMD1000.
http://www.mp3car.com/vbulletin/stre...ck-h-help.html
Nissan Carwings Inspired Skin for StreetDeck Here
My opinion is my own.
danielkh is offline   Reply With Quote
Old 06-27-2008, 09:56 AM   #679
My Photos: (0)
under software control, i can and do set the preamp level
BUT it works perfectly here, and i wont change it, till more info is reported
make sure you're using a REAL LINE IN, not a MIC in, if you out of LINE INS
soon that wont be a issue anymore
mitch
-Thanks
Mitch
www.rush2112.net
Old 06-27-2008, 09:59 AM   #680
MySQL Error
Sonicxtacy02's CarPC Specs
Sonicxtacy02's Avatar
Vehicle: 2003/Acura/RSX
My Photos: (130)
mitch
whoa wait .. am i missing something... why wont the lack of line-ins be an issue?
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
HARDWARE PROGRESS: 90%[/////////-]
Current Project: RRFusion, MovieTimes, RRMail, & CentraFusion
Sponsored Links
Old 06-27-2008, 10:01 AM   #681
danielkh's Avatar
My Photos: (0)
mitch
Mitch, this isn't YOUR problem at all! Sorry if it came across that way.
Your cable cannot control the signal strength from the line out of the main unit. That is a line out set level (factory set). Your cable is just a channel controller. No no no no......I wasn't asking you as the "creator" of the problem. Just wondering if you or anyone else had a solution from being familiar with the unit. Right now, I have all audio matched, but the levels in the control panel are set as: Mp3 "max", XM Sat "middle", Visteon HD "minimal". From there, running RR, I can switch between all 3 and get pretty equal levels.
Run out of line-ins. I laugh at the thought......
I can have 4 separate line-ins ONBOARD.
Old 06-27-2008, 10:04 AM   #682
MySQL Error
My Photos: (130)
the "psuedo" solution involves winamps line-in plugin. Set winamps volume lower than u use it with audio (mp3) so that it essentially levels the sound from the HD unit.
03 Acura RSX Coupe
Old 06-27-2008, 10:09 AM   #683
danielkh's Avatar
My Photos: (0)
Again, you guys are looking at this from a software solution (actually, I think you see the same thing I do) and yes, that is how I get around it....however......
Hooking the HD controller up (not the serial cable), then running into line-in, then just unmuting the line-in (no boost, no frontend, no software) and finding a station on the controller, the volume level is way too high, as you state, about 5% to get usable sound. Yes, it can be fixed through software, but I am asking is there a way to drop that level down, either internally to the box, or attenuation between box and PC to have better audio control.
Old 06-27-2008, 10:14 AM   #684
MySQL Error
My Photos: (130)
i know exactly what ur askin and i know as of this moment there's no way. I was simply offering a temporary (and pain in the butt) solution. I wish we could control volume direction from the unit as well.
03 Acura RSX Coupe
Old 06-27-2008, 10:18 AM   #685
danielkh's Avatar
My Photos: (0)
Yeah, I have all of them "evened out" right now and it works fine. But, if I accidentally hit that line in volume on the control panel, I'm going to break some windows along with what's left of my eardrums. Found out the other day that my speakers can handle it, even if I can't.
There has to be some device (probably been around for 20 years) that can be put inline that would attenuate that down without losing fidelity. Think we just have to go "old school" on it.
Old 06-27-2008, 10:33 AM   #686
My Photos: (0)
yea.. a pot wired as a voltage divider
mitch
-Thanks
Mitch
www.rush2112.net
Old 06-27-2008, 10:33 AM   #687
danielkh's Avatar
My Photos: (0)
mitch
I knew a pot would come in there sooner or later. lol
Thanks Mitch.
Old 06-27-2008, 10:34 AM   #688
My Photos: (0)
you know, why the HELL are you using that visteon display anyway!!!
get rid of it, and all your audio problems will go away!
mitch
-Thanks
Mitch
www.rush2112.net
Old 06-27-2008, 10:37 AM   #689
danielkh's Avatar
My Photos: (0)
mitch
no no no no no....I'm not using the display. Just used it to define/explain the issue......that the high gain levels are not software related.
When running, I don't have any audio issues. Everything is evened out and running fine. I would just really like to have all inputs set to mid level in the control panel for greater range abilities.
Old 06-27-2008, 11:58 AM   #690
My Photos: (0)
ur missing my point, I HAVE FULL CONTROL OF THE AUDIO LEVEL OF THE VISTEON!
mitch
-Thanks
Mitch
www.rush2112.net
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
PC Card for HD Radio Spotted General MP3Car Discussion 13 Yesterday 07:01 PM
HD Radio skyhawk2114 StreetDeck 12 06-04-2008 01:17 PM
HD radio in my BMW DAMBRO24 Car Audio 3 11-14-2007 05:19 PM
Someone here has be be able to crack this HDRadio for the car! Kamakazie2 Hardware Development 243 09-20-2007 08:04 PM
HD Radio? peecee Car Audio 3 12-31-2006 02:48 AM
Sponsored Links
Ad Management by RedTyger
