The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > User Innovations
Thread Tools Display Modes
Old 06-27-2008, 12:35 PM   #691
danielkh's CarPC Specs
danielkh's Avatar
Vehicle: 2004 Nissan 350Z
My Photos: (0)
of course you do. so do I. When in RR or anywhere else (front end) I can equalize everything. Same as you. The point I have tried to make is the gain out of the visteon box is too high. Not too high to control, not too high that it can't be equalized EASILY. I was just asking if it is possible to lower the output of the hd unit. Not correct it or compensate for it. To actually lower the gain. The answer is no, and thats fine. I run fine the way it is.
I don't use the stock display. I use roadrunner and your cable. works fine, works great. I used the display only to troubleshoot the high gain. nothing else.
My opinion is my own
My Current Setup is Here
danielkh is offline   Reply With Quote
Sponsored Links
Old 06-27-2008, 12:55 PM   #692
HiJackZX1's CarPC Specs
HiJackZX1's Avatar
Vehicle: 03 Dodge Durango SLT
My Photos: (254)
Let me ask, how are you guys combating the line-in issue. I noticed that if i have XM and HD radio connected, both are very low on volume. If i connect one at a time, they work like they should. I saw this A/V switch that when it senses output from a device it automatically switches to that device. I am hoping that it will keep the quality and not lover it. I am not sure if this will work though because it also has a video port, so Im scared it wont switch with only audio. What can I do to trick it if it turns out I need a video signal for the auto switching?
PLANNING [100%]
CAR PC ITEMS [100%]
INSTALL OF PC [100%]
BUG WORKOUT [75%]
INTERIOR MODS [50%]
BUDGET [380%]
HiJackZX1 Work Log
HiJackZX1 is offline   Reply With Quote
Old 06-27-2008, 12:57 PM   #693
MySQL Error
Sonicxtacy02's CarPC Specs
Sonicxtacy02's Avatar
Vehicle: 2003/Acura/RSX
My Photos: (130)
how are you hooking both xm and hd up to your computer for sound? Any link to the switch u'r talking about?
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
HARDWARE PROGRESS: 90%[/////////-]
SKIN PROGRESS: 90%[/////////-]
Current Project: RRFusion, MovieTimes, RRMail and More!!! :)
Old 06-27-2008, 01:01 PM   #694
My Photos: (0)
EVERYONE STOP!!!
WAIT, in the next day or two I will have a NEW PRODUCT that SOLVES
all your LINE IN SHORTAGES!!! and such
-Thanks
Mitch
www.rush2112.net
mitchjs is offline   Reply With Quote
Old 06-27-2008, 01:02 PM   #695
My Photos: (0)
you know daniel, your ****ing me off
I HAVE 100% control of the AUDIO LEVEL that COMES OUT OF THE HD RADIO BOX
BEFORE IT GETS INTO YOUR PC!!!!!
now which RR u using, MY RELEASE, if NO, get it NOW!
mitch
-Thanks
Mitch
www.rush2112.net
Old 06-27-2008, 01:04 PM   #696
HiJackZX1's Avatar
My Photos: (254)
Right now im using a 3.5mm headphone splitter, but like I said it makes them lower in sound, I am assuming the devices are fighting each other and thats why the output is lowered. http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN:IT&ih=004 this is the one I bought. Its very very cheap. Im hoping that I can just use a cable with RCA only, from the HD and XM to ports on the switch and then use a RCA to 3.5mm cable from the out port to the line-in port on the soundcard. I am so hoping this will stop the loss of volume. If it does work, we now have a cheap solution to connect alot of devices and not have to switch manually, although we have that option on this switch.
PLANNING [100%]
CAR PC ITEMS [100%]
BUG WORKOUT [75%]
INTERIOR MODS [50%]
BUDGET [380%]
HiJackZX1 Work Log
Old 06-27-2008, 01:08 PM   #697
MySQL Error
My Photos: (130)
Quote: Originally Posted by mitchjs View Post
EVERYONE STOP!!!
that sounds absolutely terrific.. cant wait to get my sirius unit into my setup too!
i've heard the splitter route was dangerous and never got the courage to try it.. i'm glad its working for you though.
03 Acura RSX Coupe
Old 06-27-2008, 01:11 PM   #698
Dave323Ci's CarPC Specs
My Photos: (0)
I have a simple splitter too. Seems to work ok. I don't have the sound level issue at all. Using Mitch's latest version of RR so only 1 signal at a time going into splitter,, or I guess it's a joiner in this case. Can't wait for the new USB device
Dave323Ci is offline   Reply With Quote
Old 06-27-2008, 01:26 PM   #699
HiJackZX1's Avatar
My Photos: (254)
Obviously it is dangerous if the volume is being lowered. Thats why i want to use the auto switch instead. Its not working lol!!!!!!!!!
PLANNING [100%]
CAR PC ITEMS [100%]
BUG WORKOUT [75%]
INTERIOR MODS [50%]
BUDGET [380%]
HiJackZX1 Work Log
Old 06-27-2008, 01:28 PM   #700
HiJackZX1's Avatar
My Photos: (254)
EVERYONE STOP!!!
Well if it turns out the switch doesnt work, then i will go for your device.
PLANNING [100%]
CAR PC ITEMS [100%]
BUG WORKOUT [75%]
INTERIOR MODS [50%]
BUDGET [380%]
HiJackZX1 Work Log
Sponsored Links
Old 06-27-2008, 01:35 PM   #701
My Photos: (0)
daniel, what are you talking about, did you make the control for the HD Radio?
AGAIN, I WILL SAY IT AGAIN, I HAVE FULL CONTROL OF THE PREAMP VOLUME LEVEL COMING OUT OF THE VISTEON HDZ300!!!!!!!!!!!!!!!!
also.. i would switch to my version of RR, HD Radio and XM Radio is mucho impro
and where is this turnip truck, you need to find it
do you have source to ur "special" version of RR
if u switch to mine, u will find the AUDIO level of the HD Radio LOWER!!!!!!!!!!!!
mitch
-Thanks
Mitch
www.rush2112.net
Old 06-27-2008, 01:39 PM   #702
danielkh's Avatar
My Photos: (0)
hijackzx1..
what xm setup are you using? I have xm to line in and hd to line in2 and volume isn't effected at all. I have the intel version of the kino board, but i think our audio controllers are different.
Old 06-27-2008, 01:47 PM   #703
HiJackZX1's Avatar
My Photos: (254)
Quote: Originally Posted by danielkh View Post
hijackzx1..
what xm setup are you using? I have xm to line in and hd to line in2 and volume isn't effected at all. I have the intel version of the ki9no board< but i think our audio controllers are different.
Im am using a XMD1000. I am using a Sound Blaster Live USB, and it does not have a second audio in line. Only line-in and mic-in, and mic-in cannot be used if using line-in, its one or the other. I dont use the audio on the KINO, because it so inferior to me. It only has mic-in and audio out. Plus I want to use the mic-in for my mic to control CF.
PLANNING [100%]
CAR PC ITEMS [100%]
BUG WORKOUT [75%]
INTERIOR MODS [50%]
BUDGET [380%]
HiJackZX1 Work Log
Old 06-27-2008, 01:50 PM   #704
danielkh's Avatar
My Photos: (0)
Gotcha. My mobo has 8 ports built in and 4 of them can be line in or mic in. Really don't understand why the AMD versionh didn't do the same.
Old 06-27-2008, 02:42 PM   #705
My Photos: (0)
daniel, you say the AUDIO from the HDRADIO is too HOT for you input on you MB right!!!
USE MY ROADRUNNER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!
its just a .exe and new xmdll and hddll...
read the thread...
mitch
-Thanks
Mitch
www.rush2112.net
Sponsored Links
vB code is On
Trackbacks are Off
HD Radio skyhawk2114 StreetDeck 12 06-04-2008 01:17 PM
PC Card for HD Radio Spotted General MP3Car Discussion 12 06-01-2008 08:23 PM
HD radio in my BMW DAMBRO24 Car Audio 3 11-14-2007 05:19 PM
Someone here has be be able to crack this HDRadio for the car! Kamakazie2 Hardware Development 243 09-20-2007 08:04 PM
HD Radio? peecee Car Audio 3 12-31-2006 02:48 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
