Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > User Innovations
Old 06-29-2008, 11:08 AM   #751
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
Quote: Originally Posted by danielkh View Post
Is this for #4?
yes it is sorry lol
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 06-29-2008, 11:14 AM   #752
SD beats everything. So there.
danielkh's Avatar
danielkh is an unknown quantity at this point
Quote: Originally Posted by Sonicxtacy02 View Post
yes it is sorry lol
It's wierd, done it on 2 separate computers.....
Go through following mitch's instructions, all goes well, then I go into the hd and xm folders and there is some more .bat files, so I run them. XM does fine, but the register.bat on HD gives that error on both computers.
I just manually checked the registry and it is registered. Guessing it's done in another step and then can't redo it.
My opinion is my own.
danielkh is offline   Reply With Quote
Old 06-29-2008, 04:00 PM   #753
Raw Wave
mitchjs is on a distinguished road
danielkh, dont reinstall .net 2.0!!!!
in the hdradio directory
is a runme1st.cmd
runme1st.cmd
will register the hdradio object
i have NO IDEA what "register.bat" is/does, its not mine
mitch
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline   Reply With Quote
Old 06-29-2008, 05:01 PM   #754
Raw Wave
pontiac... NO of course not, your 2ch/4ch thing is inside ur pc
you know on my OS / audio system... 2 channel LINE in, plays on all 4 speakers
via the PLAYBACK MIXER (VISTA,realtek 880)
see technically MUSIC is 2channel, (not talking about 5.1)
and there is NO such thing as rear speakers
but some people got it in their head they need music coming from the rear in a car
(you know it generally screws up the imaging of the music) but most people
arnt aware, or really understand...
what audio system are you using?
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 06-29-2008, 08:00 PM   #755
danielkh's Avatar
is a runme1st.cmd
runme1st.cmd
mitch
I didn't and everything worked great on the first roadtrip. Heck, stuff that has never worked before now works (gps weather, zipcode updating). I might just become a full time roadrunner convert yet!
Since your stuff is working great, I'm going to head over to the digital fx thread for other issues. Thanks a lot, sorry for the confusion, and as I said to begin with, great product!
Old 06-29-2008, 08:48 PM   #756
PontiacGA's Avatar
PontiacGA is on a distinguished road
mitch
I'm just saying the HD radio sounds like crap coming out of just the front speakers. When it's locked on an HD station, the tweeters get real loud. It would sound much better with sound also coming from the back. MP3's sound much much much better because of this.
I'm running a SB Audigy SE tied into my factory amp.
Mike
My Rides:
'03 Vibe GT!
My AED GA!
PontiacGA is offline   Reply With Quote
Old 06-29-2008, 09:11 PM   #757
Raw Wave
i dont know too much about the SB Audigy SE, but my guess it only supports a "virtual" surround and wont copy the audio from front to back speakers, but u can always use "AudioRepeater"
part of virtural audio cable
sounds like you dont got balance in your system, if HD Radio sounds like crap
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 07-01-2008, 09:37 AM   #758
PontiacGA's Avatar
mitch
Nope. AudioRepeater does the same thing Winamp does.....makes an echo.
Does anyone know a reasonably priced soundcard that will play the line-in on all speakers?? It's ashame when ya spend all this money on a CarPC and a $20 radio sounds better than an HD radio.
Mike
My Rides:
'03 Vibe GT!
My AED GA!
Old 07-01-2008, 09:54 AM   #759
pcpete's Avatar
pcpete is on a distinguished road
I'm using an muadio firewire 410, it has 8 outputs, no problems here, have tested audiorepeater and winamp line in plugin.
Probably not what you would consider reasonably priced, cost me $200 used from kijiji...
pcpete is offline   Reply With Quote
Old 07-01-2008, 09:59 AM   #760
danielkh's Avatar
I had no problem with SB Live external 24 and XM line in. They're pretty cheap. Not sure how it would do on HD, but should be the same.
Since then I decided to go with built in and got the kino-9452 motherboard (realtek ALC883 7.1). No issues on any line-ins and full control down to the individual speakers.
Old 07-01-2008, 11:26 AM   #761
Raw Wave
pontiac, no it doesnt "AudioRepeater" does not create echo!!!
you need to understand how audio in windows(OS) works! (or kinda)
put away RR for the moment...
a windows audio system (not talking vista, but vista is close(actually better) then XP)
there are inputs and outputs, lets call them PINS
you got playback pins, and record pins
a playback pin, will let you listen to a audio input LIVE, never being processed by the CPU of the PC
so.. if you got say a LINE IN, and you go to the playback section of the mixer, and unmute its PIN, you will hear what comes in on that line in...
NOW in your case, MUTE ALL the PLAYBACK input PINS... LINE IN, CD, AUX, what ever they are, they vary from sound card to sound card...
this is done in the windows mixer
now go to the record section of the mixer... there are PINS there
select only the LINE IN PIN, when you activate it you wont hear anything...
now use "Audiorepeater", in the IN, select the LINE IN (PIN)
and the out, wav mapper is fine... or direct to speakers
set up u speaker config you want quad... and click start...
at this point, if u got audio playing on you line in... you will hear the audio
on all 4 speakers, NO ECHO!
now RR, is limited on how it manages audio... basicly you do NOT want to use "linein" method
cause they are on the PLAYBACK PIN side of the mixer
for instance.. radioline=0, xmline=0, so fourth...
and u want all your PLAYBACK input PINS Muted
then you need RR to use "audio repeater" (since it take cmd line)
to do your audio
OR winamp LINE IN plug in, with a line out plug in, would do..
as long as winamp line in plug in, uses the RECORDING PINS, and doesnt touch playback PINS
if you need one on one help... id be happy to help you via email or better yet IM
I started a conceptuall audio management system while back... but since like you guys already know, i dont USE RR, i never finished it... but i use it alot since my machine has multiple sounds cards/usb devices, and i can play back audio from any device to the speakers on the onboard device
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 07-01-2008, 02:23 PM   #762
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
Is this for #4?
AMPCTRL is for pin #4. The other software VOLUME_AMP_CONTROL (I think its called) uses pin #4 also. Daniel how is AMPCTRL working for you? I am having a issue were it takes almost one minute to turn on the amps, and after a few hibernations i get no sound. Im thinking of ditching AMPCTRL and using the VOLUME_AMP one.
Also, Mitch, I like your USB, line device thingy... looks very small. I did get the Auto A/V switch and it hugeeeeeeeeeeeeeee. So it would be awsome to use yours. Can i be a beta tester?
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 07-01-2008, 02:57 PM   #763
danielkh's Avatar
I only have a few days testing under my belt, and so far, it works fine (ampctrl). Remind me in a week or so or if I have problems I'll let you know. By the time rr is running, I have amps.
Old 07-01-2008, 05:59 PM   #764
HiJackZX1's Avatar
Cool, i'll be waiting, although Im going to uninstall it and try the other.
Also I got the A/V switch thing in. Its pretty cool. I tested it on my PS2 and XBOX 360. First I turned on my PS2 and it automatically switched to Port 2. I then turned on the 360 and it switched to that item. I then turned off the 360 and it went back to PS2. I read somewhere that the XM stays on all the time with CF, but I know the HD radio shuts off because I hear it click off. So this is perfect, but like I said the size of the unit is cr@ppy
PS: nevermind, it doesnt work with only audio, you have to have a video feed for auto switch... so looks like Mitches device is the best way to go.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 07-01-2008, 06:04 PM   #765
danielkh's Avatar
Also I got the A/V switch thing in. Its pretty cool. I tested it on my PS2 and XBOX 360. First I turned on my PS2 and it automatically switched to Port 2. I then turned on the 360 and it switched to that item. I then turned off the 360 and it went back to PS2. I read somewhere that the XM stays on all the time with CF, but I know the HD radio shuts off because I hear it click off. So this is perfect, but like I said the size of the unit is cr@ppy.
You know, I wonder if the fact that I am using everything onboard now (especially sound), if it will have a problem. MoBo seems really REALLY smart. Probably the best motherboard I have ever owned. And that's saying a lot when the first computer I ever built was a 286 (and could double as a coffee table).
PC Card for HD Radio Spotted General MP3Car Discussion 13 09-03-2008 08:01 PM
HD Radio skyhawk2114 StreetDeck 12 06-04-2008 02:17 PM
HD radio in my BMW DAMBRO24 Car Audio 3 11-14-2007 06:19 PM
Someone here has be be able to crack this HDRadio for the car! Kamakazie2 Hardware Development 243 09-20-2007 09:04 PM
HD Radio? peecee Car Audio 3 12-31-2006 03:48 AM
