Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > User Innovations
Old 07-18-2008, 10:19 AM   #826
yea, ur right, might as well keep the antenna up
not to mention, cars dont come with moving antennas anymore
they fixed/electronic
which is a whole nother issue
mitch
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline   Reply With Quote
Old 07-22-2008, 12:42 AM   #827
utd09bry's Avatar
hi all,
so i decided to tackle my interference issues again after having given up for a while.
testing, playing, testing, playing, and finally a solution (though, one that has been done before).
i finally went to the extreme and removed the power supply (m2-atx) from the case which i had sitting open-faced under my back bench seats. put the power supply in its own metal box (an aluminum project box found at the local parts shop), and BAM. no more interference.
anyone trying to chase down noise... just know that i can add my name to the list of people who solved theirs by sealing up their s***. it really does work!
just a note for all
peace, love, and hdradio
utd09bry is offline   Reply With Quote
Old 07-22-2008, 08:36 AM   #828
PontiacGA's Avatar
Now that I have everything basically set up the way I want and MOST problems ironed out, now to tackle the small problems.
Reception. I have the Visteon HDZ300 plugged into my factory antenna and the reception is no where near as good as my factory or my Alpine HU was. Any ideas?
Also, I was thinking of trying this http://www.crutchfield.com/S-eOVvK9o...px?i=12044UA60 . Will this help at all?
Mike
My Rides:
'03 Vibe GT!
My AED GA!
PontiacGA is offline   Reply With Quote
Old 07-22-2008, 08:40 AM   #829
SD beats everything. So there.
danielkh's Avatar
With the head unit removed (?), if you have a powered antenna, make sure it is getting voltage. If the head unit powered it, it won't (blue wire). I thought I had broken my antenna. When I found that, the Visteon blew the factory HU out of the water on reception.
Nissan Carwings Inspired Skin for StreetDeck Here
My opinion is my own.
danielkh is offline   Reply With Quote
Old 07-22-2008, 09:08 AM   #830
NO SIGNAL AMPLIFIERS, they waste of money!
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 07-22-2008, 11:15 AM   #831
PontiacGA's Avatar
Nope. No power antenna. It's a little stubby one on the roof.
Mike
My Rides:
'03 Vibe GT!
My AED GA!
Old 07-22-2008, 11:56 AM   #832
danielkh's Avatar
My bad. Power as in amplified internally (newer ones are). Not powered as in up and down.
Old 07-22-2008, 01:04 PM   #833
PONTIAC, you need to power that up, and hope... and if reception is still bad... id prob put back in the factory radio and sell the car
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 07-22-2008, 01:55 PM   #834
danielkh's Avatar
Mitch, I finally had time to work on the XM. Not sure if you remember, but I mentioned having engine noise (ground loop). Just to get this out and posted for the masses, I used this cheapy and it worked beautifully. I totally forgot how good Watercolors (XM Channel 71) could sound....
http://www.radioshack.com/product/in...entPage=search
Old 07-22-2008, 10:02 PM   #835
utd09bry's Avatar
is the bad reception the hdradio period or is it being run in conjunction with your pc?
my stock and aftermarket radios worked fine. hdradio by itself worked fine... but once you used the radio with the pc it would DIE. as recently stated, sealing my pc components (and i really do mean pretty dang tight) fixed the RFI noise that was being generated. in my case, it was the M2-ATX power supply causing RFI
Old 07-23-2008, 11:39 AM   #836
HiJackZX1's Avatar
You dont have any muffled sound with the RadioShack version? I bought mine from Best Buy, its called a InstallEdge Ground Loop Isolator. This one promises 100% clarity, and a 3db gain. i think its 1 dollar more then the one you pointed to.
PLANNING [100%]
CAR PC ITEMS [100%]
INSTALL OF PC [100%]
BUG WORKOUT [75%]
INTERIOR MODS [50%]
BUDGET [380%]
HiJackZX1 Work Log
HiJackZX1 is offline   Reply With Quote
Old 07-23-2008, 11:41 AM   #837
danielkh's Avatar
Crystal clear. Sounds like the mp3's now. But keep in mind I am deaf in one ear and can't hear out of the other.
But no, no muffling. I was listening to jazz (watercolors) and if anything would show muffling, that would.
Old 07-23-2008, 12:22 PM   #838
HiJackZX1's Avatar
LOL, I am also deaf (not 100%), all I hear is certain frequencies and this horrible ringing 24/7.
PLANNING [100%]
CAR PC ITEMS [100%]
BUG WORKOUT [75%]
INTERIOR MODS [50%]
BUDGET [380%]
HiJackZX1 Work Log
Old 07-23-2008, 03:29 PM   #839
What?
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 07-23-2008, 03:56 PM   #840
PontiacGA's Avatar
Think you're on to something. I had to put an adapter cable on the ant. cable. I moved the connector behind an aluminium shield and the radio came in clearer. So, I'm gonna work on shielding the connector better. Thanks for the tip.
Mike
My Rides:
'03 Vibe GT!
My AED GA!
PC Card for HD Radio Spotted General MP3Car Discussion 13 09-03-2008 07:01 PM
HD Radio skyhawk2114 StreetDeck 12 06-04-2008 01:17 PM
HD radio in my BMW DAMBRO24 Car Audio 3 11-14-2007 05:19 PM
Someone here has be be able to crack this HDRadio for the car! Kamakazie2 Hardware Development 243 09-20-2007 08:04 PM
HD Radio? peecee Car Audio 3 12-31-2006 02:48 AM
