The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > User Innovations
Thread Tools Search this Thread Display Modes
Old 07-23-2008, 09:30 PM   #841
utd09bry's CarPC Specs
utd09bry's Avatar
Vehicle: 2002 Ford Explorer
My Photos: (15)
just another tip... if you are experiencing interference (which remember, PC's are notorious for RFI/EMI), you will have a much better result by sealing the source than trying to filter or hide the object that is receiving the interference.
in my case, i tried many things to isolate my antenna cables and radio box... but nothing really worked. i technically got it to sound ::better:: but not great. it wasn't until i sealed up my pc components that i eliminated the problem (at the source). definitely give that a try if you happen to have your computer parts unshielded.
utd09bry is offline   Reply With Quote
Sponsored Links
Old 07-26-2008, 10:27 PM   #842
My Photos: (1)
Ok... I downloaded your RR files and followed directions. Ran the register file in main RR folder then went into HD radio. It would not register HDradiocom.dll or something like that. I tried this on both systems. The radio works but RR is now all messed up.
When I try to register the batch file labeled "Register" it says this
"HDRadioComm.dll was loaded, but the Dll Register server entry point not found" "This File cannot be registered"
Now my radio isn't working at all in RR. Works on the PCR still.
Dougw133 is online now Report Post Edit/Delete Message Reply With Quote
Alright I realized I am in the worng thread but if anyone knows of any fixer here please let me know?
Dougw133 is offline   Reply With Quote
Old 07-26-2008, 11:37 PM   #843
My Photos: (0)
what batch file "register"? who the hell is com registering my dll!
define "downloaded your RR files" and where are you getting these
i could assume some, but youre for sure in wrong thread, but thats ok, ill prod you a bit
if your using my special RR build...
try, "MJSG-RR-RunMe1st.cmd"
if youre not, look in the HDRadio Directory... "runme1st.cmd"
mitch
-Thanks
Mitch
www.rush2112.net
mitchjs is offline   Reply With Quote
Old 07-27-2008, 02:19 PM   #844
My Photos: (1)
Yeah I am I realized that.. Sorry
Old 07-27-2008, 02:29 PM   #845
PontiacGA's CarPC Specs
PontiacGA's Avatar
Vehicle: 2003 Pontiac Vibe GT/93 Pontiac Grand Am
My Photos: (0)
Would getting a small plastic case from radioshack and sticking the PSU in it help at all? Or does it have to be metal?
Mike
My Rides:
'03 Vibe GT!
My AED GA!
PontiacGA is offline   Reply With Quote
Old 07-27-2008, 03:32 PM   #846
My Photos: (0)
yea metal, and grounded
you might not be able to eliminate it, which is then time to get rid of it
maybe a different ps
switching supplies always make RFI, its unavoidable... but some are just sloppy, and make tons of noise
mitch
-Thanks
Mitch
www.rush2112.net
Old 07-28-2008, 03:44 PM   #847
My Photos: (0)
hmm i seem to be having an issue where on the initial start of the HDradio program (both in RR and standalone, where the output of the visteon is EXTREMELY loud, making my clipping indicatiors of my sound card go on and of course the sound is distorted...
however, after switching to another station, the volume returns to normal and the stations come in clear. does anyone else have this problem?
Carputer HIFI car stereo project!
[XXXXXXXXXXXXXXXXXXXXX-]
95% COMPLETE! FINALIZING SOFTWARE PLATFORM!
[XXXXXX--------------]
30% COMPLETE! CAPUTER Version 2.0! Hardware FAILING! CARPUTER BLEW UP! AND NOW MONITOR TOO! WTF?!
miztahsparklez is offline   Reply With Quote
Old 07-28-2008, 05:40 PM   #848
My Photos: (0)
NO problem here, try the audio mod
are u using MY BUILD of RR?
look for it, basicly gnd the rcas
mitch
-Thanks
Mitch
www.rush2112.net
Old 07-29-2008, 01:52 AM   #849
My Photos: (0)
mitch
which is your version? im using the newest stable RR release (before the weather fix) with the newest version of the LSX skin. This not only happens in RR but also your HDR program. The gain on the outputs are set way high distorting the sound during initial power on. But, after you change stations, it goes back to proper levels and there is no issue. It seems like when it first initializes theres something that makes it too loud then corrects it after a command is sent to it.
The same thing happens both on my bench setup and in the car. On my bench setup i tried doing the grounding thing (it wasnt distorting at the time either) with no change in sound.
Old 07-29-2008, 09:04 AM   #850
My Photos: (0)
dont know then.... u are using the latest HDRadio PCR right?(not that any new one came out in a long time) but be sure
but my build of RR, does set HD Radio volume at the right level
mitch
-Thanks
Mitch
www.rush2112.net
Sponsored Links
Old 07-29-2008, 12:43 PM   #851
My Photos: (0)
mitch
right.. but when you initially turn on the HD radio, are there any commands that set volume on startup? It seems strange that it fixes itself after selecting a new station after the initial power on.
Other than that, it seems that everything works most of the time.. there have been a few occurrances where the radio gets locked onto the current station and wont change stations. Usually, restarting the radio app restores functionality. Not sure if this is a related issue or not. Perhaps somewhere in the connection bad data is being sent?
Also, I am using the files from your website that I downloaded within the last week or so.
Old 07-29-2008, 01:23 PM   #852
My Photos: (0)
maybe u got a tuner issue
sounds like it....
as you can see no one else chimed in, 1 they too lazy 2 your it with this problem
yes. volume is set before any thing is tuned...
the offical RR sets it way too high
mitch
-Thanks
Mitch
www.rush2112.net
Old 07-30-2008, 08:11 AM   #853
PontiacGA's Avatar
My Photos: (0)
I actually had the 'issue' with the volume being loud when the HD first turned on. But, I installed Mitch's version of RR, and it fixed it.
BTW Mitch, is the new RR version of yours gonna fix the problem with DFX 4.0 and not showing the logo/clock?
Mike
My Rides:
'03 Vibe GT!
My AED GA!
Old 07-30-2008, 11:52 AM   #854
My Photos: (0)
pontiacGA, prob not, since I DONT KNOW ANYTHING ABOUT DFX4
and how logos/clocks work
ive said this before, i know little to nothing about RR
johnwpb knows more, he could prob shead some light
there is room for others
mitch
-Thanks
Mitch
www.rush2112.net
Old 07-30-2008, 11:50 PM   #855
PontiacGA's Avatar
My Photos: (0)
mitch
Bummer.
Mike
My Rides:
'03 Vibe GT!
My AED GA!
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
PC Card for HD Radio Spotted General MP3Car Discussion 13 Yesterday 07:01 PM
HD Radio skyhawk2114 StreetDeck 12 06-04-2008 01:17 PM
HD radio in my BMW DAMBRO24 Car Audio 3 11-14-2007 05:19 PM
Someone here has be be able to crack this HDRadio for the car! Kamakazie2 Hardware Development 243 09-20-2007 08:04 PM
HD Radio? peecee Car Audio 3 12-31-2006 02:48 AM
Sponsored Links
Ad Management by RedTyger
