Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > User Innovations
Old 10-04-2009, 02:51 PM   #1156
Ces///M3
I've read some threads where users had issues getting the hd radio module to work while using a usb dac....As someone that got in on the hippo group buy here some time ago I had to come up with a solution to keeping the DAC as the main output device. What I did was use audiorepeater, (a sub applet of Virtual Audio Cable) and the line in on my motherboard. Audiorepeater supports command line batch entry to the point where routing the line in of the motherboard to the dac is working perfectly 'behind the scenes' I have it setup to run the batch file off my skin's radio button in roadrunner. Switching to any other media source kills the audiorepeater executable making for completely seemless integration. If anyone needs help getting it setup, post up or PM me. Thanks again Mitch for your continued work on this as well as RR!
Ces///M3 is offline   Reply With Quote
Old 10-19-2009, 11:35 AM   #1157
Raw Wave
tbird2340's Avatar
tbird2340 is on a distinguished road
Anyone here ever have any problems using the cheap USB to SERIAL dongles on fleabay? I just bought a DMHD1000 and I'm about to buy the cable but don't want to spend the $25 for the FTDI cables if the cheapo ones work OK.
Thanks!
Wife's Vehicle: 2007 Dodge Nitro
Current Vehicle: 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
tbird2340 is offline   Reply With Quote
Old 10-19-2009, 11:50 AM   #1158
roflcopter's Avatar
roflcopter is an unknown quantity at this point
you're probably best off just paying the 25 for the FTDI when you know it works rather than $10 for one that doesn't and another $25 for the one you knew worked in the first place. 25<35
just a thought.
2007 Saab 9-3ss 2.0T
Jetway J7F5M1g5d-VHE-LF, 32gb patriot SSD, 160gb WD hdd, nLite XP sp3, EWF/Horm, RideRunner
Current Progress:
PC
HARDWARE [100%] SOFTWARE [95%] FABRICATION [100%] INSTALL [75%]
Workblog
roflcopter is offline   Reply With Quote
Old 10-19-2009, 11:53 AM   #1159
Raw Wave
tbird2340's Avatar
just a thought.
If people post and say they have problems with them, then yea.. But there is a big difference between $3 and $25 when you are on a tight budget..
Now, if I just had to get that cable, then yea, no problem.. But $55 for the DMHD1000, $25 for the serial cable and then the cost of the USB to Serial adds up..
Old 10-19-2009, 12:02 PM   #1160
Raw Wave
mitchjs is on a distinguished road
I CANNOT STRESS IT
dont buy the cheapies.. some dont implement RTS and DTR
which is needed!
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline   Reply With Quote
Old 10-19-2009, 12:04 PM   #1161
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
Your Mobo doesnt have more then one serial port? There has to be some headers on it?
Just remember this.... when you budget your carpc, you have to leave leeway money, because if I still payed attention to my original budget, lol, I don't think id have an install going. Because this has become a hardcore hobby for me, I turn a blind eye to the budget. I heard of people using the cheapy cable and frying the HD unit. Mitch's cable has a special chip inside of it that properly does what its supposed to do.
PS: Is it me Mitch, or is everyone trying to be cheap on your products?
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 10-19-2009, 01:05 PM   #1162
Raw Wave
tbird2340's Avatar
No, it just has one serial port and no headers.. This is for my truck, not my wife's car, so I'm just adding on to an already completed install.. But, when I just spent over $750 building hers (and still have another $250 minimum to finish) I want to save money anywhere I can..
I'm not trying to be "cheap" I'm trying to spend the least amount of money possible to have a working solution..
If Mitch says to not go the cheap route, then I won't.. That is why I asked.. If 100 people posted and said "Yea, I got the $3 cable and have had zero issues." and no one said they had issues then it would be stupid to spend $25..
I think I'll hook Mitch's cable to my serial port and use the cheapo USB to SERIAL adapter for my serial IR receiver (to use with Girder).
Old 10-26-2009, 03:54 PM   #1163
hollow is an unknown quantity at this point
does the visteon support RDS in the uk ???
hollow is offline   Reply With Quote
Old 10-26-2009, 04:15 PM   #1164
Raw Wave
yes, basic rds is supported
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 10-26-2009, 04:31 PM   #1165
nrgizerbunny is an unknown quantity at this point
yes it does, i'm in the uk and confirm it does.
nrgizerbunny is offline   Reply With Quote
Old 10-28-2009, 03:26 AM   #1166
vijainair is an unknown quantity at this point
good god, have mercy. I spent the last two hours or so reading up on all 1165+ posts on this thread to understand how to set up my HD Radio unit properly (so I don't have to do trial and error).
Mitch, I have a suggestion: update your first post with all relevant information about your cable and the HD radio tuners. You have to repeat yourself every other time (which could've saved you, me and everyone else time because everybody's so lazy to read up 2+ years worth of old posts )
A lot of common topics (excluding RR, since I'm using CF) that I came across as important are: power wiring, grounding mod, glass antenna, RFI/EMI, USB-Serial cable, line-in vs mic-in, hibernation, com ports, etc.
but lesson learned: don't mess with the mitch
keep up the awesome work!
Thanks!
-VJ
vijainair is offline   Reply With Quote
Old 11-07-2009, 01:07 AM   #1167
Raw Wave
yea... i should...
so much work...so little time...
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 11-11-2009, 01:52 PM   #1168
Raw Wave
tbird2340's Avatar
My radio just stopped working out of the blue.. It was working great for about 2 days and then, nothing..
I downloaded your HDRadio program and I'm trying it now.. It doesn't find anything when it does an auto search but when I tell it my comport and click on retry I hear the HD radio click on but then click right back off and then it says radio not found..
Any ideas?
Old 11-11-2009, 02:10 PM   #1169
Raw Wave
try another pc
try the ugly lcd that came with it
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 11-11-2009, 02:22 PM   #1170
Raw Wave
tbird2340's Avatar
Another PC isn't really possible as the cable is ran under the carpet and would be a total PITA to get the cable out..
I did try the LCD and while I didn't have sound (guessing because of the way it's hooked up) I was able to scan stations on it and it was showing station / song info correctly.
PC Card for HD Radio Spotted General MP3Car Discussion 13 09-03-2008 08:01 PM
HD Radio skyhawk2114 StreetDeck 12 06-04-2008 02:17 PM
HD radio in my BMW DAMBRO24 Car Audio 3 11-14-2007 06:19 PM
Someone here has be be able to crack this HDRadio for the car! Kamakazie2 Hardware Development 243 09-20-2007 09:04 PM
HD Radio? peecee Car Audio 3 12-31-2006 03:48 AM
