07-18-2008, 10:19 AM
#826
yea, ur right, might as well keep the antenna up
not to mention, cars dont come with moving antennas anymore
they fixed/electronic
which is a whole nother issue
mitch
07-22-2008, 12:42 AM
#827
Vehicle: 2002 Ford Explorer
hi all,
so i decided to tackle my interference issues again after having given up for a while.
testing, playing, testing, playing, and finally a solution (though, one that has been done before).
i finally went to the extreme and removed the power supply (m2-atx) from the case which i had sitting open-faced under my back bench seats. put the power supply in its own metal box (an aluminum project box found at the local parts shop), and BAM. no more interference.
anyone trying to chase down noise... just know that i can add my name to the list of people who solved theirs by sealing up their s***. it really does work!
just a note for all
peace, love, and hdradio
07-22-2008, 08:36 AM
#828
Vehicle: 2003 Pontiac Vibe GT/93 Pontiac Grand Am
Now that I have everything basically set up the way I want and MOST problems ironed out, now to tackle the small problems.
Reception. I have the Visteon HDZ300 plugged into my factory antenna and the reception is no where near as good as my factory or my Alpine HU was. Any ideas?
Also, I was thinking of trying this http://www.crutchfield.com/S-eOVvK9o...px?i=12044UA60 . Will this help at all?
07-22-2008, 08:40 AM
#829
Vehicle: 2004 Nissan 350Z
With the head unit removed (?), if you have a powered antenna, make sure it is getting voltage. If the head unit powered it, it won't (blue wire). I thought I had broken my antenna. When I found that, the Visteon blew the factory HU out of the water on reception.
My opinion is my own
My Current Setup is Here
07-22-2008, 09:08 AM
#830
NO SIGNAL AMPLIFIERS, they waste of money!
mitch
07-22-2008, 11:15 AM
#831
Nope. No power antenna. It's a little stubby one on the roof.
07-22-2008, 11:56 AM
#832
My bad. Power as in amplified internally (newer ones are). Not powered as in up and down.
07-22-2008, 01:04 PM
#833
PONTIAC, you need to power that up, and hope... and if reception is still bad... id prob put back in the factory radio and sell the car
mitch
07-22-2008, 01:55 PM
#834
Mitch, I finally had time to work on the XM. Not sure if you remember, but I mentioned having engine noise (ground loop). Just to get this out and posted for the masses, I used this cheapy and it worked beautifully. I totally forgot how good Watercolors (XM Channel 71) could sound....
http://www.radioshack.com/product/in...entPage=search
07-22-2008, 10:02 PM
#835
is the bad reception the hdradio period or is it being run in conjunction with your pc?
my stock and aftermarket radios worked fine. hdradio by itself worked fine... but once you used the radio with the pc it would DIE. as recently stated, sealing my pc components (and i really do mean pretty dang tight) fixed the RFI noise that was being generated. in my case, it was the M2-ATX power supply causing RFI
07-23-2008, 11:39 AM
#836
Vehicle: 03 Dodge Durango SLT
You dont have any muffled sound with the RadioShack version? I bought mine from Best Buy, its called a InstallEdge Ground Loop Isolator. This one promises 100% clarity, and a 3db gain. i think its 1 dollar more then the one you pointed to.
PLANNING [ 100%]
CAR PC ITEMS [ 100%]
INSTALL OF PC [ 100%]
BUG WORKOUT [ 75%]
INTERIOR MODS [ 50%]
BUDGET [ 380%]
HiJackZX1 Work Log
07-23-2008, 11:41 AM
#837
Crystal clear. Sounds like the mp3's now. But keep in mind I am deaf in one ear and can't hear out of the other.
But no, no muffling. I was listening to jazz (watercolors) and if anything would show muffling, that would.
07-23-2008, 12:22 PM
#838
LOL, I am also deaf (not 100%), all I hear is certain frequencies and this horrible ringing 24/7.
PLANNING [ 100%]
BUG WORKOUT [ 75%]
BUDGET [ 380%]
HiJackZX1 Work Log
07-23-2008, 03:29 PM
#839
What?
07-23-2008, 03:56 PM
#840
Think you're on to something. I had to put an adapter cable on the ant. cable. I moved the connector behind an aluminium shield and the radio came in clearer. So, I'm gonna work on shielding the connector better. Thanks for the tip.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
