Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > User Innovations
Old 06-17-2009, 06:13 PM   #196
sillybilly is an unknown quantity at this point
Alex,
the task is obvious. Decode the proto (I'm 96% sure now it's NOT regular serial port, otherwise it must have been cracked already), buy a PIC evaluation board, and then write the firmware and windoze/linux/mac drivers. Then test, and then place the order in China. This will require ....ahem, some investment and time.
Will post here once I find out, is this "bus" uni- or bi-directional at least. If the latter, I have no chance: the navi unit I could grab the conversation from, costs beyond my budget.
sillybilly is offline   Reply With Quote
Old 06-18-2009, 10:06 AM   #197
OPERATOR is an unknown quantity at this point
i think this must be a unidirect think, because the navi told the monitor to go away from navi screen and this can take from 1-20 secounds. so this command will not be analysed by the monitor, i think this will be a command via AiNet and the navi computer is a little bit slow.
this problem exists since the first monitors from alpine with navigation input.
the monitor told the navigation computer only the klick position, not more and not les. if you take a look to the iR LED it flashes everytime you klick on the screen. people told me that this is only a Infrared signal that the monitor transfer in the same protocol like the RemoteControl do, to the navigation computer.
if this is correct, i don't know.
OPERATOR is offline   Reply With Quote
Old 06-18-2009, 11:48 AM   #198
Hi back.
I don't see the IR led blinking since W505r does not have an IR led. Nothing I see on the remote output as well.
I see some millivolts signal down +12v on the Screen Control pin when the screen is touched, regardless of the input - either Nav, Radio or iPod. That must not be correct, unless there is some other signal. You say navi tells the monitor to close the screen? How? Is it connected to the display with MORE than one connector?
Thanks.
Old 06-18-2009, 03:24 PM   #199
Hi,
thats correct, on my old 200 monitor i have this IR LED and this is blinking every time i touch the screen on every position.
i hope you find a way to get the touched position. on another thread there is anything about the AiNet, i hope this can help a little bit.
http://www.mp3car.com/vbulletin/car-...rc-solved.html
did you find on this topic anything usefull?
kind regards
Old 06-18-2009, 04:24 PM   #200
Yes, I've read this. AiNet has nothing common with the RGB jack, sorry... It may transfer commands received via GUI of the head unit, but this doesn't relate to navi.
I've found the pin, and I've found the signal which MUST be TTL or CMOS level - but it isn't. Maybe I should activate the screen interface with some command, dunno. Somebody lend me a PMD200 with the dock?! Pleeeze...
Old 06-29-2009, 03:56 PM   #201
Guys, I need your help.
Anyone with a navi unit connected to the RGB socket on the head unit or the monitor?
Could you please make some measurements for me? I don't have (and can't afford) a navi.
Old 06-30-2009, 10:02 AM   #202
Another question.
I've just put together the VGA interface for this screen. Looks..... bad. Due to interlaced sync (15,75kHz horiz, 25Hz vert) the picture is twitching quite a bit, like on an old TV. Cannot make it work on 31,5kHz progressive, I think it's not designed for progressive scan.
Ideas?
Old 07-12-2009, 02:53 AM   #203
i think there must a way, because the blackbird and the new flash naviation system use a progressiv signal in full resolution of the screen.
i think the best way is to check the signal of the blackbird interface to find the correct way.
Old 07-12-2009, 04:24 AM   #204
Lend me a blackbird? Then I could dig out not only the screen params but also the touch signal as well.
The prob is that I'm located in Russia: we could get broke on postage.
Old 07-12-2009, 04:39 AM   #205
i ask for you on the alpine support website for this documentations. i hope we got a positiv message back.
Old 07-12-2009, 04:47 AM   #206
Well, they never share this kind of info officially, otherwise i'd have this unit selling already. But if you succeed, the first box is yours! of course, for free.
Old 07-12-2009, 04:52 AM   #207
If they say you must sign a NDA this will be ok allready and it will save a lot of time. but let's see what they writing back, if we don't get a awnser i will contact the support direcly over the german internal support board. i have a friend that working for alpine technical in another contry and had access to the technical support board.
Old 07-12-2009, 03:39 PM   #208
That'd be great, waiting eagerly.
I do know now how to make 800x480 progressive, but a regular VGA can't do that. Need a frame buffer for it, and quite a circuit.
The question is. Dear friends, how much would you pay for a VGA/USB interface to Alpine head units, without getting too greedy?
Old 07-12-2009, 03:58 PM   #209
Thats a good question, i think between 50 and 150 euro its a price range thats possible. my personal limit is 100 euro for this interface, but if you have the circle and the rest around, you can make it via china or taiwan for a small price.
Old 08-05-2009, 08:33 AM   #210
FLX
FLX is on a distinguished road
Sillybilly, if you can create a vga input and usb usage of the buttons for the IVA-W502 i would pay you 250 euros
If you can get the buttons correctly connected via usb i can write an application that will change the raw codes to a keyboard shortcut of choice.
Dennis
FLX is offline   Reply With Quote
Alpine more mods RR Skins 302 04-10-2008 06:34 AM
can a carputer replace a high end av dedicated system? turbocad6 Car Audio 85 07-09-2007 05:44 AM
Head Unit w/ Touch Screen, interface w/ Car Puter Karterius LCD/Display 0 05-21-2007 05:19 PM
Non-VGA screen to VGA xxMIKExx LCD/Display 13 04-10-2007 10:18 PM
Alpine amp interface omega_5 General MP3Car Discussion 2 01-02-2007 04:41 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
