Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > User Innovations
Old 01-31-2007, 05:53 PM   #136
W3bMa5t3r's Avatar
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
W3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of light
Quote: Originally Posted by RyanB95 View Post
Just ordered mine late last night - Paypal sent.
Possibly have it by Friday?
I'll be shipping it out tonight. All shipments are Priority mail, so 2-3 days is usual
Cheers.
W3bMa5t3r is offline   Reply With Quote
Old 01-31-2007, 06:57 PM   #137
W3bMa5t3r's Avatar
Sent Cheers
Old 02-01-2007, 08:19 PM   #138
RyanB95's Avatar
RyanB95 is an unknown quantity at this point
Perfecto! Hopefully it will arrive for the weekend.
Pleasure doing business!
1995 AWD Tsi Talon
Intel D945GCLF
M2-ATX
2GB Corsair
30GB OCZ SSD
BU-353
Lilliput EBY-701
Logitech DiNovo Mini
LSX VOID 3.3
RyanB95 is offline   Reply With Quote
Old 02-02-2007, 09:57 PM   #139
RyanB95's Avatar
Received it today. Thank you very much! Looks to be of top-notch quality.
Now for the wiring
1995 AWD Tsi Talon
Intel D945GCLF
M2-ATX
2GB Corsair
30GB OCZ SSD
BU-353
Lilliput EBY-701
LSX VOID 3.3
Old 02-03-2007, 12:35 AM   #140
W3bMa5t3r's Avatar
Now for the wiring
Cool, you're welcome... and I try lol good luck.
Peace...
Old 02-03-2007, 01:22 AM   #141
RyanB95's Avatar
Webmaster if you could, please check your email for me.
I wired in my controller but I don't know if I did it right. The computer's "idiot" lights come on when plugged in and all that jazz. When I press the power button, some other lights come on as they should. But the laptop doesnt actually power up. Is this becuase I don't have the rest of the module hooked up? I was testing to see if the laptop worked with the mono jack hanging out the side of the laptop with nothing else plugged in. Should it still start up like normal? No fans are spinning, and there is no display. I hope I didn't fry anything !
1995 AWD Tsi Talon
Intel D945GCLF
M2-ATX
2GB Corsair
30GB OCZ SSD
BU-353
Lilliput EBY-701
LSX VOID 3.3
Old 02-03-2007, 02:08 AM   #142
W3bMa5t3r's Avatar
If you wired it up correctly, the laptop should power up as normal, whether or not the module is connected. You should also be able to use the external/emergency power button to turn the laptop on if the module is connected to the laptop. If it doesn't work in either scenario then something might be wired wrong. Just check the laptop power button, ensure you're connected to the correct leads on the switch. Let me know whatcha find out.
Old 02-03-2007, 06:06 PM   #143
RyanB95's Avatar
Webmaster - I see that you are online right now. Is it possible for you to sign onto AIM?
1995 AWD Tsi Talon
Intel D945GCLF
M2-ATX
2GB Corsair
30GB OCZ SSD
BU-353
Lilliput EBY-701
LSX VOID 3.3
Old 02-04-2007, 01:26 PM   #144
RyanB95's Avatar
Ok, I have drawn a diagram of my current situation. Apparently the power switch that gets pressed to turn the laptop on normally has no effect on this switch, which is connected to it by a ribbon cable. This button has a black pin sticking out of it. I used a multimeter on the "beep" setting as instructed to test it.
This is how I have it wired now:
This is what I figured out after testing it:
This button gets mounted to the plastic casing of the laptop, but never actually gets pressed down. This leads me to believe that I need to solder my jack to 1+2 because the button will never actually get pressed. I guess that just serves as a "base" for when the ribbon-connected button gets pressed. I suppose my laptop already has a "remote" power button setup.
1995 AWD Tsi Talon
Intel D945GCLF
M2-ATX
2GB Corsair
30GB OCZ SSD
BU-353
Lilliput EBY-701
LSX VOID 3.3
Old 02-04-2007, 02:10 PM   #145
RyanB95's Avatar
Ok I got it wired up and now the laptop turns on. I soldered the leads to pins 2+3 in my diagram. I plugged the connector into the jack, but when I press the emergency power button... the display turns off - not the computer . This makes no sense to me as I didnt change anything that has to do with the display. Also - the emergency button is supposed to power up the computer if needed - correct? It doesn't do that either...
I'm confused!
1995 AWD Tsi Talon
Intel D945GCLF
M2-ATX
2GB Corsair
30GB OCZ SSD
BU-353
Lilliput EBY-701
LSX VOID 3.3
Old 02-04-2007, 11:48 PM   #146
W3bMa5t3r's Avatar
Sorry I hadn't responded yet, these 12-14 hour days are kicking my butt. And night shift just makes it all that much more crazy. Anywho... I'm gonna try to catch you on AIM so we can work this out.
Cheers.
Old 02-11-2007, 11:57 PM   #147
RyanB95's Avatar
Ok, has anyone ever needed to solder this module to a membrane switch? The only other person I saw that had to do it was tiomka. I PM'ed him about how he did it a few weeks ago and never got a response. He has a Toshiba laptop just like me:
http://www.mp3car.com/vbulletin/classified-archive/94484-toshiba-a15-s157-2-2ghz-512mb-dvd-built-w3bma5t3r-laptop-power-module.html
I was soldering to the wrong thing before so I need to figure out what needs to be soldered to now. Here is my setup:
The power button is all the way to the left. Here's a closer shot:
I don't know how I should go about this .
1995 AWD Tsi Talon
Intel D945GCLF
M2-ATX
2GB Corsair
30GB OCZ SSD
BU-353
Lilliput EBY-701
LSX VOID 3.3
Old 02-12-2007, 10:36 AM   #148
rsxtypes's Avatar
rsxtypes is an unknown quantity at this point
I wouldn't solder on the button itself. I would look at where the ribbon cable connects to the board. The long dark line that crosses the three buttons in your picture is more than likely the ground. You would need to connect to that ground and the other side of the button. To find it use a continuity tester or ohm meter. Connect one lead to the ground leave the other lead free and move it down the line of connectors as you test. When you press the button the continuity tester should beep and the ohm meter should go from infinity(no connection) to zero.
Just test each wire till you get it.
Should look something like this. (Not a toshiba laptop or even a computer for that matter).
By the calculas homework I can tell you are familiar with the concept of infinity or will be soon
rsxtypes is offline   Reply With Quote
Old 02-12-2007, 11:53 PM   #149
RyanB95's Avatar
Yeah, but the connector that's soldered to my motherboard has way more pins than the ribbon cable has wires. Sorry about the size but I wanted you to be able to see the details.
1995 AWD Tsi Talon
Intel D945GCLF
M2-ATX
2GB Corsair
30GB OCZ SSD
BU-353
Lilliput EBY-701
LSX VOID 3.3
Old 02-14-2007, 09:47 AM   #150
rsxtypes's Avatar
I count 5 which is the exact number it should be. 1 ground, 1 for each of the 3 buttons and 1 for the screen close detection switch(which is what you where soldering on). I count 6 conductors on the ribbon cable. But I can't see the ribbon cable close enough to tell where they all go.
Before I go further, I have to ask. Do you have a multimeter?
Find the ground first. My guess is that it is the 2nd one from the right is the ground. Although The second one from the left has a big white arrow pointing to it SO thats a good candidate too.
Laptop Power On I've Searched Help Please TimStark Laptops, Netbooks, Tablets, UMPCs, etc. 17 02-28-2007 07:59 PM
laptop power on off onlineamiga Laptops, Netbooks, Tablets, UMPCs, etc. 4 12-20-2005 11:33 PM
Any downsides to a laptop car adapter as a power source? BlackAWD Laptops, Netbooks, Tablets, UMPCs, etc. 9 11-20-2005 06:59 PM
Power laptop from headunit? LordSnow Newbie 12 04-07-2005 10:25 PM
Power button extention on a laptop oafdawg General Hardware Discussion 7 05-18-2004 09:26 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
