Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > User Innovations
Old 02-14-2007, 12:18 PM   #151
Ruffy's Avatar
Ruffy is an unknown quantity at this point
button is alot easier on many laptops (trust me ive repaired laptops for 2 years on job)
On mine there is no ribbon cable or similar. the button board presses onto a small connector on the mainboard then its screwed down. so no cables to play with. And you're not going to be able to solder onto the small connector on the mainboard. It's a press fit and very small, plus the button board sits on top of it blocking all access.
Car : 00' Chrysler 300M
Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
Ruffy is offline   Reply With Quote
Old 02-14-2007, 02:25 PM   #152
RyanB95's Avatar
RyanB95 is an unknown quantity at this point
So what am I supposed to do?
1995 AWD Tsi Talon
Intel D945GCLF
M2-ATX
2GB Corsair
30GB OCZ SSD
BU-353
Lilliput EBY-701
Logitech DiNovo Mini
LSX VOID 3.3
RyanB95 is offline   Reply With Quote
Old 02-14-2007, 02:45 PM   #153
rsxtypes's Avatar
rsxtypes is an unknown quantity at this point
Are you saying it would be easier to try to get at the wires behind this membrane (that is probably adhered to that plate) ...
than to solder on these clearly visible posts?
rsxtypes is offline   Reply With Quote
Old 02-14-2007, 03:17 PM   #154
W3bMa5t3r's Avatar
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
W3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of light
I think RSX is right here, it'd probably be easier to solder to the leads from the socket for your ribbon cable. You'd just need to be very careful and very precise. Before you start, do like you did for the membrane switch/lid switch check the leads with a multimeter on the continuity setting. Have your ribbon cable in the socket, press your button and test the leads till you get the desired BEEP (make sure your laptop is unplugged and the battery is out)
W3bMa5t3r is offline   Reply With Quote
Old 02-14-2007, 05:59 PM   #155
rsxtypes's Avatar
Quote: Originally Posted by W3bMa5t3r View Post
Thanks for cutting that picture down for me. I just wanted to add you are not looking at the pins inside the connector. You want to look at the soldering pads at the base of the connector. There are 5 of them clearly visible on this side of the connector. I am not sure what is on the other side of that connector there may be more.
Old 02-15-2007, 09:24 PM   #156
RyanB95's Avatar
Just in case it helps at all - Here's a picture of the back side of that connector:
And here's where I mounted my jack. I didn't need my speakers anymore since I would be using the laptop in my car all the time so I removed them and that gave me a perfect spot to mount the jack:
1995 AWD Tsi Talon
Intel D945GCLF
M2-ATX
2GB Corsair
30GB OCZ SSD
BU-353
Lilliput EBY-701
LSX VOID 3.3
Old 02-16-2007, 09:53 AM   #157
rsxtypes's Avatar
I go back to my question from earlier: Do you own a multimeter? It is really hard to make guesses from a picture on where wires go. Guesses, that may or may not fry your system.
Old 02-16-2007, 11:56 AM   #158
RyanB95's Avatar
I don't own a multimeter, but I have access to one. I'll grab it today and try to figure it out. All I'm doing is figuring out which two soldering points beep when the button is pressed, correct? Polarity isn't an issue?
1995 AWD Tsi Talon
Intel D945GCLF
M2-ATX
2GB Corsair
30GB OCZ SSD
BU-353
Lilliput EBY-701
LSX VOID 3.3
Old 02-16-2007, 01:10 PM   #159
rsxtypes's Avatar
That is correct. You want to set the multimeter to Ohms. You aren't going to be interested in voltage or amperage. Polarity isn't an issue.
Old 02-17-2007, 09:57 AM   #160
anel160 is an unknown quantity at this point
Laptop Power supply/ and auto power up /shut down
Not really, but you can build these yourself and thus cheaper that way. Or having someone build one for you, saves you the time and effort and they are still cheaper than the other 'commercial' products. The commercial products do plug into serial ports, etc... usually. These we're building are just simple power on/off designs. The commercial ones also throw in all kinds of frills, bells and whistles, though you pay for that as well. All up to you... Just offering this as a service/as info for the community. ;-)
Hello, I am new to this forum guys,
I therefore introduce myself and let you know it's been a very educational site to read. Thanks for all your help.
I would hope someone could reply to this request of an explanation.
Basically i am about to biuld my first carputer. I was going to build it using an EPIA but then i found a new laptop with a faulty screen from factory for less that EUR 100 (USD 120 - GBP 65 ).
So i bought this DELL XPS M1210 and going to use this as my carputer.
I am going o use a touchscreen monitor as well and I am confused on what to do in respect of the followings:
How to connect the laptop and the screen to a DC - DC supply
so that
the laptop and the screen to turn on together simultaneously as the ignition starts
and turn off when i turn the engine off
(with the possibility of deactivating this function).
I hope someone is so king to help me, so far i have read all your threads but i am very confused. I have seen the switch shown in the pictures above but i don't understand how the laptop and the screen are powered.
I am a total newbie, but i learn fast.. so please help :-)
I promise i will post loasd of pictures as i build and finish my carputer..
anel160 is offline   Reply With Quote
Old 02-22-2007, 08:20 PM   #161
RyanB95's Avatar
Ok, I finally got the multimeter tonight. I put it on the continuity, or beep setting and here are my results:
By the way, the orientation of this diagram corresponds with the picture I took.
Should I be using the ohms setting as mentioned before? As of right now they are all equal as far as continuity goes, but maybe using a different setting will set on of them apart because I will get different numerical values.
1995 AWD Tsi Talon
Intel D945GCLF
M2-ATX
2GB Corsair
30GB OCZ SSD
BU-353
Lilliput EBY-701
LSX VOID 3.3
Old 02-22-2007, 09:03 PM   #162
RyanB95's Avatar
Got it. It was leads 7 + 9. I touched the red wires from the SDC to them, pressed the emergency switch and it fired up. Hopefully it does this automatically when it receives power .
Now to solder to those microscopic leads
1995 AWD Tsi Talon
Intel D945GCLF
M2-ATX
2GB Corsair
30GB OCZ SSD
BU-353
Lilliput EBY-701
LSX VOID 3.3
Old 02-23-2007, 12:23 PM   #163
rsxtypes's Avatar
Good work and good luck. Just be to careful and don't get it too hot.
Old 03-01-2007, 11:05 PM   #164
RyanB95's Avatar
Yeah I might take the screen off to allow for more airflow. Don't know yet though because I'd like to be able to bring it inside to transfer new media to it.
By the way - Is there a program that automatically syncronizes folders between two separate computers? For example: Every time I get new songs on my desktop I eventually bring my laptop inside and transfer the songs to it but it's ahrd to keep track of what's already been transferred and what hasn't. Is there a program that could keep them in sync so it does it automatically?
1995 AWD Tsi Talon
Intel D945GCLF
M2-ATX
2GB Corsair
30GB OCZ SSD
BU-353
Lilliput EBY-701
LSX VOID 3.3
Old 03-02-2007, 12:24 AM   #165
W3bMa5t3r's Avatar
I use SyncBack Freak'n awesome I tell ya. lol you can create profiles for particular folders, filter, backup, sync... etc...
Laptop Power On I've Searched Help Please TimStark Laptops, Netbooks, Tablets, UMPCs, etc. 17 02-28-2007 07:59 PM
laptop power on off onlineamiga Laptops, Netbooks, Tablets, UMPCs, etc. 4 12-20-2005 11:33 PM
Any downsides to a laptop car adapter as a power source? BlackAWD Laptops, Netbooks, Tablets, UMPCs, etc. 9 11-20-2005 06:59 PM
Power laptop from headunit? LordSnow Newbie 12 04-07-2005 10:25 PM
Power button extention on a laptop oafdawg General Hardware Discussion 7 05-18-2004 09:26 PM
