Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > User Innovations
Old 05-01-2007, 10:41 AM   #181
slinkytoy's Avatar
slinkytoy is an unknown quantity at this point
dell inspiron 8200 notbook
I have a dell inspiron 8200 notbook that i have that I'm going to install into my truck. The power turn is on a board that plugs into the motherboard will this turn on unit work with this kind of connection. Any help would be great.
slinkytoy is offline   Reply With Quote
Old 05-04-2007, 12:42 AM   #182
W3bMa5t3r's Avatar
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
W3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of light
If there is a momentary push button on the board it will work. You would solder in the leads as you would on a laptop. You'll have to test it though to be certain. Use the same test method as previously mentioned for the laptop power buttons.
Cheers, The W3bMa5t3r
W3bMa5t3r is offline   Reply With Quote
Old 05-08-2007, 07:52 PM   #183
bangumandoo is an unknown quantity at this point
will this module work for inspiron 600m?
bangumandoo is offline   Reply With Quote
Old 05-08-2007, 08:04 PM   #184
W3bMa5t3r's Avatar
Too funny. I was just updating the first post. Check it out.
Old 05-15-2007, 09:06 AM   #185
jwlionking's Avatar
jwlionking is on a distinguished road
Great Module. Mine is working great! What do you suggest for the reverse effect? I find myself using the momentary switch you supplied to put it into sleep. Is there a way to build the box to do the opposite too?
DigitalFX4.0 Skin by JohnWPB
Road Runner RR's Myspace
My Ride - Car Domain Page -JWLionKing's MySpace Page
Project 98% Complete -FREE DOMAIN & WEBSPACE / FILE HOST FOR DEVELOPERS - PM ME
jwlionking is offline   Reply With Quote
Old 05-15-2007, 11:07 AM   #186
W3bMa5t3r's Avatar
If you're using it with a laptop, you should be able to just set the ACPI / Power Settings to shut down / hibernate / standby the system once you turn the car off and whatever is supplying power to your laptop is turned off. Say after 45seconds after power loss it goes into standby/hibernate mode.
As far as building the reverse mode... I'm sure there is, I just haven't devoted the time to it as I have too many irons in the fire as it is lol. Maybe one of these days
Old 06-20-2007, 01:47 AM   #187
silicoon's Avatar
silicoon is an unknown quantity at this point
hi man
I hooked up your module and the usb function doesnt work - it still shuts down when i turn on the car
just wondering how you wired it because i cut the USB plug and wired it to another extension that goes to my hub - so i dont loose a usb port - im guessing red is + and black is - :P let me know...
im going to have another look at it, but its not workin atm!
anyway i can check if its taking in the power properly etc?
silicoon is offline   Reply With Quote
Old 06-20-2007, 02:02 AM   #188
W3bMa5t3r's Avatar
Quote: Originally Posted by silicoon
hi man
I'm guessing you mean you already have the pc ON then, when you turn on the car? How is your HUB powered in relation to the module and pc?
I've attached a pic showing the usb connection on the board. Basically just positive and negative from the usb cable should be read here. +5vdc on the one side, Ground/Negative on the other. Also, when you plug the usb cable in to a port that is powered on, you should hear the smaller, 5vdc relay 'click'.
Old 06-20-2007, 02:37 AM   #189
silicoon's Avatar
no worries ill check it soon! cheers bruz
Old 06-21-2007, 12:54 AM   #190
silicoon's Avatar
hey i checked and the relay does tick over when i add power, but it still resets on startup etc...
Old 06-21-2007, 05:28 AM   #191
W3bMa5t3r's Avatar
Giving power to the module, or plugging the usb into a powered port? When giving power to the module, you'll hear the 12vdc relay click. To test just the usb relay, you don't have to power up the module, just plug the usb cable into a powered port. You should then hear the 5vdc relay click.
Old 06-21-2007, 08:20 AM   #192
silicoon's Avatar
yeah the 5v relay clicks, i rewired it but i still have the ability to connect and disconnect it, and it does switch... :S guess ill have to pull it up out of my seat
Old 06-24-2007, 06:36 AM   #193
The Vauxhall Vectra Project
ccsnet's Avatar
ccsnet has a spectacular aura aboutccsnet has a spectacular aura about
W3bMa5t3r - I was curious about this project in your sig in your link so I thought I'd check it out.
Have you thought that this same unit can be used with screens too where there is no auto on ?
( Thats why I started looking at it )
Terran
ccsnet is offline   Reply With Quote
Old 06-24-2007, 07:18 AM   #194
W3bMa5t3r's Avatar
Terran
It should turn on any electronic device that uses a momentary pushbutton switch to power it on. So yes, monitors, external hard drives, etc. It's about a 3/8 - 1/2 second "PRESS" (or short really since that's what a switch does).
Old 06-28-2007, 11:15 AM   #195
brad1011a is an unknown quantity at this point
I have the same lappy going into my van. That daughter card's power-on contacts are shorted by the underside of the power button.
If you pull that card out you can see the same contacts on the reverse by pulling off the insulating tape underneath. There is no clearance there, so I'm going to try doing it with just a few strands of wire.
Have you or anyone been able to do it differently?
I wonder if the main board has a separate 'emergency' power button... I haven't been able to find anything about that...
brad1011a is offline   Reply With Quote
Laptop Power On I've Searched Help Please TimStark Laptops, Netbooks, Tablets, UMPCs, etc. 17 02-28-2007 07:59 PM
laptop power on off onlineamiga Laptops, Netbooks, Tablets, UMPCs, etc. 4 12-20-2005 11:33 PM
Any downsides to a laptop car adapter as a power source? BlackAWD Laptops, Netbooks, Tablets, UMPCs, etc. 9 11-20-2005 06:59 PM
Power laptop from headunit? LordSnow Newbie 12 04-07-2005 10:25 PM
Power button extention on a laptop oafdawg General Hardware Discussion 7 05-18-2004 09:26 PM
