Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > User Innovations
Old 07-23-2007, 02:10 PM   #211
the_crooked_toe's Avatar
the_crooked_toe is an unknown quantity at this point
i have an IBM R40 and if you need to know the connections on the mobo it's on 38 and 19. w00t!
the_crooked_toe is offline   Reply With Quote
Old 07-29-2007, 08:54 AM   #212
ticketmagnet is an unknown quantity at this point
I am going to try connecting the relay coil between IGN (through a diode) and the 12V output of the PSU. This performs the "power on button press", but can not perform a "power off button press". So it does the job with just one relay and no capacitor. Plus, there is no timing to worry about, it will always press the button just long enough to bring the computer up.
Without the diode, the relay coil would be energized with reverse polarity once ignition went low. This would hold the button until a forced power-down occured, I think.
I apologize if somebody already proposed this. I have to admit I didn't read the entire thread.
ticketmagnet is offline   Reply With Quote
Old 08-01-2007, 02:16 PM   #213
Well my last idea didn't work very well. The internal power supply is not stiff enough to source the relay coil current. I also found that the computer I'm using does not accept button presses that occur simultaneously to external power application.
I did create a two-stage that works. The first relay closes after a cap charges to give a 0.5s time delay. This powers the second relay that pulses the power button. However, I find this setup too cumbersome because it requires a lot of capacitance (I think I used 5400uF)
Old 08-12-2007, 06:59 AM   #214
TWiST is an unknown quantity at this point
So did the press once to turn on and hte press once to turn off module ever get finished ? Or is this circuitry still just for power on ? I am getting ready to build my own unit I got my 8 inch dynamix 816 lcd (DOES vga auto on, DOES NOT do auto reverse switch, and the mirror button on the remote DOES NOT do anything.) and I ordered and recieved my dash kit for my 2007 audi a4 but honestdee on ebay sent me the wrong one, he sent me the 99-9105 when I needed the 99-9102 and I ordered the 99-9102 so I dunno how he mixed that up.
TWiST is offline   Reply With Quote
Old 08-20-2007, 07:45 PM   #215
jgnoel86 is an unknown quantity at this point
I love idea of the module, but I'm not sure if perhaps im doing something wrong, i have it wired up to a docking station, and I've tried reversing the leads coming from the power switch on the docking station. But basically my laptop isnt auto turning on when i start my car, i have to use the emergency switch, and it is acting just like if i were to hit the power button once.
Also i thought the emergency switch was designed to let you hard boot the PC if it froze up for some reason. And no matter how long i hold the switch down it seems to act as though i had only touched the power button briefly. I ran the red-red and black-black on my ex-cigarette lighter, so I'm pretty sure that is wired right. yeah im just at a loss where this could be going wrong. Any help from ANY one would be great.
jgnoel86 is offline   Reply With Quote
Old 08-20-2007, 11:25 PM   #216
mangus580 is an unknown quantity at this point
What would everyone think, if I were to offer a 'ring' module for the 'wake on ring' function of a modem? I am working on just that now, for my setup.
'Burb-puter - worklog
mangus580 is offline   Reply With Quote
Old 08-25-2007, 01:15 PM   #217
john1701's Avatar
john1701 is on a distinguished road
ok i just ordered the laptop controller ($35 model), should have in about 5 days. I too will post what i think of it when it gets here.
CAR:2001 Ford Crown Victoria
PC: Acer EEE 900HA with Vista with CF 2.0.
Memory:1G
Drives:160gig
WI-FI:Cingular
GPS:Garmin
Screen:Xenarc 700TSV
The Florida Meets Thread
john1701 is offline   Reply With Quote
Old 08-25-2007, 06:55 PM   #218
bgreen02 is an unknown quantity at this point
can just 1 module turn on a monitor and a laptop, or do you have to have a separate module for each one?
bgreen02 is offline   Reply With Quote
Old 08-30-2007, 06:26 PM   #219
W3bMa5t3r's Avatar
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
W3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of light
Sorry I've been absent lately. Been pulling extra 12 hour shifts for people that are sick and/or on vacation...
John, your module shipped out early yesterday,
bgreen, you "should" be able to use one module to do both, but you'll need to modify the cable coming from the module that goes into the plug/jack setup for the laptop. You can just splice into that cable, taking it to the monitor and it should work for you.
W3bMa5t3r is offline   Reply With Quote
Old 08-31-2007, 10:14 PM   #220
WarDriver's Avatar
WarDriver is on a distinguished road
Hey W3bMa5t3r...glad to see you're still selling these modules and helping people get their laptops set up the right way.
-WarDriver-
Server Administrator
Outdoor Nut
My DC to AC Inverter Mod
My Laptop Remote Switch
WarDriver is offline   Reply With Quote
Old 09-01-2007, 11:27 AM   #221
john1701's Avatar
ok got it! it only worked once! one time! i hear the relay turning on and off but the laptop does not turn on. Yes its wired correctly. It is connected to the docking station's power button. Yes it is soldered correctly. Yes the all three buttons turn on and off the laptop- laptop button - docking station button- and the button that came with the controller.
any other help?
-i think the relay is not "pressing" the button long enough.
Memory:1G
Drives:160gig
WI-FI:Cingular
GPS:Garmin
Old 09-01-2007, 04:38 PM   #222
W3bMa5t3r's Avatar
any other help?
The approximate timing is 1/2 second. Are you getting that time between the two clicks of the relay turning off and on?
Old 09-01-2007, 04:43 PM   #223
W3bMa5t3r's Avatar
Hey hey, long time bro. Yeah I'm still around lol and within the next week or so I'll have the usb power modules out as well. All the more to eat up the free time I don't have lol.
...only 1.5 hours till I'm off work... GRAW2 is calling me...
Old 09-01-2007, 05:31 PM   #224
john1701's Avatar
no its actually clickin faster.
Memory:1G
Drives:160gig
WI-FI:Cingular
GPS:Garmin
Old 09-03-2007, 12:41 PM   #225
john1701's Avatar
well it looks like i have wasted my money big time. could have went to radio shack a bought a 99 cent button to manually turn the laptop on and off. what a rip. guess its only for certain laptops, even though they all turn on and off with a button. buyer beware.
Memory:1G
Drives:160gig
WI-FI:Cingular
GPS:Garmin
Laptop Power On I've Searched Help Please TimStark Laptops, Netbooks, Tablets, UMPCs, etc. 17 02-28-2007 07:59 PM
laptop power on off onlineamiga Laptops, Netbooks, Tablets, UMPCs, etc. 4 12-20-2005 11:33 PM
Any downsides to a laptop car adapter as a power source? BlackAWD Laptops, Netbooks, Tablets, UMPCs, etc. 9 11-20-2005 06:59 PM
Power laptop from headunit? LordSnow Newbie 12 04-07-2005 10:25 PM
Power button extention on a laptop oafdawg General Hardware Discussion 7 05-18-2004 09:26 PM
