Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > User Innovations
Old 01-24-2008, 11:03 PM   #256
silvi4000 is an unknown quantity at this point
Quote: Originally Posted by Vinster03XR View Post
If you would have use stranded CAT5, you would not have had the problem with the wire being too stiff... Be-heading a pre-made 10ft cable would have worked well too..
Props to you.
Vin
gotta get me some of that stranded CAT5. I think we only use solid wires even for patch cables. If I find a factory made patch cable Im gonna cut it up and check it. Maybe after the 10 or 11th be-heading I'll find a stranded one :-)
silvi4000 is offline   Reply With Quote
Old 01-26-2008, 04:45 AM   #257
Vinster03XR's Avatar
Vinster03XR is an unknown quantity at this point
Here normally the 3ft to 25ft pre-made cables are stranded... and the supplier that I get my networking hardware from sell both Solid and Stranded RJ45 Connectors... So I'd think it would be common....
Where do you live?
Vin
Carputer works... but will never be complete....
Vinster03XR is offline   Reply With Quote
Old 02-15-2008, 11:04 AM   #258
rafynet is an unknown quantity at this point
Unhappy
I get this error when i try to Checkout in your store.
I live in Mississauga, Ontario Canada.
I want to buy your Laptop Auto Power-On Module, What can i do? Can I send the payment to your email through PayPal?
rafynet is offline   Reply With Quote
Old 02-18-2008, 12:11 PM   #259
W3bMa5t3r's Avatar
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
W3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of light
Seems there was a misconfiguration with the international shipping. Should be all good now so give it another go. Thanks
W3bMa5t3r is offline   Reply With Quote
Old 03-03-2008, 09:42 PM   #260
ArtVandalay is an unknown quantity at this point
Additional Option
I think I found another work around for the some folks (depends on the laptop). I would first start by looking into getting (if you don't have it already) the docking station for your laptop. I am using an HP NC2400 and it's dock. Instead of fiddling around and soldering my Laptop motherboard I decided to see if I could hack the dock instead. Mose docks have there own power switch which function the same way the onboaed switch does (while the machine is in the dock of course) Obviously this is a lot cheaper to replace if things go bad. So upon opening up my dock I found the the power switch and LED were on it's own standalone circuit board and wired to another control board within the dock. I clipped the wire at the 1/2 way point and plan on extending this wire by splicing in some of my own. There are 4 wires in all to control things like one touch standby or a hold down for complete power off...etc. I'll keep you posted on my progress if anyone is interested. Should take me a few more days to work on and test things out. Now I do understand that not all docks have the convenience of having the power button separate from the rest of the internal components, but that is where using an item like the one offered in this thread comes in...only this time instead of possibly ruining your $1500.00 laptop you are only hurtung a $50.00 - $100.00 dock. By the way using a dock has other benefits as well...Usually they have more USB Ports, and allow you to easily remove your PC from your car for safety / maintenence etc. without unplugging everything.
ArtVandalay is offline   Reply With Quote
Old 03-03-2008, 09:48 PM   #261
Sorry I need to Read more!
Sorry to WilgartW of post #209...This thread is so huge I missed it...damn...pics too...Looks great! Hope mine goes well.
Old 03-15-2008, 02:02 PM   #262
Gibson99's Avatar
Gibson99 is on a distinguished road
Webmaster - excellent and SIMPLE device you've come up with here. I'm no EE but i can solder OK, and follow a simple schematic like this. I've decided to make mine a little more modular.
I have the remnants of a Dell L400 laptop. I say remnants, because it's one of those weird first attempts by a manufacturer to make a super-thin laptop, where the "docking station" is really a second layer that snaps into the bottom of the laptop, and is the only way to have a floppy or cdrom, or even more than just one USB port! It was given to me by a friend who knows I like to tinker, and it's missing that lower half w/ cdrom/fdd/etc, and has been dropped, so the plastics are in pretty rough shape. It's got a 30gb hdd and unfortunately only 256mb, but it runs XP, Winamp and Streets & Trips, so I'm ok with that. I found another thread on here with some great command line instructions on how to "pre" install xp onto the hd with the hd installed in my desktop. The only weird concequence of that was that now instead of C:, the laptop has an F: drive. Looks weird in explorer, but it works, so who cares!
I took off the screen (permanently - it's going on ebay!), and while I was in there, I probed around to find the power button stuff. While I was in there I also removed the modem, since I won't be needing it. A thought occurred to me at this point, because the phone jack actually had a 2-pin lead going from the motherboard up to the modem daughterboard, so I just grabbed a little length of cat-5 and took one pair out of it, and used that to extend the lead from the phone jack to the power button. This made "adding a plug" to the outside of the case super easy - especially since there was absolutely no room to add anything (further complicated by cracked case plastics!) So now other than the missing screen (and physical damage to one corner) the laptop looks normal - you can't tell it's been hacked! No idea what would happen if you actually plugged a phone line into the modem port now, but I haven't used a POTS landline in so long....
Now for the box I'm building off your plans, I am simply putting a duplex phone jack (cannibalized from an old 2-way phone jack splitter) into the side of the enclosure. I will have a simple coaxial power connector to plug into the car for 12v acc, but for the 5v section i took a rather different approach:
I am using the PS/2 KEYBOARD PORT for my +5vdc! Why? I only have ONE usb port on this laptop, and I am probably going to end up using that for the touchscreen, and I don't want to deal with usb hubs and their power issues. From another project, I had an unused female ps/2 port I can easily install into the radio shack project enclosure so that I don't lose my keyboard port in the process. For the lead to the laptop I chopped the end off an *OLD* keyboard adapter cable that allowed you to use an old AT style keyboard on a machine w/ a ps/2 port (See, there is a good reason to hang on to all those old cables and equipment - free carputer parts!). I'm simply tapping into the 5v rail on the keyboard line to activate the relay. I don't necessarily have to have a keyboard plugged in for this to work, though i will be using a numpad to control it - at least till I get a touchscreen installed.
The only thing I see as possibly being a problem is that I bought a 1000uf 35v cap instead of a 25v one like you specified. I couldn't find a 25v at any of my local radio shacks - 50v was more prevalent. Do you forsee this being a problem if I keep a 10k resistor?
Previous: CamryAmp 1.0 - 95 Camry SE V6 Coupe (sold)
Current: CamryAmp 2.0 - 98 Camry CE V6 5spd
Gibson99 is offline   Reply With Quote
Old 03-15-2008, 02:10 PM   #263
W3bMa5t3r's Avatar
Sounds good mate, and good idea using your ps2 port for the 5vdc. The 35v cap is fine. The capacitance value is the same so you'll be good. Just rated for higher voltage applications.
Good luck with your project
Old 03-15-2008, 02:26 PM   #264
peijffertje's Avatar
peijffertje is on a distinguished road
@Gibson99
Dude, I used exactly the same as you have. (also no screen)
A Dell c410 (Now a C640) with W3bmast3rs shutdown control thingie. (which is a really nice piece of work)
I advice strongly on getting a dockingstation on Ebay (got mine for 10 Euro) and built the shutdowncontroller into that. You want to be able to take the laptop out when your installing software and that kind of stuff and you can upgrade later if you'd wish to a C640 or something and still use the same dock.
Plus, big extra.. you get 2 more USB ports.
peijffertje is offline   Reply With Quote
Old 03-15-2008, 02:59 PM   #265
Gibson99's Avatar
Quote: Originally Posted by peijffertje View Post
@Gibson99
No, the C series is quite different from the L series. Check out these pics I just took of the L stacked on top of the C - both screens removed, at the bottom of this post.
Actually my main laptop that I use for work is a Latitude C610 (which also only has one USB port - go figure). I also have an old Inspiron 4000 which is basically the same as a C600 but with a different bios and different plastics. Its screen is cracked, and i have a docking station for it (and the dock for the insp 4000 does NOT work on the c610 even though it physically fits - be aware of firmware differences when trying things like this), so when I get done with this project in the Miata, I am planning on using the dock and the insp4000 (minus screen) in my Camry. There just isn't enough room in the miata to put a big C series plus its dock, which is why I'm using the L400 - it's quite small. Its dimensions are 27cm x 21.5cm x 1.5cm, which makes it possible to fit in the glovebox of the miata with very little modification to the glovebox itself. Plus, since I am making this startup controller modular, I can easily unplug the laptop from the car and bring it inside for updates/maint. True, it's not as easy as removing it from a dock, but it's only power, keyboard, "phone" and audio, so it's not a big deal.
The camry has a lot more room, so I can mount the dock under a seat, and yes, I plan to build the controller into the dock itself, so that all I have to do for that is add a switched 12v input jack to it - the relays, resistor and cap can all be contained completely within the dock. Do you have any problems with your laptop rattling in the dock? I don't want to add any more rattles to my car!
Old 03-15-2008, 03:38 PM   #266
The dimensions of the C400 (Its C right? I know they are both lattitudes...) and the C600 are different (The C600 is a lot larger) but they use the same dockingstation.
Nope, no ratling at all. The dock is firmly fixed in my trunk with Velcro and locking the dockingstation seems to be enough.
If you put the laptop under your chair, keep in mind that it can get a little wet when people get in the car on a rainy day.
Old 03-15-2008, 05:37 PM   #267
Gibson99's Avatar
Good to know about the rattling (or lack of). My last carputer was under the driver seat and I had no issues with it. it was made of desktop components, too! Check out the photos section of my CamryAmp link in my signature.
Back on topic, here's my (almost) finished box. I haven't tested it yet, partly because the only thing it lacks is the 12v input jack - it will go on the orange and brown wires sticking straight up. I kinda wish I could have made the keyboard cable a plug too, so that the box would not have any dangling wires, but oh well, nothing's perfect - and it'll be hiding in the dashboard anyway, so nobody will see it.
Turns out the keyboard cable I hacked up was defective - it had a break somewhere in the wires, and I couldn't trace it back, so I found an old Compaq 2-button mouse with no scroll wheel that (thankfully) had all of the pins needed for the circuit. It ended up giving me a 2m cable to work with rather than just 15cm like before. The phone jacks will need a little glue to keep them from rattling, but that's easy. Whatcha think?
EDIT: Update: it works great on the bench. Does exactly what it's supposed to! Now to hook up some bigger relays in the car itself to allow my inverter to only be on w/ the ignition, and then mount it in the car! woohoo! Thanks again Webmaster - your little gizmo has helped me get done with this project a LOT sooner than I otherwise would have, and it should work a lot simpler too!
Old 03-21-2008, 08:58 PM   #268
W3bMa5t3r's Avatar
Glad to see you guys taking this on in other/additional directions.
Old 03-22-2008, 02:05 PM   #269
Gibson99's Avatar
hey, we couldn't have done it without the great foundation of your little circuit, and your regular support in this thread to people like me who had questions! THANKS!
here's to you W3bMa5t3r!
Old 04-19-2008, 04:48 PM   #270
jonessc's Avatar
jonessc is an unknown quantity at this point
Hi W3bMa5t3r
Ordered a kit bout a year ago and its still going well. Thanks for making these available to the community
What im after is way to trigger a power on, while my laptops outta the car in the house (maintainance or software upgrades.)
Maybe just a wire similar to your startup kit with a switch on the end to trigger the start, I dont mind buying another kit if thats not possible, just don't want the needless wires
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
jonessc is offline   Reply With Quote
Laptop Power On I've Searched Help Please TimStark Laptops, Netbooks, Tablets, UMPCs, etc. 17 02-28-2007 07:59 PM
laptop power on off onlineamiga Laptops, Netbooks, Tablets, UMPCs, etc. 4 12-20-2005 11:33 PM
Any downsides to a laptop car adapter as a power source? BlackAWD Laptops, Netbooks, Tablets, UMPCs, etc. 9 11-20-2005 06:59 PM
Power laptop from headunit? LordSnow Newbie 12 04-07-2005 10:25 PM
Power button extention on a laptop oafdawg General Hardware Discussion 7 05-18-2004 09:26 PM
