Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > User Innovations
Old 08-08-2006, 09:16 AM   #61
W3bMa5t3r's Avatar
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
W3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of light
Quote: Originally Posted by peijffertje View Post
Just placed the order.
I'll pay you through paypal as soon as you tell me the total amount.
I asked this question with the order as well, but the only cable that really needs to have some length is the cable of the remote switch, right?
(laptop is in the trunk)
All the other cables can be short since they are close to the laptop and powersource anyway.
Shot you an email with the info. You are correct though, for your setup, what you requested in the order request form sounds perfect.
W3bMa5t3r is offline   Reply With Quote
Old 08-08-2006, 09:35 AM   #62
peijffertje's Avatar
peijffertje is on a distinguished road
Thanks mate.
I just made the payment.
peijffertje is offline   Reply With Quote
Old 08-18-2006, 01:13 AM   #63
rumy is an unknown quantity at this point
hey there,
Hows the shutdown part comming along. I am looking to make this module so if I can get the shut down part that would be awosme....
Thanks..
rumy is offline   Reply With Quote
Old 08-18-2006, 04:27 AM   #64
Laptop ON/Off Module
Hey guys,
I have modified the circuit to work with a 555 timer IC and shut down/Stanby/hybernate when you turn the car off.
Any one want to test it for me. I dont have the time.
The only problem I have with this is that when the car is off the laptop cannot run. As soon as you turn it on it will shutdown/ hybernate in whatever delay is set.
Any suggestions are welcome.
Old 08-18-2006, 10:44 AM   #65
W3bMa5t3r's Avatar
Quote: Originally Posted by rumy View Post
Hey guys,
Sorry I, nor mrfrankmrfrank has gotten around to building/posting the startup/shutdown module/circuit. I personally have been swamped with a million things on my plate. I do have one question for you though, how much current is required to trip that DPDT 5v relay? because the usb line can only supply 500mA, and alot of times, the laptop lines are less than that. The 5v relay used in my circuit is a SPDT MINI relay and it's coil activation mA draw is about 200mA and I know for a fact from testing on two different laptops, that the USB line could NOT activate two of those at a time. I would actually have to have two seperate usb powered lines, one for each relay. Kinda sucked. lol. Though being in a single package, the DPDT might work just fine...
Old 08-18-2006, 11:36 AM   #66
Quote: Originally Posted by W3bMa5t3r View Post
Sorry I, nor mrfrankmrfrank has gotten around to building/posting the startup/shutdown module/circuit. I personally have been swamped with a million things on my plate. I do have one question for you though, how much current is required to trip that dpdt 5v relay? because the usb line can only supply 500mA, and alot of times, the laptop lines are less than that.
Well,
I took that part of the circuit from your diagram posted in this thread, but ill try and find out for sure.
Well if some one here feels like testing this circuit and using it go ahead and let us all know if it works. In theory it should work, but then again.
If I do get arround to getting the compoents I will test it myself.
Old 08-18-2006, 01:30 PM   #67
drewbad is an unknown quantity at this point
Would there be any concern with the current in this circuit? I noticed there is not a current limiting resistor in series with the ACC or USB voltage line? It might be something to consider.
drewbad is offline   Reply With Quote
Old 08-20-2006, 05:33 PM   #68
mJrO's Avatar
mJrO is on a distinguished road
what values should i use for the resistors assuming that i want the laptop to poweroff after 5/7 seconds after the car is turned off? (i dont know much about electronic stuff).
2005 S40 2.0D - Sport Body Kit
Ipod 100%
Carpc 95%
mJrO is offline   Reply With Quote
Old 08-21-2006, 11:54 AM   #69
This should help:
http://ourworld.compuserve.com/homep...Bowden/555.htm
http://wolfstone.halloweenhost.com/T...TimerCalc.html
Your goal is an output of around 6000 milliseconds.
Old 08-22-2006, 06:40 AM   #70
artur2 is an unknown quantity at this point
Could Someone please tell me , where i can buy one, i know i can make one but i havenīt know how to make one, i donīt have any knowledge !!
Hughes
artur2 is offline   Reply With Quote
Old 08-22-2006, 06:42 AM   #71
W3bMa5t3r's Avatar
Hughes
What are you looking for? If you're looking for one of my laptop auto power on modules, just check out the first post and/or my website. I build and sell those. As far as the other circuits that have flooded this thread I have no dealing with.
Peace.. The W3bMa5t3r
Old 08-26-2006, 08:28 AM   #72
blessani is an unknown quantity at this point
Just out of interest, if anyone wants a piece of software that can shutdown/restart/stanby/hibernate the laptop when the AC is removed, check it out here...
ShutControl - http://www.mp3car.com/vbulletin/showthread.php?p=901994#post901994
It doesn't appear there is a piece of software like this yet (or I haven't seen it), so its perfect in conjunction with your shutdown controller. But, it does require the AC Power to turn off when the IGN goes off.
'98 Peugeot 306
Project Status: I sold it ages ago!
ShutControl
The ultimate shutdown control software for laptops.
blessani is offline   Reply With Quote
Old 09-02-2006, 04:42 AM   #73
W3bMa5t3r's Avatar
Exclamation I do build these Laptop Auto Turn On / Power On Modules
Just to clarify things since this thread has become cluttered with other posts/circuits and I've been getting numerous emails/pms about this... The circuits and modules that I talk about in the first post (and to about post 39) are the ones I build and support. Please check out my website for more information, testimonials, faqs, etc...
Old 09-11-2006, 01:59 AM   #74
isawultra is an unknown quantity at this point
Ok. After reading all 5 pages, this module doesnt have an auto hibernate function? Please correct me if I am wrong.
When can you release modules that have both features?
isawultra is offline   Reply With Quote
Old 09-11-2006, 02:04 AM   #75
W3bMa5t3r's Avatar
You are correct, my module does not have that feature and I'm sorry, but I really haven't gotten around to trying to add it. I have a million things going on and Windows can be configured to go into hibernate as soon as a laptop is unplugged (turning the car off and the power supply) so it hasn't been at the top of my list of things to do.
later...
Laptop Power On I've Searched Help Please TimStark Laptops, Netbooks, Tablets, UMPCs, etc. 17 02-28-2007 07:59 PM
laptop power on off onlineamiga Laptops, Netbooks, Tablets, UMPCs, etc. 4 12-20-2005 11:33 PM
Any downsides to a laptop car adapter as a power source? BlackAWD Laptops, Netbooks, Tablets, UMPCs, etc. 9 11-20-2005 06:59 PM
Power laptop from headunit? LordSnow Newbie 12 04-07-2005 10:25 PM
Power button extention on a laptop oafdawg General Hardware Discussion 7 05-18-2004 09:26 PM
