11-06-2006, 02:46 PM
#91
Power Supply for a T41
Webmaster,
I have sent you a couple of emails requesting a power supply built. I was wondernig if i sent you a spare AC adapter that i have for the laptop, could you create a power supply with a connector that would plug right into my laptop?
I am hoping to avoid the teardown, and soldering of my laptop.
11-06-2006, 02:59 PM
#92
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
Quote: Originally Posted by scp028
Webmaster,
Not sure what's happened with the emails, but I don't actually build or work with power supplies. The module I build doesn't supply power to anything, but mearly replicates someone manually pressing a power button. It just does it automatically.
11-06-2006, 03:40 PM
#93
Ahh, ok thanks man.
12-27-2006, 06:49 PM
#94
Updated a few pics (still need to update a few of'm) and some of the information.
Cheers & Happy Holidays Everyone
01-06-2007, 11:24 AM
#95
Ok, after even more additional questions / confusion, the schematic for my Auto Power On Module has been updated and more information added.
Cheers
01-06-2007, 03:04 PM
#96
Hey mate, the design is ace. Been tryin to build one, but struggling on which relays to use? Im in the uk so only have access to http://www.maplin.co.uk and http://www.rapidonline.com cant work out whether the ones that these company supply, are normally open or closed? Any advice? thanks
01-07-2007, 01:37 PM
#97
This is pretty sweet... I'll have to give it a try....... Nesxt would be a delayed auto off..
Vin
Carputer works... but will never be complete....
01-07-2007, 02:51 PM
#98
Quote: Originally Posted by Vinster03XR
... Next would be a delayed auto off..
Vin
That would be Windows power management  lol
..well, if you're using it on a PC...
01-07-2007, 05:38 PM
#99
I'm using a laptop with no battery, running off an inverter... the inverter 'on' signal is from my deck.... at the moment, I have to turn off/Hybernate the PC manually using the power button I mounted on the cash... but I'd like to install an off-delay relay for the inverter and a pulse relay from the ingnition....
So the pulse will be for the power button and the off-delay will be for the inverter on signal and it would need to be on for about 15 seconds.... long enough for the PC to hybernate...
That's what I need to do.... I know how and what I need to do it... but some of the parts are expensive and I don't have time to do it right now, so it'll have to wait until next summer..
But I like your auto on function... I'll have to try that sometime... and thanks for sharing the circuit...
Vin
01-07-2007, 05:56 PM
#100
Vin
gotcha  and good luck... and I'm just glad to help
Cheers
01-08-2007, 04:32 PM
#101
Not sure how I missed this post... but yeah...
If you get the SPDT (single pole double throw) relays, they have a normally closed and a normally open pole. you just have to wire to the correct pole.
Hope that helps
01-09-2007, 08:22 PM
#102
Cheers
Appreciated
Vin
01-10-2007, 11:27 AM
#103
Hi W3bma5t3r,
Is your email playing up again ?
Left a PM and sent a contact message with questions on your " buy module " site ?
Sorry new to this but wanted to know before I bought one ,
if you dont plug in the USB safety lead , have windows set up so to hibernate and then push the remote emegency button on dash again, would it act as a shutdown to hibernation ?
thanks
01-10-2007, 12:45 PM
#104
Quote: Originally Posted by Tapsell123
Hi W3bma5t3r,
thanks
Hey, not sure what's up with my email... sorry :-\
The remote emergency button overrides everything, so whether or not the USB safety lead is plugged in, it will be like pressing the laptop power button.
It will act however Windows is setup in the Power Management section to act.
If you have "When power button is pressed, do:" set to "hibernate", then if you press the laptop button or the remote power button, it will put the laptop into hibernation.
Hope that helps...
Cheers
01-11-2007, 06:34 AM
#105
So once I have set to " hibernation when button pressed " , will pressing it bring it back from hibernation too ?
How do you bring your system back from hibernation ?
as my setup is similar to the one in your cobra
| Thread Tools |
| Display Modes |
Linear Mode
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Laptop Power On I've Searched Help Please
TimStark |
Laptops, Netbooks, Tablets, UMPCs, etc. |
17 |
02-28-2007 07:59 PM |
laptop power on off
onlineamiga |
4 |
12-20-2005 11:33 PM |
Any downsides to a laptop car adapter as a power source?
BlackAWD |
9 |
11-20-2005 06:59 PM |
Power laptop from headunit?
LordSnow |
Newbie |
12 |
04-07-2005 10:25 PM |
Power button extention on a laptop
oafdawg |
General Hardware Discussion |
7 |
05-18-2004 09:26 PM |
