Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > User Innovations
Old 10-19-2006, 05:26 AM   #16
TxAxZxZ's Avatar
TxAxZxZ is on a distinguished road
CDR,
Works great with GGE910 Wireless PC Control Pad.
Have you ever thought about using the controller to respond to each sub menu item? For instance, you're on the main menu. The buttons could be used to direct you to sub-menus like GPS or audio. Once in the GPS menu, the controller will focus on just GPS functions. Common controls like volume and exit back to main menu could be used on all menus/sub-menus.
@ iselfdevi,
I'm not sure what your problem could be. I tried my controller and it showed up instantly. I did notice that I have to switch to analog mode to get the controller to actually work the first time. After that, it works in both modes. I wish I knew how to help you out a little more.
Jeeputer Project
- Design <<< 100% >>>
- Construction <<< 99.5% >>>
TxAxZxZ is offline   Reply With Quote
Old 10-19-2006, 08:05 AM   #17
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Quote: Originally Posted by iselfdevi View Post
yeah i guess theres no support for those who are having problems with this program.
It's been less than 3 days since you posted your problem.
It's a free program written by one guy, it is not a commercial app written by a company with a large development team and support team(who from my experience can sometimes take wekks to get back to you, if at all). You can't expect him to be on the forum 24/7 just for you, he has a normal life outside of here just as we all do.
And with that attitude, if it had been one of my apps I would now be of a mind to ignore your problems.
Enforcer is offline   Reply With Quote
Old 10-20-2006, 07:46 AM   #18
soundoff's Avatar
soundoff is on a distinguished road
Just stumbled across this by accident. I am having the same problem with this that i have been having with version 1.1
Generic USB gamepad
Works in control panel
Works in games
Start app
select "USB GAME CONTROLLER" from dropdown list
press save settings
says "updated settings.ini"
press ok
reports "device unplugged" and "USB GAME CONTROLLER" disappears form the dropdown box
winXP SP1
cant think of any other useful info!
soundoff is offline   Reply With Quote
Old 10-20-2006, 07:49 AM   #19
Curly_cat's Avatar
Curly_cat is on a distinguished road
be patient and wait for an answer. If that isn't good enough for you, go and write your own app
: Jetway J7F2 1.5Ghz Mainboard : Cubid 3688 : CarNetix CNX-P1260 :
: Netgear 802.11g PCMCIA : 2 x LinITX 7" Screens :
: BU353 USB GPS Mouse : Panasonic UJ845 DVDRW :
Curly_cat is offline   Reply With Quote
Old 01-21-2007, 11:24 AM   #20
Carpc6280's Avatar
Carpc6280 is an unknown quantity at this point
I have the same prob as iselfdevi, could someone explain what i'm doing wrong please.
Carpc6280 is offline   Reply With Quote
Old 01-21-2007, 01:15 PM   #21
FreeDrive Creator
CdRsKuLL's Avatar
CdRsKuLL will become famous soon enough
ok fixed the problem with it not detecting some joypads. I have also improved a load of other stuff in it.. I think this is near the final version now.. I will be releasing version 3.0 soon.
CdR
CdRsKuLL is offline   Reply With Quote
Old 10-13-2007, 10:25 AM   #22
One Sharp Cheddar
ThunderStick's Avatar
ThunderStick is on a distinguished road
I must say this has unlimited capabilities. I will definitely be using this...
ThunderStick is offline   Reply With Quote
Old 10-14-2007, 04:33 AM   #23
FreeDrive Creator
CdRsKuLL's Avatar
btw version 3 has been released which has solved alot of the problems. Its on the freedrive site..
www.freedrive.co.uk
just scroll down to the link / picture on that site
CdR
Old 07-26-2008, 01:25 PM   #24
DeadlyAP1's Avatar
DeadlyAP1 is on a distinguished road
great program. I couldn't imagine my carPC without it. I have the gamepad soldered to my car's audio controls.
I was wondering if it would be possible to add some additional functionality in a future release?
There are only a limited amount of buttons on a car's wheel, so I figured it would be great if a combination of two buttons pressed at the same time could do another function altogether.
In other words:
the way it is now:
if button "1" is pressed, it sends command "X"
and if button "2" is pressed, it sends command "Y"
BUT, I would like to be able to press buttons "1 & 2" and then it would send command "Z"
What I would probably do with this is map it so that if I hold down the "mode" button on my wheel, I could then use the "volume control" on the wheel to select next or previous track instead of volume since my car's wheel controls do not have a "next or prev" button.
Make sense? Is this possible?
DeadlyAP1 is offline   Reply With Quote
Old 07-26-2008, 02:36 PM   #25
colin's Avatar
colin will become famous soon enoughcolin will become famous soon enough
Since this is extremely old, I'd say the best way to do this would be through your own software.
Once the key is PRESSED (X), if (Y) is pressed and released, then perform Z. Once the key (X) is released, just perform X.
colin is offline   Reply With Quote
Old 07-26-2008, 03:53 PM   #26
DeadlyAP1's Avatar
Programming is not my bag. If I could have made my own software I would love to. I use RR for my front end.
Old 07-26-2008, 04:00 PM   #27
figfry is an unknown quantity at this point
This is so awesome all last week i was thinking about doing this and wondering if anyone had already done it! Does anyone know if it is adaptable to the old school joystick connection rather than usb? ive got like 2 old joysticks i dont mind ripping apart.
figfry is offline   Reply With Quote
Old 10-10-2009, 07:09 AM   #28
vicky_obee's Avatar
vicky_obee is on a distinguished road
Hi Guys
can some 1 pls post a copy of this software... ver 3.1...
Free drive has some registering prob....
thanks
vicky
Commell LV-677 DC 6 x 6" Mother Board
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
7" InDash Xenarc MTD - X7000 Screen
Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
Parrot MK 6000 & iPhone
Re done the carputer...Into the Glove Box !!
vicky_obee is offline   Reply With Quote
Old 10-10-2009, 10:49 AM   #29
Confusion Master
Enforcer's Avatar
I have uploaded it to the MP3car downloads section, but will not approve it until I get approval from CDR.
Old 10-24-2009, 01:41 PM   #30
vicky_obee's Avatar
Thanks for the upload...
It works fine now
Vicky
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
WTB: M2-atx, USB 2.0 hub, USB 2.0 pci card, etc CavityCr33p Classified Archive 1 01-30-2006 06:57 PM
Nokia Phones [iG] PhoneControl 211 01-19-2005 02:59 AM
lilliput USB controller connector Alric LCD/Display 0 12-12-2004 03:25 AM
usb touchscreen controller, dead or...? Sh0cker Input Devices 6 07-14-2004 02:25 PM
USB Bandwidth Question - PCMCIA card to USB 2.0 timwiththebo General Hardware Discussion 1 07-09-2004 04:47 PM
