Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > User Innovations
Old 03-12-2007, 03:11 AM   #46
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
Quote: Originally Posted by W3bMa5t3r View Post
HMM well if you're getting port open, then MSCOMM.OCX is good and the use of it, but if you're still not getting data... You imported the REG file right? I might have to change the OCX I use for communication... or maybe use the the NetComm.ocx wrapper... :-\ hmm
Thanks for work'n with me on this I've got to have good feedback to get this working, cuz on all the machines I've used it on, it works..
lol
again thanks bro... oh and I should have my new version (new gui and added features) released by morning... for you all to test too. now to just figure out the main part of this whole thing.. lol getting the damn data in...
My question is what is so different between this and PURGPS, which does work?
I did also look at my raw data stream from the GPS - its a mess. About vry third sentence is all zeroes, but the virtual port software tells the ports I have 12 sats locked and discards any bad sentences.
Oh well, goodnight, I'll pick this up again around noon.
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
GizmoQ is offline   Reply With Quote
Old 03-12-2007, 04:51 AM   #47
W3bMa5t3r's Avatar
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
W3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of light
Okie doke folks... See the bottom of the first post. Updated the program to use NETComm.OCX vs the MSComm.OCX, so we'll see if that fixes some issues. Also rebuilt the GUI, added more features and functions.
Let me know how this works for you. I does work for me and all the systems I've tried it on...
Enjoy. There will be more to come. Peace... The W3bMa5t3r
/EDIT: This version has the offline save / upload later feature. You can also make backup copies of your current data log.
W3bMa5t3r is offline   Reply With Quote
Old 03-12-2007, 07:29 PM   #48
Cheekz185 will become famous soon enough
HEy i tried it with the new ver 1.7 and still no good. I install the new netcom things and it still didn't work. I still get that not receiving GPS... Also if i were to set it to a different com port that doesn't have gps feed. i get "could not communicate with com port# and it wont load the app. So obviously it knows that their is GPS data on the correct port and it loads the app but doesn't log data....
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Cheekz185 is offline   Reply With Quote
Old 03-12-2007, 07:45 PM   #49
W3bMa5t3r's Avatar
GRRR ... lol damn. I don't get it. I really can't get it to not work at all on any of the systems I've tried it on. Everything from my carpc to the office computers and even virtual pcs...
Old 03-12-2007, 07:48 PM   #50
What kind of GPS receiver are u using? Are u using a com port splitter? If so which one?
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 03-12-2007, 07:58 PM   #51
W3bMa5t3r's Avatar
I've used an older one, a HICOM 204E, my new one, the BU-353.. both work. And no, I haven't used a port splitter. I think I'm gonna try one now and see if that's affecting it...
Old 03-12-2007, 08:02 PM   #52
try using xport 3....
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 03-12-2007, 08:13 PM   #53
W3bMa5t3r's Avatar
doing it now
Ok... so it doesn't work with Xport3.. hmm interesting... off to investigate...
Old 03-12-2007, 08:39 PM   #54
Playerbeat's Avatar
Playerbeat is on a distinguished road
I think I'm getting the same problem as Cheekz185. When I press gps tracking and as soon as the app receives the first coordinates it gives me the "could not communicate with com port#" error, but I can see the first coordinates come in. It does work when I'm using the logging option. And yes xport doesn't work at all.
7" TouchScreen Carputer
Rockford Fosgate 1501BD and Rockford 551s
12" MTX 9500 in a SS* or a 12" Brahma in a SS*
ZAPCO COMPONENTS in front and RFs in rear
2 YellowTops and a 200amp Iraggi Alternator
*Snell Shell box from nolteaudio.com
Playerbeat is offline   Reply With Quote
Old 03-12-2007, 09:10 PM   #55
doing it now
I should try it with Franson GPSGate
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 03-12-2007, 09:28 PM   #56
Playerbeat's Avatar
did you get it working without any splitters?
Old 03-12-2007, 09:31 PM   #57
no, i had the complete opposite problem with Purdooms Gps app. HIS PROgram DI NOT work unless i was using Xport3....I dont know what it could be THis doesrnt work either or
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 03-13-2007, 02:13 AM   #58
W3bMa5t3r's Avatar
Hey guys, I've been doing some testing tonight and I'm able to pull data from Xport 3... so I just have to fix a few things and I think (and hope) this will fix some of the issues Later...
Old 03-13-2007, 04:49 AM   #59
W3bMa5t3r's Avatar
Ok, I've uploaded 1.8 (Still using the NetComm Wrapper for Mscomm). It seems the sentences coming from the receiver and from Xport vary a bit, so in making it work with Xport... I've crippled the ability to read straight from the receiver. I know most of us are using a splitter anyways, so this might not be a big issue, but I will try to make it compatible to using both. Let me know if this actually does work for you now. I've included the latest Xport3 with the program, along with the NetComm installer.
Cheers... The W3bMa5t3r
Old 03-13-2007, 11:21 AM   #60
WEll I have to say that it does work now with xport3. Im glad about that... But how does the tack to log work? Is it all manual or does it automatically log and then send the data when u get an internet connection. Also the gps connect/disconnect does not work it is just red all the time. But when i first open the APP it flashes green once and thats it!
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
tracking police gps geoff897 GPS 34 10-22-2009 09:29 AM
need a gps tracking solution cheeep L33TZOR GPS 1 09-11-2006 07:53 AM
Interesting GPS tracking software Tred Software & Software Development 15 10-26-2005 08:59 PM
GPS Tracking OriginalNick2 Centrafuse 28 01-21-2005 04:38 PM
