04-21-2004, 04:20 PM
#61
Quote: Originally Posted by Fasthook
Buffer? I don't know.... did a standard install, where can I see if I use the buffer?
David.
In the Click-N-Type software Do you see the chars you click, on the bottom edit window ??
04-21-2004, 05:22 PM
#62
No, there is no text in the bottom window.
04-22-2004, 04:54 PM
#63
@Fasthook Will go thru it in a day or 2 and try to simulate the problem with some other app, if I can simulate the problem then I should be able to solve it. Does it happen with any othe application other that Navigon MobileNavigator ??
Regards
Satish
04-23-2004, 02:26 PM
#64
To be honest: I don't know.... I will try the standard windows 98 apps, I don't have much more installed on the carpc. Will let you know in a few hours!
04-23-2004, 02:58 PM
#65
Could you make a simplified keyboard layout version? Meaning, no F-keys, arrow keys, etc. Just the keyboard, windows key and right-click key.
04-23-2004, 03:10 PM
#66
@[H]Bugster To disable the keys just edit the kb.ini and enter the setting 0,0,0,0 against the key and change the Kb.jpg
Hope this helps
Satish
04-23-2004, 04:41 PM
#67
All other applications I have work with virtualkeyboard :-)
Amazing that the one I need it for is not compatible! I tried
Destinator sdk
outlook express
notepad
winrar
tighvnc
Totalcommander
dosprompt (in window)
I think it has to do with the fact that Navigon uses drop-down boxes to select the city & street. Unfortunately, I can't think of an other aplication I have that uses drop-down boxes to check this.
In the first screenshot: normal keyboar used
In the second: Virtual keyboard. Only as long as I click on the 'L', the 'L' is shown in the navigon drop-down box. As soon as I release the mouseclick, the 'L' disappears in the dropdown box.
If you can't simulate the problem let me know, I can ftp the relevant files for testing...
David.
04-23-2004, 04:50 PM
#68
can you try if OSK from Microsoft works with the app and let me know ?
04-23-2004, 05:02 PM
#69
Good point, switched to windows XP with the standard xp osk: different behaviour, still not good.
When I click the 'L', it selects the first entry in the list that starts with a 'L' in the dropdownbox 'Town'.
When I enter the second letter ('A'), it jumps to the dropdownbox 'Street' and selects the first street that starts with an 'A'. From there on, all subsequent letter appear in the 'street' dropdown box. ???
I can not force the osk to stay in the 'town' dropdownbox
See Navi-5 & Navi-6.
04-23-2004, 08:18 PM
#70
I have another idea. I will implement it tomorrow and send it across to you .
Satish
04-24-2004, 10:40 AM
#71
Fasthook can you try this app and let me know if it works ???
Satish
04-24-2004, 02:58 PM
#72
Sorry, it now behaves like the windows xp osk:
In the first dropdown box 'Town': the first letter is entered as it should (the previous version didn't), but when I press the second letter to narrow down the selection in the dropdown box, the cursor jumps to the second dropdownbox 'Street' and the letter is inserted there.
Strange enough, when I enter a third letter (which is the second letter in the 'street' dropdownbox) to narrow down the selection in the 'Street' dropdownbox, it works as it should! I can enter as many letters as I like in the 'Street' dropdownbox.
Maybe this is because the next entry box is not a dropdownbox, but a entryfield for (house)numbers.
The previous version did not let me enter any letters in the 'Street' dropdownbox.
David.
04-24-2004, 03:00 PM
#73
is it possible to get the software for testing ?
04-24-2004, 05:20 PM
#74
Satish,
I e-mailed you for details....
David.
04-24-2004, 05:23 PM
#75
Mailed you back
| Thread Tools |
| Display Modes |
Linear Mode
