Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > No Longer Supported > V.O.I.C.E.S
Old 02-19-2004, 05:25 PM   #1
SilentAdmirer's Avatar
SilentAdmirer is on a distinguished road
Smile Virtual Keyboard 1.0.0.3 with Sources
Hi,
I thought that OSK would be very difficult to use on a small screen in a car, so I have developed Virtual Keyboard. The keys and the key layout is generated at runtime. It should be OS language independent. Can someone test it and let me know what you think about it. I haven't tested it on Touch screen but if the Touch screen driver just acts as like a mouse it should not have any problem
When you run the application a keyboard icon is placed on the top left of the screen. Clicking that shows and hides the keyboard. The icon always stays on top. To close the application right click on the icon
Following fixes has been made
1.0.0.2:
1) Icon Drag can be disabled from the ini File
2) Hide Btn available on the keyboard (user Defined Position)
3) generation of Dead keys.
4) icon Dragging problem
5) Save last position of Keyboard on Exit.
6) generation of chars when shift key is clicked and caps lock is on
1.0.0.3:
1) On Clicking the Icon, the focus is not lost from the current application
1.0.0.5
1) The Keyboad Dragging can also be diabled
2) Size in percentage can be set in the ini file
http://voices.techworldonline.com/co...d V1.0.0.5.zip
Regards
satish
SilentAdmirer is offline   Reply With Quote
Advertisement Sponsored links
Old 02-19-2004, 05:57 PM   #2
Rireal's Avatar
Rireal
Really nice, no quarks in the 30 seconds I played with it. =D
Rireal is offline   Reply With Quote
Old 02-19-2004, 06:45 PM   #3
PiR-P3's Avatar
PiR-P3 is on a distinguished road
Nice program. I played a while with it and i like it.
Would be nice if you could also save the position of the
keyboard on exit, and restore the keyboard there when started.
When all keys are defined, there will be a problem moving the keyboard
using a touchscreen (no place to hold the keyboard with a finger)`
There are a few little problems ;
the shift-6 character ^ is not on the keyboard but generates
a ^ when pressed.
the \ character is twice defined.
Why are the F6 -F12 keys not defined ?
PiR-P3 is offline   Reply With Quote
Old 02-19-2004, 06:52 PM   #4
R3l0ad is on a distinguished road
Sweet OSK!!! I like it!!!
New CarPC on the way again I think. I miss my old one!!!
R3l0ad is offline   Reply With Quote
Old 02-19-2004, 06:57 PM   #5
I'm sorry, and you are....?
frodobaggins's Avatar
frodobaggins will become famous soon enoughfrodobaggins will become famous soon enough
Clicking or dragging the icon causes the icon top left corner to jump to the mouse pointer.
Other than that, pretty cool.
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 02-19-2004, 06:58 PM   #6
MTWallet is on a distinguished road
a ^ when pressed.
I agree much more useful than XP OSK, I will try it tonight on a touchscreen.
^ was there for me
There was some kind of odd problem that caused all of my open windows to minimize and then none would restore. I could click them in the taskbar, but the wouldn't pop back open. I had to ALT-TAB to one to get it to restore and then they were all OK again.
MTWallet is offline   Reply With Quote
Old 02-19-2004, 07:01 PM   #7
GMajor2003's Avatar
GMajor2003 is on a distinguished road
Nice proggie... just what i was looking for (for once me laptop and screen finally make its way into me car....)
Very nice... impressed
GMajor2003 is offline   Reply With Quote
Old 02-19-2004, 07:18 PM   #8
NotchbackVW's Avatar
NotchbackVW is on a distinguished road
Very nice. All keys defined (exp F6-12) correctly for me. ^ works and only one \.
I asume I can 'skin' it by just swapping the Jpeg? Keep this thread updated with your next update.
Will def be using it if i ever fix my screen...
NotchbackVW is offline   Reply With Quote
Old 02-19-2004, 07:41 PM   #9
teedty1 is on a distinguished road
Quick Request
Your OSK looks great! I just have small request. Is there any way you could add the ability to remove the dragging function of the small keyboard icon? A simple switch in the config file would be great. I just don't want to accidentally move the icon to launch the app while I'm driving.
Is the source code available?
Thanks!
Andy
teedty1 is offline   Reply With Quote
Old 02-19-2004, 07:50 PM   #10
Adam432823's Avatar
Adam432823 is on a distinguished road
Could be just my setup, but I cannot move it to my secondary display. It'll drag over there just fine, but when I release the mouse, it jumps back to primary.
Adam432823 is offline   Reply With Quote
Old 02-19-2004, 07:52 PM   #11
Thanks!
Andy
I would request this too. As pointer jumps to top left of icon it would be very hard (immpossible) to put back in top left with a touch screen and finger! was thinking could match icon in with Skin so becomes 'invisable'. Top left corner, not draggable would be good. Also is only way to shut it down by going ctrl alt del? although not really a prob a guess.
well done so far.
Old 02-19-2004, 07:53 PM   #12
Jumps back for me too
Old 02-19-2004, 07:55 PM   #13
TimmyM's Avatar
TimmyM is on a distinguished road
It worked fine for me to enter a web address in IE but I couldn't add text in Notepad, Wordpad or Word.
I could alt/tab and get the task switcher but it didn't seem to switch the task.
I had IE on top and Word below and when I selected Word, IE still was on top.
Maybe a button on the main keyboard that would make it disappear instead of using the little one.
TimmyM is online now   Reply With Quote
Old 02-19-2004, 07:56 PM   #14
F2-F12 Keys
The F6 to f12 keys are present, to use it all u have to do is define the rectangle where u want the Key. Also the Function keys names are not generated on runtime so you will have to put it on the jpg. Its just to demonostate that the keys you don't want on the keyboard can be disabled by putting a 0,0,0,0 in the ini file.
regards
Satish
Old 02-19-2004, 07:59 PM   #15
Izik is on a distinguished road
very nice, thank you.
Izik is offline   Reply With Quote
Laptop keyboard to the PS2 port.... claylong General Hardware Discussion 8 09-22-2007 07:29 AM
mini keyboard Alphared Input Devices 25 07-27-2004 11:32 AM
virtual keyboard samc Software & Software Development 6 03-17-2003 01:32 PM
virtual keyboard....... Redeyed General MP3Car Discussion 1 03-21-2002 10:57 PM
Disabling BIOS keyboard error? Squeezer General Hardware Discussion 3 02-02-2001 09:29 AM
