Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > No Longer Supported > V.O.I.C.E.S
Old 04-01-2004, 05:06 PM   #46
SilentAdmirer's Avatar
SilentAdmirer is on a distinguished road
will try my best to include it . Can't promise but I want to have that feature too. The plan is to make it like a bookmark. So you can add the current location to the bookmark also in the setting window a button to add fav from search .
SilentAdmirer is offline   Reply With Quote
Old 04-01-2004, 05:20 PM   #47
S4Per's Avatar
S4Per is on a distinguished road
sounds great. any details or progress on interaction with coyote yet as far as MediaCar integration? (last question for the day, I promise ;-) ).
S4Per is offline   Reply With Quote
Old 04-01-2004, 05:40 PM   #48
Jesus Freak
antimatter's Avatar
antimatter is on a distinguished road
Quote: Originally Posted by SilentAdmirer
antimater: I will download latest Media Car and test if I can reproduce the bug. Does it occur when you are moving ?. Tap and Hold should be possible through the Application let me try, I have got some idea.
This happened when the car was at a stand still. Another thing to note if you are trying to recreat this bug is that in the MediaCar setup under the GPS tab you must provide a path to your application, make sure that the "run embedded" checkbox is checked and make sure the "additional search string" has the value *GPSdlt* <--what ever the name of the application is (the name the appears in the taskmanager). The search string allows MediaCar to find the correct application and embed it into MediaCar.
When it is propperly embedded you will see a "close" button and another button on the top right hand corner. The close button is where i am having the problem. This button actually terminates the application. The other button allows the application to run in the background while bringing you back to the MediaCar interface.
This embedding is really handy and I appriciate you looking into it. And thanks for looking into the tap and hold support. This will make it even easier to do searches.
Have a good Weekend,
antimatter is offline   Reply With Quote
Old 04-01-2004, 06:15 PM   #49
See me in my wet t-shirt.
stevieg's Avatar
stevieg is on a distinguished road
Hiya, I've been testing some more through replaying routes to it, I've found that if you re-calculate the route when on a motorway, for some reason (I've tried this about 5 times) it tries to re-route me on 'local roads' - i.e. ones thats aren't on the motorway but next to it that I physically can't get to bar driving off the side of the motorway. Is this a bug with mappoint or this?
Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
Car PC Status: Complete - Undergoing Software Redevelopment
stevieg is offline   Reply With Quote
Old 04-01-2004, 06:17 PM   #50
stevieg's Avatar
I've attached an image of the above as an example
Old 04-01-2004, 06:17 PM   #51
Raw Wave
Laidback's Avatar
Laidback is on a distinguished road
See post #33 & #34
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 04-02-2004, 04:30 AM   #52
stevieg's Avatar
Sorry, was tired and obviously blind
Old 04-02-2004, 12:27 PM   #53
ozoffi is on a distinguished road
@SilentAdmirer: I tested your software and i am inspired - it is really well... more than that!
But I have there a small desire: The position arrow is very small - can i make that larger? Or is it possible to be used drawn of pointer (as in Mediacar)?
Best Regards
Oliver
ozoffi is offline   Reply With Quote
Old 04-02-2004, 12:57 PM   #54
Jesus Freak
antimatter's Avatar
Best Regards
Oliver
If you are referring to the location icons, I have already requested that this be changed to a larger more noticeable icon. I think SilentAdmirer is already working on that.
I am inspired to
Cheers
Old 04-03-2004, 02:48 AM   #55
F4kk3r0's Avatar
F4kk3r0 is on a distinguished road
How to Install???
Where do I put the files I have tried everything but it seems to hang???
F4kk3r0 is offline   Reply With Quote
Old 04-03-2004, 05:15 AM   #56
cwho122 is on a distinguished road
Can this program supports 848x480 resolution?
cwho122 is offline   Reply With Quote
Old 04-03-2004, 06:16 AM   #57
@F4kk3r0 All the the application,dlls and the ini file should be in one directory and there should be a sub directory named skin where the skin should be present.
@cwho122 Not as of now but will in the future.
To all trying to run the application in MediaCar as embedded Application . There seems to be some in the navigation application . Please run it in non embeded mode till I can find a solution.
Old 04-04-2004, 04:27 AM   #58
Jesus Freak
antimatter's Avatar
The main problem is how your little application handles the close event from mediacar. The screen is a little distorted aswell becasue of the top navigation bar but i assume that it can taken care of with the skining.
One thig that i noticed is that when When I input a destination address and my current GPS location is fairly (less than .5 mile) that in the directions it skips the first step.
For instance:
If I should make a left to get get on the free way and then take a right to exit and i am really close the the left turn to get on the free way, then it will skip the left and tell me to "make a right in x miles"
Has anyone else noticed this? Is this a Mappoint Problem?
Old 04-04-2004, 02:53 PM   #59
clemen is on a distinguished road
Where do i get the Windows Speech engine from??
i am running windows xp proff.
clemen is offline   Reply With Quote
Old 04-04-2004, 03:11 PM   #60
Jesus Freak
antimatter's Avatar
you should already have it. If not
GPS NavStar - low cost in-car navigation system mobilegps GPS 7 11-09-2009 09:19 AM
A few observations in OS and why I'm now using Windows 2003... Mastiff Software & Software Development 12 01-21-2004 10:11 AM
X-MP3Pad: Beta testers needed... Please read! PorscheMP3 Software & Software Development 0 08-22-2002 12:55 PM
BMW pre-installed system - TFT ? tsingsu LCD/Display 11 08-05-2002 03:16 AM
My hardware/Software computer control system - Wish list/feedback - Easy power off DarkWolf General Hardware Discussion 22 08-13-2001 02:42 PM
