The MP3car.com Store
Go Back   MP3Car.com > General > Wiki Discussion Threads
Thread Tools Display Modes
Old 03-04-2007, 10:09 AM   #1
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
Audio Tuning via Software
Discussion thread for Audio Tuning via Software. If you would like to add a comment, click the Post Reply button
RedGTiVR6 is offline   Reply With Quote
Sponsored Links
Old 02-05-2008, 12:48 PM   #2
My Photos: (0)
a few questions
- the kx drivers say they don't support any usb devices but i see threads where people are doing software tuning with usb devices, how so?
- i read that tuning needs to have a DSP (like in a regular sound card) to work and "The Bloat" doesn't have one (i'm pretty sure), how are they doing the tuning?
- is console used instead of kx, or with it?
- do i need to use kernal streaming or asio, or does it matter?
i have done a ton of searching and reading (that is how i came up with the questions)
thanks for any help or links to info are also good as long as i don't have to search through 100 pages to find an answer.
the optimizer is offline   Reply With Quote
Old 02-06-2008, 01:47 PM   #3
Car Audio Moderator
durwood's CarPC Specs
durwood's Avatar
Location: Chicagoland - Finally settled in St. Charles,IL
Vehicle: 06 MazdaSpeed6
My Photos: (0)
I haven't seen anyone that is using a USB card with KXdrivers. It's impossible because the USB cards DO NOT use the same DSP chip.
Depends on if the tunning is done via hardware or software. The VST/ASIO method is all software and the DSP is your CPU. The KXdrivers use the built in hardware/DSP chip on the soundcard even though it's software controlled.
Depends on if you want to use VST plugins with your KX compatible soundcard. KX has it's own plugins though, but the VST ones are more powerful. There is a tutorial on how to combine the two in the wiki.
Both bypass windows kxmixer, but some hardware does not like to share ASIO with other software if that makes any sense. kernal streaming output from the software audio player is your safest bet to get it to work with various tuning methods.
durwood is offline   Reply With Quote
Old 02-06-2008, 09:57 PM   #4
My Photos: (0)
thanks for the answers durwood. so how are people doing software tuning and using usb dac's? are they using console?
Old 02-08-2008, 07:42 AM   #5
Car Audio Moderator
durwood's Avatar
My Photos: (0)
hippohifi is the only person that tested the multiple USB DAC thing with console. I don't know of anyone that is actually doing it that way. I think you are better off with a good soundcard that works well with VST's and ASIO.
Old 02-08-2008, 06:37 PM   #6
My Photos: (0)
is using a usb device like something from m-audio the same as a sound card just external?
Old 02-09-2008, 11:28 PM   #7
Car Audio Moderator
durwood's Avatar
My Photos: (0)
Unless the device by itself is specifically stated as a "DAC" then it is a soundcard.
For example, http://www.apogeedigital.com/products/ has DAC only products as well as soundcards.
Sponsored Links
vB code is On
Trackbacks are Off
Software options for Tuning RedGTiVR6 High End Solutions 454 07-23-2008 09:10 AM
Tuning Software Mod TheSin DigitalMods (Scripts / API) 3 09-19-2006 02:52 PM
Audio gateway autoconnect software needed CdRsKuLL Software & Software Development 4 07-01-2005 07:03 AM
Audio problems, Epia Sound, and FAQ stuff gothate Newbie 2 06-16-2005 04:04 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
