04-23-2009, 04:45 PM
#46
mDesktop should be a faster phone control app. Will try.
04-24-2009, 10:39 AM
#47
what about this in streetdeck 2? Like make a digital mod?
04-27-2009, 01:39 AM
#48
Just an FYI for some of you that are trying to get audio across bt. Your BT device has to already be capable of audio in order for you to use it. That is why some of you are having trouble getting audio across BT to cpu.
05-09-2009, 03:30 AM
#49
So, I just got a windows mobile phone and am trying MyMobiler and MDesktop out. Here's the thing. MyMobiler is taking some getting used to and seems slow. I know it's skinable and all but is the standalone app skinable? I mean could I use it without using RR? My frontend of choice is StreetDeck2 and it doesn't support phone integration. My plan is to run one of these programs in the background and when a phone comes in, switch to it with a mapped key. I'd buy and use MDesktop for sure but, it doesn't seem touch friendly at all. Though, I guess while driving the only thing I should be doing is hitting the answer button and selecting from contacts but, even selecting from the contacts list seems non touch friendly. Any ideas?
05-10-2009, 09:43 AM
#50
You can skin the app by editing the defaultskin.xml.
The skinning is a pain really,i've had to edit the xml just to make a skin to remove the top bar.
The latest windows phones are HD anyway so if your in the market for a new phone make sure you buy hd and you'll end up with something like this and no real skinning required.
The only issue i find is there's some lag. (may be different over bluetooth or WiFi,I've yet to test) EDIT: (Now working over BT but its no quicker)
My phones Res is 800 x 480.
P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,ROADRUNNER, iGo8, Custom Freedom 2.1
05-11-2009, 04:38 PM
#51
Man, that skin looks great. Nice work. Here's the deal with my phone, I recently had an accident with my iPhone and had to get a new one. Since I wasn't due for an upgrade yet with AT&T, I figured I'd get one off ebay. Ended up picking up a Blackjack 2. It worked out well since I had seen this app and wanted to try it out anyway. Is it possible for me to use that skin you made with my phone or would I need a touchscreen phone to use it? I really don't get the MyMobiler app too well. There really isn't a lot of documentation for it and the one forum I found for it doesn't seem too highly used anymore for some reason. To be honest, I don't even know how to get the audio to output to the computer speakers. It almost seems like you only use the program to control the phone then need to use the speaker phone to talk. Anyhow, any information or direction with this or other phone control apps would be really helpful. Thanks so much
05-12-2009, 01:23 PM
#52
As far as using what you see above.... you cant because its not a skin,its just my phones display rendered on the pc using MyMobiler.
Thats what MyMobiler does,display's "YOUR" phones screen in a desktop window.
The bottom media buttons in those images are part of the RR skin i use,everything above that is MyMobiler sitting on a black background,audio is via bluetooth as is the connection to MyMobiler.
If your using RR then take a look at post 1 as there's good example of a skin for lower res phones.
05-14-2009, 02:50 AM
#53
are you able to use Internet Sharing while you're in remote with MyMobiler?
05-14-2009, 03:57 PM
#54
I probably could but i dont have it configured that way,it would mean disabling activesync i think.
05-15-2009, 06:41 AM
#55
Is that the touch pro using xbmod rhodium manila? I have been looking into usb host capabilities for this phone but all i have came up with is that there is hardware for it on the phone but only way to access it is through bootloader to flash a new rom. afaik theres no drivers that work on winmo. For this reason, I boight a car pc and will be installing when i figure the hardware out and get my bezel done. Man that TP2 is amazing, I had the Beta C on my fuze but it was a bit too buggy for me
05-15-2009, 06:47 PM
#56
Its a Rhodium/Topaz mix running on a Touch HD.
05-15-2009, 09:08 PM
#57
Not to jack the thread but is that the lastest version? and which icon set are you using? thats a nice looking setup man, especially the htc logo on the start menu.
05-16-2009, 04:24 AM
#58
I'm not sure i get what your asking.
Do you mean in the phone or in the RR skin?
05-17-2009, 03:00 PM
#59
On your phone
05-19-2009, 12:09 AM
#60
griff would it be possible to get you to upload your skin files. I am having some problems maiking one that works landscape and looks good w/RR
-|M10000|-|512mb|-|Morex 3688|-|CDRW/DVD|-|60GB WD|-|7" EX Audio TS|-
| Thread Tools |
| Display Modes |
Linear Mode
