05-19-2009, 03:26 AM
#61
@ Greg, here's a link to the rom = http://forum.xda-developers.com/showthread.php?t=507372
@ Kwiksilver, These files are for 800x480 only,if your phone supports that res then it should work fine (back up your Mobiler folder then paste these files)
P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,ROADRUNNER, iGo8, Custom Freedom 2.1
05-19-2009, 03:56 AM
#62
Hey thanks, now I see what you got going on. Im on the Rapheal so Im waiting for xbmod to get a stable build of the rhodium/topaz port before I upgrade to it. Unlike your Blackstone, the Rapheal has a VGA screen so I gotta wait for the port so it runs right on my phone. Looks good tho, glad to see im not the only one here with an htc.
05-19-2009, 12:40 PM
#63
I hope you don't have to wait too long.
As far as phone intergration goes this looks like being as perfect as i've managed yet.
I've been at it for years now,messing around with a Nokia 6310i,N95,SonyEricsson K800,K850i........never got the results i was after.
The whole solution is coming together now,
I can connect my phone via BT to activsync and get audio handled by BT but then i cant get a serial connection so it looks like i'll connect to activsync via cable,audio via BT which then leaves me a serial port i can connect to so i can get the AT+CLIP (incoming call) data.
I've asked Tempgp to write up an app to monitor the phone to watch for an incoming call and when it see's the CLIP data to fire a command to rr to switch to the phone skin screen and pause the audio.
In theory it all works (i've tested it now) so just wainting on the app to complete the software and then i must fix 2 hardware issues.
The 1st is to get a new BT Dongle,the one i'm using now is running with cracked widcomm stack 5.1.0.1100 and its playing up a little (its auto answering calls when the audio gateway connects).
So i've got my eye on an AnyCom usb 200/500 which has the Broadcom chipset so no need for cracking widcomm 6.x.x.xxxx.
The other is the BT audio echo issue and it can only be fixed by spending £100 quid on the Pheonix Soho conference card so thats what i'll do and then i'm done with the phone part,finally.
05-20-2009, 06:06 PM
#64
Hi
i tried to get my phone to work with Digital FX4.0, but i was unable to. the command line is
LOAD;phoco.skin;C:\Documents and Settings\georga\Desktop\My Mobile\MyMobiler.exe -open;My Mobiler
any help is appreciated.
05-20-2009, 06:39 PM
#65
Try it without the -open switch.
05-20-2009, 10:48 PM
#66
did not work the only thing it does is open the skin!!!!
HELP!!!!!!!!!!!
05-22-2009, 01:35 PM
#67
Quote: Originally Posted by armia1
Hi
LOAD;phoco.skin;Phoco;C:\Documents and Settings\georga\Desktop\My Mobile\MyMobiler.exe -open;My Mobiler
Add the above in bold, and the whole thing needs to be in quotes like the other button commands in the DFX4 exectbl.ini file.
Also, I ran into a problem where things got confused between this and the real PHOCO. To solve I renamed the button PHONE and renamed the skin PHONE.skin. DFX4 was trying to start up PHOCO even though I had the command correct. Renaming everything fixed it for me.
Carputer progress:
100% [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓]
Zotac N630I-D-E M/B w/ Nvidia 7100, Celeron 430 1.8 GHz, Xenarc 700IDT, M2-ATX, RR & DFX 4.0.
05-25-2009, 04:15 AM
#68
if i only added "phoco" to my line as you mentioned and renamed the skin to phone it did not work, because it is looking for phoco!!!
you are a bit hazy when you say renaming everything. please be patient with me as i am new at this. please tell me the files at which you made the changes.
thanks you
05-25-2009, 11:03 AM
#69
The problem I ran into was that I had a new button labeled PHONE but there was still a PHOCO button as well in the DFX4.0 Exectbl.ini file. RR was getting confused somehow because the PHONE button details were calling the PHOCO.SKIN so it wasn't working correctly. Here are the changes I made:
1. In Exectbl.ini my command line is:
"MyApp07","LOAD;Phone.skin;Phone;C:\Program Files\MyMobiler\MyMobiler.exe -open;My Mobiler"
Label for MyApp07 is set to PHONE on the "SetAppLabels" line (too long to put here)
"SetCommandLabels07","SETVAR;MyApp07LB;Phone||SetC ommandLabels08"
2. Rename PHOCO.SKIN to PHONE.SKIN. In this file, change one line at the top:
RRScreen Phone (was originally RRScreen "PhonoControl")
3. Test it out
That's all I did. You can rename the .PNG files too if you want to but I didn't bother.
One other note. On my Motorola Q9h to toggle the speakerphone on/off during a call you press "SOFT 2"->"3". I was able to map a button to do that with the following command:
"ACTIVATE;!My Mobiler||SENDKEY;{F2}||WAIT;0.5||SENDKEY;(3)",""
If I didn't use the WAIT then the "3" would come too fast. Delaying it just a bit makes it work just fine.
Carputer progress:
05-26-2009, 06:24 PM
#70
3. Test it out
hi, i have followed your instruction to the letter and it still does not work. i have tried another skin 506 by Doc breezy, i can can pretty much control my phone except the numbers eg 1,2,3... buttons do not work!!!
go figure, why one skin it works and the other does not!!!!
06-06-2009, 04:17 AM
#71
anybody noe how to use the mymobiler to get the new sms and show it on the screen? or any other way?
06-06-2009, 03:53 PM
#72
MyMobiler simply displays what is on your device screen. If it does not show on your device, it wont show up on the remote screen.
If you have the Manila today screen, it shows the messages on the messaging tab on the main screen.
06-24-2009, 08:57 AM
#73
any other where can bring the contact to the frontend ? and do searching can make call?
06-29-2009, 07:07 PM
#74
Griff1, seeing your screenshot makes me feel like trying MyMobiler again.
Do you have to orientate your blackstone to landscape/horizontal in order to show it likewise on the pc screen?
Btw, what resolution are you running your RR?
If it's 800x600, I would love to get a copy of your MyMobiler skin without the hardware buttons. Although I'm running Centrafuse @ 800x600, it should work fine as well.
When I had my TyTN II, I managed to use Simplistique's skin which had hardware buttons controls in CF. The hardware buttons were useful and sizing was perfect although running MyMobiler as an embedded app in CF was not as stable as I hoped. Somehow after multiple opening and closing of MyMobiler, it goes crazy as more than 1 instance of MyMobiler could be running in the taskbar as MyMobiler already runs an instance the moment the phone is connected. Tried both with and w/o -open parameters. I'm not sure if RR embeds MyMobiler the same way as I only used RR for a short while before switching to CF due to no radio plugin for my Infill G4. Did you encounter the same issue and found a way around it? I recalled changing all possible options in MyMobiler.ini to no avail. i.e. enable/disable trayicon, autoconnect. Wonder how to get MyMobiler running only 1 instance throughout multiple opening and closing which should really be showing and hiding the 1 instance instead.
Anyhow, after I switched to Blackstone, running the skin I posted above, I had problem with the sizing possibly due to the skin with extra hardware buttons I got from here here.
In the end, I got a pda mount that reaches close to my steering wheel which allows me to tap the blackstone with my index finger and in the process gave up on MyMobiler.
If someone could make a skin with hardware buttons that fit the screen, or even better write a plugin with buttons away from the MyMobiler screen it will be perfect but that will probably never gonna happen or take a long long while.
Until then, if you could share your MyMobiler skin, I would love to rekindle my affairs with MyMobiler.
Thanks!
06-30-2009, 11:07 AM
#75
My bad! Just saw the skin already posted! Let me give it a spin.
| Thread Tools |
| Display Modes |
Linear Mode
