Go Back   MP3Car.com > Mp3Car Technical > Mobile device and phone meshing - Connect your car to the internet cloud > Windows Mobile Phones
Old 09-16-2009, 07:27 PM   #16
trader007 can only hope to improve
Quote: Originally Posted by justchat_1 View Post
Seems like a pretty simple but well done design....my only concern would be how well it would handle load dump post-ignition.
yes without making it overly complex, this as shown will draw about 30ma at most when activated (15ma for the relay and another 15 at crazy best for the rest of the circuit) i figure that is negligible even on dead car batteries, its the same as two LED light bulbs....
trader007 is offline   Reply With Quote
Old 09-16-2009, 07:31 PM   #17
Quote: Originally Posted by prodigalsun View Post
With regards to the WM6 VNC server I think I found a free app . I'm a going to test it out but so far it's running on my phone ok. Check it out here. If it goes well then my install will truly be boss.
freakin sweet. i will be trying this too, just for kicks. looks fun... i could freak people out by using my carpc to make my phone do things. people already think im some super crazy mad scientist, this will make it even better.
Old 09-16-2009, 07:36 PM   #18
justchat_1 will become famous soon enough
By load dump I mean the voltage spike that occurs when certain components turn off. In a car when the starter is disengaged the 10A+ that it was drawing dumps into the system causing a voltage spike...in some cars this can be up to 80v.
openMobile - An open source C# Front End
- Currently Recruiting Developers -
Available for download on sourceforge
justchat_1 is offline   Reply With Quote
Old 09-16-2009, 07:38 PM   #19
well i think i will add another larger capacitor to the power legs on both the comparator and the timer. but other then that, most of these components are rated for 50v or more... and its all current limited so i dont see it being a problem.
i will find that out though, thats for sure. my parts should be here friday... also, the power filter coil i will be adding also has capacitance along with the coil itself.
Old 09-16-2009, 08:19 PM   #20
prodigalsun is an unknown quantity at this point
Okay so this thing worked flawlessly. Configured a password, got the phone's ip, downlowed the real vnc viewer and bang I'm in! Only bad thing is on every restart the phones ip changes (just like pc) but other than that it's all good
prodigalsun is offline   Reply With Quote
Old 09-16-2009, 08:27 PM   #21
that sucks about the ip address. logmein wouldnt have that problem... and its actually rare to have a pc change IP addresses, even if its a dynamic IP most providers like to leave them the same for as long as the modem is connected. good thing for you is the phone stays on at all times anyway
edit- wow it does work well. little slow over edge revA, but it works. im trying to see how it does over local wifi now...
Old 09-16-2009, 09:14 PM   #22
Just to clarify, when I say it changes ip just like a pc I meant say you're using a router, the PCs local ip would change and if there there was no modem in between the connection the same thing would happen on the wan side. Similarly, since no modem between phone and the internet the changing ip is expected. The ip changing is not a big thing for me as the the phone is always on (as you mentioned). I guess I could go crazy again looking for a dynamic ip type service/software simlar to dyndns etc but I'll leave that for another day.
Old 09-17-2009, 02:28 PM   #23
So i've finally accomplished everything. I'm attaching all files I used. Here's a quick guide...
On the phone (which you want to log into):
1. Install the VNC server - you may need to use mymobiler to type the password in the config
2. Install the the dns program - either using a dyndns or a noip account
Now to login using another phone use the PPC VNC viewer and to login from a PC use the VNC Viewer for PC - using your name friendly domain name eg. mywmphone.no-ip.org
Hope this saves someone time in the future.
Old 09-17-2009, 08:01 PM   #24
oh i thought you were talking about wan connections. sorry for the confusion.
Desktop PC - Internet problem...? Bimmerstyle Off Topic 13 03-18-2009 04:37 AM
....... Jantsa Wireless Communications 1 04-13-2008 02:09 PM
Project: DIY Dual Remote - 2 remotes in 1! WarriorRocker Input Devices 0 04-03-2008 11:15 AM
ME 2.0 Official Bug Reports phat_bastard ME Archive 67 01-31-2004 07:27 PM
ps2 pelican remote w/ creative reciever & girder ShinkunoNamida Input Devices 0 04-26-2003 03:00 PM
