07-15-2007, 11:11 PM
#1
Installing XP on the SATA Flashdrive
its the same idea... but i had a question so when i have all the programs the way i want them, like all my media programs.... and so forth, and my XP is nlited, has the WEF and the Minilogn thingy all setup on my hd, i want do to the steps in the stiky guide, but when i want to copy over basically the C: drive, do i use the BACKUP command in dos to completely copy the system or what do i use?? Also once the xp has been copied over to the CF card, do i want to delte those DOS bootup files???
08-01-2007, 08:00 PM
#2
Vehicle: BMW 320D M-Sport
so you want to clone your hard drive?
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
08-01-2007, 10:15 PM
#3
i want to be able to take my harddrive and just basically exactly copy it to the CF card so it boots really fast. The original HD will be reformatted, but i will boot and run of the CF card. What do i need to do once i have everything installed on teh HD plus BOotvis, Minlogn, and EWF? How do i copy that exact HD
08-02-2007, 06:37 AM
#4
thats easy just get a hard drive cloning software such as HDClone (it's free!) if you search the forums i have posted a link in a post i made somewhere otherwise just google it, it'l be on the 1st page of results!
CarPuter Progress:
08-02-2007, 07:08 AM
#5
Neither darque nor pervert
Vehicle: 2003 Toyota Tacoma X-Cab
Understand that you're not going to get much of a performance increase (if any at all) by boothing from a flash drive.
My Worklog
08-02-2007, 11:41 AM
#6
cf card i mean, through IDE or SATA than what will get me that faster boot time...
08-02-2007, 08:13 PM
#7
Maybe not speed, but depending on where you live, in cold weather, you will at least boot!
08-02-2007, 08:47 PM
#8
what will give me the most boot up speed performance, that is really obviously what i really want to do.
08-03-2007, 06:39 AM
#9
Neither, as far as I know. Perhaps some of the CF experts could weigh in on this.
A 10,000rpm hard drive.
However, they suck lots of power, so aren't a good choice for a vehicle installation.
Very, very true.
However, that has nothing to do with what the OP is asking about.
My Worklog
08-03-2007, 09:37 AM
#10
so really the CF card is not going to give me a faster boot time. I need a 10,000 RPM HD? Im not sure what to think? I was told originally that a CF card will give me a faster boot time.. But now im not so sure.....,
08-03-2007, 09:57 AM
#11
Typical modern laptop is 5400rpm, desktop 7200rpm, not sure what a CF would give you. Only advantage is they use less power, and silent from what ive read anyway
CarPuter Progress:
08-03-2007, 10:17 AM
#12
Raw Wave
Vehicle: '97 Vauxhall Corsa 1.5 TD
And smaller, and more shock resistant. And lower seek times, so faster where you have bad access patterns across the disk (but slower in raw streaming throughput). And they eventually die if you write too much to them.
If you want a fast boot, look at hibernate or suspend, also consider HORM. Strip down your system as much as possible, turn off stuff you don't use (network is a good one to go).
I unzip windows from a flash disc into a ramdisk and boot from there. That is quite fast (17 seconds cold boot including POST, Win98SE).
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 512Mb flash DOM, 8Gb CF HDD, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
08-03-2007, 11:01 AM
#13
well I think im going to do Nlited XP, EWF, Minlogon, and use a 4 GB CF card, with the IDE adapter. I do not think the SATA adapter will have improved performance, then you suggest installing HORM. I will problably get the MX1 PSU for the Micro ATX motherboard, is there a way to config HORM with that as well. My front end is also centrafuse.
Is this going to be a fast Setup ( the CF card has X266 Speed)
08-03-2007, 11:02 PM
#14
Use HORM Manager Lite from Wechsler Consulting. It's a simple GUI for enabling/disabling EWF and HORM so you don't have to use command line all the time.
http://www.wechslernet.com/english/Produkte.htm
My personal experience has been that HORM actually slows down my boot/shutdown time, probably since I like to have more RAM on my system. There is always that hibernation loading time, and if the system is optimized you can kind of circumvent that.
09-22-2007, 07:55 PM
#15
Quote: Originally Posted by Machinist
Do you still need to do all the manual registry hacks to enable HORM in the first place or does that tool do everything? I am running XPP on the carputer, it would be nice to have a tool that sets HORM up from scratch.
| Thread Tools |
| Display Modes |
Linear Mode
