Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Old 08-14-2007, 02:56 AM   #1
Zorro_X's Avatar
Zorro_X is an unknown quantity at this point
Question XP Home VS XP Pro
Hi all !
Considering that XP home is less expensive than XP pro and that i only need a window API OS to run my embedded car software, i've bought it (home edition). And i'm actually trying to install it with minlogon (sucess) and with EWF into a CF (with a CF to IDE converter). But it doesn't seems to work.
Could it be because i'm using XP home instead of Pro ? (SP2 anyway)
Thankyou in advance for your answers,
Zorro_><
Z-Car Cockpit : http://zcarcockpit.free.fr
Zorro_X is offline   Reply With Quote
Advertisement Sponsored links
Old 08-14-2007, 07:52 AM   #2
walstib's Avatar
walstib is on a distinguished road
Try this. He seems to have it working for Home, Pro and Media Center.
Carputer Project Status:
0% - Mobo died on 2/17/08
Check out the worklog for my '01 Pathfinder.
walstib is offline   Reply With Quote
Old 08-14-2007, 09:42 AM   #3
Zorro_X's Avatar
Thank you, i've downloaded the soft but as i think, the problems goes from my EWF version : i've the 2.0.807.0 instead of the 2.0.927.0 or above required.
I don't undesrtand : i've downloaded the XPe SP2 trial from microsoft like all documentations said in order to get EWF and minilogon. In my repository directory i find only two EWF versions : first one is version 2.0.620.0 and second one is 2.0.807.0. Then no other versions above 2.0.927.0 (!?).
Zorro_><
Old 08-14-2007, 05:21 PM   #4
Zorro_X's Avatar
Thumbs up It's OK !
Thanks to you walstib !
The version required to the installation software give me the clue I need to find out ! doing a google on "2.0.927.0" i've found that : http://www.911cd.net/forums//index.p...c=14181&st=569 telling also that it is not necessary to instal XPe to get EWF & minlogon.
It seems that I forget to install the SP2 of my trial XPe. So now I got the right one and everything goes well !
Zorro_><
Old 08-14-2007, 06:08 PM   #5
walstib's Avatar
Excellent! Glad it worked.
Old 11-11-2007, 11:07 PM   #6
jd520 is an unknown quantity at this point
Zorro-
I think I'm having the same problem that you did. Where did you find the 2.0.927.0 versions of the ewf files? Any way you can PM them to me??
Thanks,
JD
jd520 is offline   Reply With Quote
Old 11-12-2007, 01:00 AM   #7
Zorro_X's Avatar
Hi, i've found it into the SP2 file. I've not installed it, i've just uncompress/unzip it into a folder and look for ewf files.
Zorro_><
Old 11-12-2007, 04:47 PM   #8
Zorro-
Thanks for the quick reply. Do you have EWF working on your system? I keep getting the "error 1" that says it can't find the ewf directory. Any suggestions?
Thanks,
JD
Old 11-12-2007, 09:35 PM   #9
macr6 is an unknown quantity at this point
Quote: Originally Posted by jd520 View Post
Zorro-
Thanks,
JD
I'm getting the same error. Are you setting up your stripped down version of xp on vmware? If so I would love someone to post a fix to this problem.
macr6 is offline   Reply With Quote
Windows XP Pro - Embedded or No? Thelgord WinNT Based 19 02-22-2008 12:54 AM
XP Pro on M9000 wont Hibernate IntegraKarim General MP3Car Discussion 3 03-09-2006 09:58 PM
XP Pro Synchronization cadence117 Wireless Communications 8 05-09-2004 12:33 PM
I just ran bootvis on my xp pro... burnout.no Software & Software Development 11 01-13-2004 12:13 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
