The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Thread Tools Display Modes
Old 04-23-2008, 04:55 PM   #1
coucouillu's CarPC Specs
coucouillu's Avatar
Vehicle: 06' Audi A3 2.0 TDI Exclusive Line 170HP
My Photos: (72)
How to make hardware to install automatically without "Found new hardware wizard" ?
Hi all,
I have been searching for month now.
I am on XP professionnal.
If I change my mouse or my keyboard for USB one, Windows won't automatically install driver for these simple devices. It will ask my help to make the installation (I just need to click on "NEXT").
I would like Windows to instal alone this kind of stuff without prompting with "Found new hardware wizard".
Any help would be appreciated.
Brice.
coucouillu is offline   Reply With Quote
Sponsored Links
Old 04-24-2008, 06:09 PM   #2
galvitron's CarPC Specs
galvitron's Avatar
Vehicle: 2006 Evo MR
My Photos: (0)
Try using the disk that came with the keyboard/mouse. Install the drivers first, then plug the new hardware in. If the disk is done right it will already have the driver installed and auto-detect the device, like when you plug in a USB stick or a USB cd-rom.
Also, you should be able to just do one at a time and use the keyboard or mouse that is still plugged in (one or the other) to get through the install new hardware wizard.
2006 Lancer Evolution IX MR In-Dash PC Project - WIP
Planning:
[----------] 100%
Purchasing:
[----------] 100%
Installation/Fab/Assembly (Revised):
[----------] 80%
galvitron is offline   Reply With Quote
Old 04-25-2008, 12:07 PM   #3
coucouillu's Avatar
My Photos: (72)
Thank you for your answer galvitron.
The exemple of the keybord/mouse was juste an example.
But when you say "Try using the disk that came with the keyboard/mouse. Install the drivers first"...How do you explorer ce CD for the installation without any keyboard /mouse working! They are both USB and are "still" not recognized because they need to install drivers....with PS2 keyboard/mouse that I don't have!
Bios regonize USB but not Windows still the drivers are installed.
Do you understand now?
That's why my question is "How to make hardware to install automatically without "Found new hardware wizard" ? "
and not
"How could I do to make my keyboard / mouse working...."
But thank you again.
Another example, for car PC, Imagine each time a friend would plas his usb stick on your PCCAR becasue he has got some fresh good songs, then when it plug it, Windows can't play it untill you click next in the "Found new hardware wizard"
Old 04-25-2008, 12:20 PM   #4
galvitron's Avatar
My Photos: (0)
When I say try using the disk that came with the device and run the driver install program. It won't detect the device because it is not plugged in but it will copy the driver to system32 folder, which will help windows auto-detect it when it is plugged in. Basically, you need to get it installed once so that every time you plug it in it doesn't ask you over and over.
Planning:
[----------] 100%
Purchasing:
[----------] 100%
[----------] 80%
Old 04-26-2008, 05:04 AM   #5
coucouillu's Avatar
My Photos: (72)
I have understand this.
But how could you explain that for a simple USB keyboard or mousse, the system desn't install alone....The only thing I do is clicking "next" and it installs its own drivers without any CD.
Another example, once I pluged the device in an usb port and installed driver, if I unplug it and plug it again in the same USB port, no problem.
But if I change the USB port, It asks me again to install driver.
Old 04-26-2008, 05:25 AM   #6
Nerd2's CarPC Specs
Nerd2's Avatar
Vehicle: Ford Mondeo 96
My Photos: (0)
I have no explanation for this. Is it a normal XP installation, or have you used Nlite or similar?
Nerd2 is offline   Reply With Quote
Old 04-26-2008, 12:30 PM   #7
galvitron's Avatar
My Photos: (0)
Oh, I see.
Well, just do it for every USB port... Sounds bad, but may fix your problem.
There may be a registry setting to disable the prompt...
Planning:
[----------] 100%
Purchasing:
[----------] 100%
[----------] 80%
Old 04-27-2008, 05:50 AM   #8
coucouillu's Avatar
My Photos: (72)
I am running under XP pro UNLTIMATE (a version made by a man called Mad Dog).
FORUM HERE :
http://www.ultimate-edition.niloo.fr/
I would like email him but I can't register to HIS forum because they stopped registration....The forum is the only way to talk to the team...
Already done to solve my problem for the moment. But I would like find a final solution on my problem.
That's what I am looking for....
I thought found some solutions in "gpedit.msc" services (start-->run-->gpedit.msc) but it doesn't solve the problem.
Old 04-27-2008, 07:35 AM   #9
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Considering you're using a stripped-down version of XP, you may or may not have access to all the utilities and services that a full-blown install of XP would have.
That is the single biggest reason I will not go to TinyXP, MicroXP, GamerXP or BloodyFrigginSmallXP. I don't know what I can/can not troubleshoot and what tools are available to me.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 04-27-2008, 12:02 PM   #10
coucouillu's Avatar
My Photos: (72)
I know about that.
But this version fit exactly for why I need but only this problem is my problem.
I am looking for one person whom know enough on registry to solve it.
Sponsored Links
Old 04-29-2008, 10:30 AM   #11
jonessc's CarPC Specs
jonessc's Avatar
Vehicle: BMW 320D M-Sport
My Photos: (0)
Thinking outside of the box you could use an autoit script that would sit in the tray, and whenever it detected the 'add new hardware' wizard it would take control of window and press next twice.
That would be easy to do in AutoIT
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
jonessc is offline   Reply With Quote
Old 05-05-2008, 05:13 AM   #12
almera's Avatar
Vehicle: 2001 Nissan
My Photos: (0)
Found this, maybe helps:
http://www.msfn.org/board/lofiversio...hp/t49514.html
almera is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
False floor i3igmind Fabrication 29 02-04-2006 10:28 PM
How can I make my install look better? tbird2340 Fabrication 33 10-13-2004 08:02 AM
atari 2600 install / hardware question tracker92 General Hardware Discussion 15 07-21-2004 09:56 AM
can u make destinator 3 install onto pc chris-uk MediaCar 0 04-19-2004 04:30 AM
how do I make my inverter automatically on and off? e36mp3 Power Supplies 3 07-04-2003 08:03 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
