The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Thread Tools Display Modes
Old 04-28-2008, 12:31 PM   #16
Sal R.'s CarPC Specs
Sal R.'s Avatar
Vehicle: 2001 A4 1.8TQMS
My Photos: (31)
Do I need to tweak the registry entries to enable winlogon or is it just a matter of disabling EWF, renaming winlogon.exe.bak back to winlogon.exe and rebooting?
MicroXP / RR v11/04/2007 / Winamp v5.13 / MMIv2
RR Album Art Browser
Sal R. is offline   Reply With Quote
Sponsored Links
Old 04-28-2008, 12:46 PM   #17
jonessc's CarPC Specs
jonessc's Avatar
Vehicle: BMW 320D M-Sport
My Photos: (0)
disable ewf, restart in safe mode (the service is locked) then delete and replace with the .bak version of winlogon, that should work.
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
jonessc is offline   Reply With Quote
Old 04-28-2008, 02:33 PM   #18
Sal R.'s Avatar
My Photos: (31)
Cool. I'll give it a shot tonight or tomorrow. Still looking for a jumper pin so I can set my extra HDD as a slave to I can move my install to the 5400RPM HDD to see if that makes a difference.
Old 05-08-2008, 04:23 PM   #19
navputer's CarPC Specs
navputer's Avatar
Vehicle: 2002 Lincoln Navigator
My Photos: (0)
...and the results was not what I expected.
System:
VIA M10K
512MB RAM
30BG 4200RPM *i think*
Opus 150W
Software:
RR v11-04-07 as shell
WMP9
K-Lite Codec Pack v2.88
Winamp v5.13
iG v3.0
HD Radio
VAG-COM v3.11-N
AI v3.0
w/ all necessary drivers.
From "key-on" to music averages to 38 seconds from cold boot.
From "Key-on" to music averages to 27 seconds from resume.
6 seconds is waiting for the Opus to send the "power on" signal to the mobo.
This is a pretty lean install, right?
Looking at my hardware, my HDD could be a limiting factor. I have a 10GB 5400RPM HDD lying around here that I could swap to. Would that help my boot times?
Eventually, I am going to transfer to a CF card, but want to do an extensive shakedown of the system since what I do here will evenutally be emulated in my carPCv2.0 Pico-ITX install.
My goal is to get a sub 20 sec HORM or cold boot. Is that possible w/ my hardware and software choices?
I really would appreciate the input.
TIA!
I installed MicroXP but I didn't install EMF or HORM installed and I get into windows in 30seconds.
Hardware
VIA MII 10K
1 GB Ram
120 GB WD (5400rpm)
Bluetooth adapter (Belkin)
BU-353 (USB)
iFreedom Wireless Keyboard
M1-ATX
Software
Nero 7
IG 4
SlingPlayer
Word, Excel, Outlook 03
PowerDVD 7
Winamp 5.13
I installed MicroXP cause I wanted faster boot times also. I installed most of my apps but I have not installed RR yet. I wanted to see if I can get faster boot times by using bootvis before I added RR.
Gee
navputer is offline   Reply With Quote
Old 05-09-2008, 11:03 AM   #20
Sal R.'s Avatar
My Photos: (31)
Hardware
VIA MII 10K
1 GB Ram
120 GB WD (5400rpm)
BU-353 (USB)
M1-ATX
Software
Nero 7
IG 4
SlingPlayer
PowerDVD 7
Winamp 5.13
When I first installed MicroXP, i was getting "key on" to desktop in 22 seconds before installing all my usb/serial hardware & software.
Haven't had the chance to work on this, but I'm hoping bootvis can make a difference.
Still having trouble justifying the cost of an SSD, but the performance over my current HDD is undeniable.
Sponsored Links
Old 05-12-2008, 01:16 PM   #21
Machinehead's CarPC Specs
Machinehead's Avatar
My Photos: (0)
You may considering trying a CF Card install. The hardware is a lot cheaper than an SSD.
Machinehead is online now   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Possible solution for saving files on EWF systems (without disabling EWF) SFiorito WinNT Based 11 03-13-2008 01:46 AM
Using EWF on regular WinXP SFiorito WinNT Based 193 06-18-2007 07:50 PM
Minlogon, EWF and HORM - Problem Fuzzy screen menus after HORM hibernate ruairi Operating System Optimization 0 11-30-2005 07:51 AM
Touchscreen problems with nlite and minlogon Ascension WinNT Based 1 06-01-2005 05:18 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
