Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Old 07-04-2009, 09:18 AM   #1
HNaga is an unknown quantity at this point
XP and hardware support
I have something wrong in Car PC XP
it cannot detect Ipod and Internet mobile USB
both are working fine on my laptop.
For th internet USB , software is installed run but it can not detect the network.
For the ipod , when plug it appears for seconds and then disappears.
what do I have to do?
HNaga is offline   Reply With Quote
Old 07-04-2009, 09:43 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Details, man...
Details...
Your post lacks them.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 07-04-2009, 11:40 AM   #3
Quote: Originally Posted by DarquePervert View Post
Details, man...
Details...
OK laptop is Compaq nx7400 with windows XP SP3
Car PC is
CarTFT CFT700-H
Creative Xmod Sound card
VoomPC-2
M2-ATX
Jetway 7F2WE-1G5-OC
1 GB RAM
40 GB HDD
With Windows XP SP3 (XP black Edition)
What else do I have to say?
Old 07-04-2009, 12:48 PM   #4
System specs are a start...
But there's still very little to go on that could aid in troubleshooting.
What have you tried and what were the results?
For the wireles NIC, what sort of wireless network are you trying to connect to?
Is it encrypted? If so, what method?
Are you using Windows stack or the software that came with the NIC?
Are you using drivers from teh CD or did you download newer drivers?
There are lots of details you're missing.
And frankly, an internet forum is a lousy means of troubleshooting anything but the simplest of network problems.
What is XP Black Edition? Is that a stripped-out variant like TinyXP? Have you tried using the network adapter with a full-on install of XP instead?
The same goes for the iPod.
If you want to use the iPod as a portable HDD, it should show up as a removable HDD in My Computer. Does it?
Old 07-04-2009, 02:30 PM   #5
for internet , it's Vodafone internet USB it's Hawawy hardware.
In laptop , I simply plug it and install the software included in it.
Black edition is XP version customized by NLite , I think it misses something but I don't know what exatly.
Yes for Ipod , it appears as removable HDD for seconds then disappears again
Old 07-04-2009, 04:21 PM   #6
I think the problem is likely related to your stripped-out XP variant.
I suggest loading up a complete install of XP and I bet you have all your functionality.
Once everything works, you can use some tools to determine what parts of Windoze are necessary to use your hardware, and begin the stripping down process.
Old 07-04-2009, 04:23 PM   #7
North of the land of Hey Huns
malcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to all
Heh, what do you think one of the things they strip out to make windows smaller is besides drivers and device support?
RevFE - Try it, you just might like it.
Carbon - Next Generation Touchscreen Browser
Come join us on IRC: irc.efnet.net #mp3car
Audiophiles make me chuckle as they pad my wallet.
malcom2073 is offline   Reply With Quote
Old 07-04-2009, 04:24 PM   #8
They strip out a lot more than just help files and that stupid CLOCK.AVI...
Old 07-04-2009, 04:32 PM   #9
XP is very heavy for car pc , lite versions are fine but I think I have to customize one myself or find one made for Car PC.
I know it's something wrong in that Black Edition , I wanted to know what to install instead of re-installing the whole windows , drivers and apps
Old 07-04-2009, 04:35 PM   #10
Reinstall a full version of windows, or make your own "lite" version if you truly believe it actually helps which contains the stuff you need.
Old 07-04-2009, 04:38 PM   #11
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
Well, reloading windows would be a good place to start. This way you'd know if it was hardware or software that's giving you the trouble in the first place. It's hard to troubleshoot a problem like this when you're running a stripped version of XP.
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is offline   Reply With Quote
Old 07-04-2009, 04:40 PM   #12
How fine can they be if they don't have the functionality you need?
Honestly, unless you're trying to squeeze an XP install onto a small flash drive or something, there is no reason NOT to use a full install. Turn off services you don't use to boost your performance and call it a day.
It's impossible to diagnose that on an internet forum.
And unless you know what all the services and features of Windows do in relation to your hardware, you need to load a full version of XP and figure it out.
Old 07-04-2009, 05:41 PM   #13
Thanks m8s
Old 07-05-2009, 01:31 PM   #14
after some tries , I found the problem
It's the number of USB devices I installed in the car
I have 2 powered and 2 unpowered USB ports
the Touch screen is connected to the first powered one
in the second there is 7 port hub for bluetooth , GBS , mobile internet , sound card
I unlpugged all and connected Ipod , i worked fine but when I started plug them one by one , IPod disconnected again.
How to power the hub in the car?
Install Windows XP on a USB Flash Drive kingofl337 WinNT Based 6 10-13-2008 04:14 PM
Bluetooth support in XP SP2 beuz Wireless Communications 5 10-31-2007 07:45 AM
How to remove Bluetooth wireless device support in Windows XP Service Pack 2 Player_One Wireless Communications 5 05-28-2006 05:52 AM
Run WinCE & XP together ShawJohn Software & Software Development 12 11-07-2005 06:09 PM
Disabling hardware detect in XP? ofthedove Software & Software Development 3 11-18-2003 09:01 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
