Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Old 12-15-2004, 06:10 PM   #151
bigman1 is on a distinguished road
How's that doc coming, SFiorito?
Wayne
bigman1 is offline   Reply With Quote
Old 12-15-2004, 10:52 PM   #152
SFiorito's Avatar
SFiorito is on a distinguished road
Sorry, got finals this week. I'll post sometime in between finals tomorrow.
SFiorito is offline   Reply With Quote
Old 12-17-2004, 06:13 AM   #153
SlashEMc2k's Avatar
SlashEMc2k is on a distinguished road
Installing xp now.. onto a fat system. A guide would be good so I could follow it through and test
http://www.mp3car.com/vbulletin/winnt-based/38484-new-ewf-minlogon-cf-instructions.html
Continued here..
Last edited by SlashEMc2k; 12-18-2004 at 06:08 AM.. Reason: add link to continued topic
SlashEMc2k is offline   Reply With Quote
Old 06-23-2005, 04:04 PM   #154
TonioRoffo is on a distinguished road
Sorry for my bashing in on an old thread with my first post, but I have a little secret here that might come in handy for you guys...
I've read that you had problems with front-ends on HORM systems. There is a little trick, but you'll have to use NTFS to get it, first download this:
Sysinternals Junction
Junctions are little known in NTFS. They are similar to hardlinks in Linux: It actually is possible to create an "empty directory" with junction and redirect this directory to a totally different directory... even on other disks!
So you could create C:\Frontends on your C: CF card, and once you enter this directory you find yourself on, for example E:\front - however, all windows apps report c:\frontends.
It might be possible to create a junction like above, and then "install" your frontends to this junction. They will actually reside on your E drive.
Depending on the frontends you are using (I have no experience with it at all), if the config files/states are in a directory on its own, you could install, configure, then *move* this directory to your HD drive. Then create a junction towards it.
Hope this helps out guys...
TonioRoffo
PS. Alternative to CF card booting? Got cash? Check this out: Google for gigabyte iRam....
TonioRoffo is offline   Reply With Quote
Old 06-23-2005, 06:13 PM   #155
SFiorito's Avatar
wow, that's cool. i never heard of that before and i practically live in MSDN!! thanks for the tip!
Old 06-24-2005, 01:34 AM   #156
You're welcome. I was looking at "hacked" EWF for other purposes and wound up here. Couldn't resist to register and tell you about this. Take what you need and give what you can on the 'net!
Keep up the good work guys!
Old 06-24-2005, 01:57 AM   #157
Raw Wave
RoyN's Avatar
RoyN is on a distinguished road
Amazing, can sfiorito or someone confirm that it continues to work with EWF/HORM?
Roy
2005 Range Rover 4.4
RoyN is offline   Reply With Quote
Old 06-24-2005, 02:03 AM   #158
Also, when doing hibernate, the hibernation will only include the junction, and not the contents in the junction.
I just hope it's compatible with EWF, I haven't tested this yet, no time for the moment.
Old 06-24-2005, 02:34 AM   #159
malkalm is on a distinguished road
Are you sure you need to run EWF. I know in windows 2000/XP you can change Ntuser.dat to Ntuser.man. Here is a link how to set it up, it might help you guys out.
http://www.tweakxp.com/article139898.aspx
malkalm is offline   Reply With Quote
Old 06-24-2005, 02:43 AM   #160
Raw Wave
RoyN's Avatar
I'm sorry, what are you refering to malkalm??? I'm not following... EWF isnt to do with a particular user,neither is HORM...please explain
Roy
Old 06-24-2005, 03:01 AM   #161
I thought it might help out, it's a way to make a read only user profile. if any files were added or deleted, all changes would be reset. (added files would be deleted and deleted files would still be there)
Old 06-24-2005, 03:19 AM   #162
Only for files contained in the mandatory profile.
Horm goes beyond this, it's for the *entire* filesystem.
With mandatory profiles, you could still add or remove software, etc. It's just that changes in the currect profile aren't stored.
Old 06-24-2005, 04:43 AM   #163
Raw Wave
RoyN's Avatar
sorry malkalm, i hadnt quite understood, but if it only protects the current files thn HORM might act up... because you will be hibernating one way (frontend one way, etc) and then coming back from hibernation in a different (potentially) state...
Roy
Old 06-24-2005, 08:29 AM   #164
SFiorito's Avatar
malkalm, the reason we use EWF is to protect the whole disk from any writes as well as to use HORM for faster and more reliable booting. we're not looking to simply protect the user profile.
i'll test the junction out today.
Old 07-26-2005, 11:52 PM   #165
smkau18 is on a distinguished road
Need some help guys, i am really new to this and was following the instructions in the EWF.zip file.
I made the ewf1.reg file but when I double click it 'to add the information to the registry,' I get an error saying that "cannot import...error accesing the registry." I have given the directroy full access.
Yet when I look in
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\R oot\........
I can't find the folder entitled "LEGACY_EWF"
I have no idea what im doing wrong, any help would be greatly appreciated
smkau18 is offline   Reply With Quote
Will OPUS work with regular P4 Motherboard badandy4you Power Supplies 3 06-22-2004 01:55 AM
slim dvd vs. regular dvd cybermob2 Power Supplies 28 03-22-2004 01:47 PM
TM-701L & Geforce 4 also a regular TV!! Mp3Goose_Your King LCD/Display 3 03-25-2003 01:59 AM
Com Ports not working in WinXP on EPIA-M Defiler General Hardware Discussion 25 12-16-2002 03:26 PM
FV24 and WinXP BRINET General Hardware Discussion 3 04-19-2002 02:00 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
