Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Old 07-27-2005, 04:14 AM   #166
knubile's Avatar
knubile is on a distinguished road
You have to gran full access on the enum\root key.
knubile is offline   Reply With Quote
Old 07-27-2005, 09:19 AM   #167
smkau18 is on a distinguished road
I have granted full access on the "enum\root" key
I still have the same problem.
smkau18 is offline   Reply With Quote
Old 07-28-2005, 12:29 AM   #168
sorry me stupid
I didn't give full access to enum key...only root key...now it works
thanks
Old 02-19-2006, 09:28 PM   #169
proph's Avatar
proph is on a distinguished road
ha... I did the same thing too..
proph is offline   Reply With Quote
Old 02-21-2006, 03:27 AM   #170
TonioRoffo is on a distinguished road
Is there a *legal* alternative for EWF? I'd like to boot networked computer off iSCSI and redirect writes to *other* iscsi disks... RAM writes aren't enough, because these computers will be using roaming profiles.
EWF would do just nicely but it's not ok with the MS EULA... can't just take a few things out of a XPe and transfer them to XP installs.
Closest thing I've found is Netboot/i - this will enable any XP machine to boot from iSCSI, and optionally redirect writes to RAM. In my situation, the RAM would be eaten up quite rapidly.
If money is no objection, neoware image manager can do all of the above, but you can't buy it below 50 users.
TonioRoffo is offline   Reply With Quote
Old 03-04-2006, 12:24 AM   #171
rcdash's Avatar
rcdash is on a distinguished road
Question Using HORM and a paging file???
Sorry to jump in here, hoping to get some help: I've got a burning question that I cannot find an answer to anywhere on the net...
If you set up HORM to protect your OS boot volume (e.g. C: ), can you still use a paging file on an unprotected volume (e.g. D: ) to permit virtual memory functions?
If so, then when you resume from hibernate that paging file will be invalid as it will be from a different state than the fixed hibernation file.
How to fix this?
I need to have a paging file but I would like to use HORM.
Any thoughts?
rcdash is offline   Reply With Quote
Old 11-26-2006, 04:04 PM   #172
coucouillu's Avatar
coucouillu is an unknown quantity at this point
Is there a solution for :
A EWF protected drive with the OS and file for hibernation on another drive linked with "junction.exe" or "hardlink.exe" ?
coucouillu is offline   Reply With Quote
Old 11-26-2006, 05:44 PM   #173
SFiorito's Avatar
SFiorito is on a distinguished road
no, have you tried it? i've never tested that so it'd be interesting to know if it works. Although, nowadays flash memory is so cheap that it may be easier to just buy a larger drive so you don't have to worry about storing the hibernation file on another drive.
SFiorito is offline   Reply With Quote
Old 11-27-2006, 01:33 AM   #174
coucouillu's Avatar
Hi SFiorito,
I wished you would be the first to reply.
I also hoped YOU had test it and had the answer (and the tutorial )
So i will work on it soon ( i first have to send back my broken Jetway motherboard for a replacement )
Old 11-27-2006, 04:13 PM   #175
coucouillu's Avatar
I don't want to put the file on another drive because of size problem...But only for Write protection problem.
If EWF enable on C:, I won't be able to write on C, so the RAM context won't be written in the file on the C:.
But if i hard link the file on C: to a file on D: which is WRITE enabled, I think i will be avle to store the RAM context.....
Old 11-27-2006, 04:44 PM   #176
SFiorito's Avatar
Hibernation bypasses EWF. There's no need to place the hiberfil.sys onto another drive.
Old 11-29-2006, 03:27 PM   #177
coucouillu's Avatar
Great news !!!
So I will continue my idea on Programs files folder.
For exemple in Centrafuse I use, when I change setting and save them, It doesn't save the "settings.xml" (like ".ini" file) due to the write protection.
I will "hardlink" this file and other like it which need to be updated for settings and others...
Old 05-07-2007, 11:00 AM   #178
Mdct is an unknown quantity at this point
EDIT: The problem is solved.
Mdct is offline   Reply With Quote
Old 06-03-2007, 05:57 PM   #179
rdc_3200 is on a distinguished road
Hey guys, I've recently tried to get the whole EWF/HORM thing working on my carputer. I got as far as replacing the ntldr file, and updating the registry...when I restarted, I got a ntldr cannot be found...so I had to re-install XP...
I'm guessing that I didn't have the registry file configured to the proper partition; I'm not planning on using a CF card and was wondering if there was a way to find out which partition location I have to put in the "archname" location...
Or am I totally off and messed up some other part of the installation? Any input would be appreciated.
rdc_3200 is offline   Reply With Quote
Old 06-04-2007, 02:17 AM   #180
masch
What partition do you have WinXP installed?
Do you have multiple harddrives?
New Lilliput EBY701 For Sale http://www.nusantech.com/index.asp?c...at=TOUCHSCREEN
SiRF3 Bluetooth GPS http://www.nusantech.com/index.asp?cat=GPS
masch is offline   Reply With Quote
Will OPUS work with regular P4 Motherboard badandy4you Power Supplies 3 06-22-2004 01:55 AM
slim dvd vs. regular dvd cybermob2 Power Supplies 28 03-22-2004 01:47 PM
TM-701L & Geforce 4 also a regular TV!! Mp3Goose_Your King LCD/Display 3 03-25-2003 01:59 AM
Com Ports not working in WinXP on EPIA-M Defiler General Hardware Discussion 25 12-16-2002 03:26 PM
FV24 and WinXP BRINET General Hardware Discussion 3 04-19-2002 02:00 PM
