Okay, here's what I compiled from this thread and MSDN docs. There are some slight changes to the reg settings that I need to test out when I get home.
Making an EWF enabled XP installation
1) Install XP like you normally would, whether it's an nLite, XPLite, or regular install.
2) Retrieve the EWF files: ewfmgr.exe, ewf.sys, and ewfntldr
3) Place ewf.sys in \WINDOWS\System32\drivers
4) Place ewfmgr.exe in \WINDOWS\System32
5) Place ewfntldr on the root of your boot drive. Rename ntldr to ntldr_bak and rename ewfntldr to ntldr.
6) Configure XP to minimize writes as much as possible. EWF basically creates a RAM drive where all changes are stored in RAM, so the more changes you
make to your protected volume the more RAM it'll take.
a) disable the paging file
b) disable automatic disk defrag and autolayout:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Dfrg\BootOpt imizeFunction]
"Enable"="N"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\OptimalLayout]
"EnableAutoLayout"=dword:00000000
c) disable Last Access timestamps:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\FileSystem]
"NtfsDisableLastAccessUpdate"=dword:00000001
d) disable Prefetch:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Session Manager\Memory Management\PrefetchParameters]
"EnablePrefetcher"=dword:00000000
e) disable System Restore
f) depending on your configuration you can also relocate your eventlogs to a non protected partition:
http://msdn.microsoft.com/library/en...OfEventLog.asp
g) same with your webbrowser temp files
h) MSFT even recommends using a FAT filesystem if you don't require the security features of NTFS as this will improve EWF performance even more.
7) Enter the following registry values into your registry:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\R oot\LEGACY_EWF]
"NextInstance"=dword:00000001
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\R oot\LEGACY_EWF\0000]
"Service"="EWF"
"Legacy"=dword:00000001
"ConfigFlags"=dword:00000020
"Class"="LegacyDriver"
"ClassGUID"="{8ECC055D-047F-11D1-A537-0000F8753ED1}"
"DeviceDesc"="EWF"
"Capabilities"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\R oot\LEGACY_EWF\0000\Control]
"ActiveService"="EWF"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\ewf]
"ErrorControl"=dword:00000001
"Group"="System Bus Extender"
"Start"=dword:00000000
"Type"=dword:00000001
*NOTE*: For the following key, ADD Ewf to the existing value which should be volsnap.
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{71A27CDD-812A-11D0-BEC7-08002BE2092F}]
"UpperFilters"="Ewf"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\ewf\Parameters\Protected\Volume0]
"ArcName"="multi(0)disk(0)rdisk(0)partition(1) "
This last entry, ArcName, needs to match the partition you want to protect. If you want to protect more than one volume then just add another key named
Volume1 with the appropriate entries.
8) Reboot!! If you get a boot error then just boot up with Last known good configuration. That will probably kill all the registry entries you entered,
but you probably forgot something so do it again and make sure the EWF files are in the right places.
9) Once you boot up open up a CMD and run "ewfmgr n:" n being the drive letter of your protected volume. If it says it didn't find an EWF volume then you
messed up, otherwise it should show info on your protected volume.
10) If you need to make configuration changes to windows or install software then disable EWF by running "ewfmgr n: -commitanddisable -live" n being your
protected drive. This will COMMIT any changes and DISABLE EWF immediately. Once it's done go ahead and do whatever you want, but BEFORE YOU REBOOT run
"ewfmgr n: -enable" n being your protected drive so that EWF will be reenabled after you restart.
11) Hibernation is possible on a volume protected by EWF, but first create an empty file on the root drive (where you installed the special ewfntldr)
called resmany.dat. Just right-click and create textfile and rename it resmany.dat. That's it. Obviously you need to do this with EWF disabled. Once that
is done reenable EWF and RESTART so that EWF can protect the volume again. THEN you can hibernate. This will allow you to ALWAYS resume from the same
hibernation state. There is no need to hibernate every time you shutdown, unless you want to change the state. For a CarPC system you would obviously
hibernate with your frontend running.
12) You need to really think about what you're doing with an EWF system because you don't want to make tons of changes without disabling EWF, or
disabling EWF and then forget to reenable it. Take into consideration configuration files that may change (such as a frontend saving its state... if it
saves it on an EWF partition it'll be gone when you resume!!).
13) This system will allow you to run a regular XP install from a CompactFlash disk. MSFT has some good information on booting from CF disks and
deploying your OS to CF, even if they are marked as removable:
http://msdn.microsoft.com/library/en...mpactFlash.asp
Spend the time to read through MSDN XP Embedded docs!! There's lots of good info on there about EWF, but also on streamlining your system and improving
boot speed.
Let us know if you find anything new!!!
S/F,
Frito
