Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Old 12-07-2004, 07:36 PM   #121
knubile's Avatar
knubile is on a distinguished road
Which adapter did you get? I have my CF card already. Waiting for my adapter. I got this one.
It fits right in the same place as a laptop drive. Same screw holes and everything.
I also ordred a 99 cent one off ebay for ****s and giggles. I doubt it'll fit on the eden board.
knubile is offline   Reply With Quote
Old 12-07-2004, 07:56 PM   #122
SFiorito's Avatar
SFiorito is on a distinguished road
The original I got (that doesn't work) is from acscontrol. I saw them mentioned a lot online so I figured it would be safe... So I just ordered one from that other site (I guess the forums automatically edit out the name). It sucks too, because I was all ready to roll. All I needed to do was copy the files over to the CF card and boot up!! I even acquired the SanDisk utility to modify the removable flag so that the drive is fixed. That way I can partition it in XP and don't need to run bootprep in dos, but because of the stupid IDE adaptor I can't even do that!
SFiorito is offline   Reply With Quote
Old 12-07-2004, 10:33 PM   #123
knubile's Avatar
Think that sandisk utility works on other CF cards.
Old 12-07-2004, 10:54 PM   #124
SFiorito's Avatar
No, it's specifically for the new SanDisk models. You should contact your CF manufacturer's tech support to get their utility. Actually search google groups to see what other users did. You should find a lot of XPe developers talking about the removable bit or flag. Apparently you can order the "industrial" grade cards that come from the manufacturers preconfigured as fixed disks, but they tend to cost more. SanDisk only lists 3 places and they're not online stores for Joe Shmoe, so I don't know if that's possible for users like us. I wasn't sure beforehand, but I read tonight that EWF doesn't load when it sees it's trying to protect a removable drive. I thought I had read earlier that the whole point of RAM Reg mode was to support such devices that can't be partitioned, but I guess that wasnt' it. The utility I have is supposed to work on Ultra, UltraII, and Extreme cards. We'll see once I get my new CF-IDE adapter.
Old 12-08-2004, 09:30 PM   #125
SFiorito's Avatar
Okay... this is incredibly embarassing but... my CF-IDE is okay. The problem is that I was using the new style IDE cables when instead you need to use the older ones. News to me. Luckily I had an old cable lying around from an old PC I gutted. So now I have an extra 1GB disk and another CF-IDE adapter on the way... awesome. I guess I'll use them for my next project. Anyways, here's the process I used to deploy my OS to CF:
1) Get a DOS bootdisk and put bootprep from XPe on it.
2) I set up my system with the CF card by itself on the primary controller and my DVD and HDD on the secondary controller. Since my slim DVD can only be master, my HDD was slave.
3) Boot up to DOS and run fdisk, then format c:, and finally run bootprep /dc (/dc denotes the c drive, /dd d drive, and so on).
4) Copy the files from your HDD to your CF. I used knoppix to do a copy. Don't just use the DOS copy command because it'll ignore hidden files. Using knoppix it was pretty quick. Originally I tried partimage on knoppix until I realized it wasn't worth the extra steps.
5)Shutdown and remove your HDD. Reboot and it should boot into XP from your CF card. The first time you boot it MAY not load EWF properly. I think this happened for me because I had my HDD still plugged in, but I just shutdown, removed it, rebooted, and EWF was back fine.
That's it!! If you're having problems re-partition your disk and run format c: /s to make it boot into DOS just to see if you can boot up period. If you don't have a utility to turn your removable drive into a fixed drive you should be fine with the directions I gave you. I'm running my system with FAT32 because that's what MSFT recommends for speed and less overhead when running on a CF card. If you want to use NTFS you need to turn your card into a fixed disk and you don't need to run bootprep.
It seems pretty quick to me, but then again I can only compare it to my ****ty old Maxtor drive. My SanDisk cards supports DMA show up in XP as using Multi-Word DMA Mode 2) whereas some other cards only use PIO which isn't so good. No benchmarks yet because I'm still tuning... okay, I've been getting about 17-19 second cold boots.
Have fun!!!
Old 12-09-2004, 04:40 PM   #126
SlashEMc2k's Avatar
SlashEMc2k is on a distinguished road
Thumbs up
SFiorito, knubile
I was looking for something to boost up my xp carputer. and you guys have done it.. Ordering my CF card and adapter today
Just need to tweak the boot speed about 10 secs more and that will be impressive.
SlashEMc2k is offline   Reply With Quote
Old 12-09-2004, 07:02 PM   #127
SFiorito's Avatar
Hey knubile, you get your card yet?
I don't know how much faster we can get without faster flash cards. My system is currently running on the slower of two cards I own. Tonight I'll test it out on the faster card. SanDisk has an even faster card coming out very soon so that should be really sweet!! Some people have talked about making a front end as the default shell. That MAY speed things up, but only if the shell is quick to startup itself, otherwise it'll be the bottleneck instead of explorer. Tonight I'll also do a bootvis trace to see what exactly is slowing it down, because loading the drivers and such goes by pretty quickly. Once the progress bar hits the end it sits there and thinks for a few seconds. Hopefully it's something that can be tweaked. One thing I'm worried about is all the devices I plan on having plugged in: GPS, XM, FM, WiFi, etc. That's going to slow things down as well probably. We'll see.
Old 12-09-2004, 08:18 PM   #128
knubile's Avatar
I have my card. No adapter though. I'm going to tweak the install on my laptop drive now while I wait. Running bootvis as I type. Next step, minlogon.
I want to try to get away without using hibernation. It's amazing, but the current front ends don't work very well with it.
So as a temporary measure, I'd like to avoid hibernation altogether.
Old 12-10-2004, 12:51 AM   #129
SFiorito's Avatar
I think you could do without hibernation. It's only like 1 or 2 seconds faster on mine so it's not a huge difference. I don't know if BootVis will do anything for flash cards since they've got hardly any seek time. I've tried running it on mine, but it made no difference. I just tried running defrag and disabling automatic chkdsk on bootup. That shaved off another second or so since chkdsk was running every bootup. It thinks the drive is corrupted I guess due to EWF. If you've got a bootlog.txt file on your c: drive it's running. Search for BootExecute in your registry and just remove the entry.
Old 12-10-2004, 01:06 AM   #130
SFiorito's Avatar
Standby is fast as hell with the CF card... WOW!!! I'm guessing it's due to the flash disk no spin up time? And my powersupply fan even shuts down, whereas with the HDD it stayed on. I'm just going to use standby in my car! The Opus will automatically shut off if the battery gets low, right? Don't need to worry about clean shutdown with EWF anyways. Awesome!
Old 12-10-2004, 01:29 AM   #131
Nic
Nic's Avatar
Nic is on a distinguished road
so what hardware are you using? please be specific
Signature: [==||========] 20% complete
Nic is offline   Reply With Quote
Old 12-10-2004, 08:32 AM   #132
SFiorito's Avatar
VIA MII 1Ghz, 512MB RAM, acscontrol CF-IDE adapter, SanDisk UltraII 1GB, Panasonic slim DVD/CDRW.
Old 12-10-2004, 09:11 AM   #133
Nic
Nic's Avatar
how fast was hibernate please? i'm trying to work out if i should use a hdd or a flash card for my OS drive, i'm gonna use a removable usb one for media, makes syncing easy
Old 12-10-2004, 09:35 AM   #134
SlashEMc2k's Avatar
I`m planning on having a flash card. Either the SanDisk UltraII 1GB optimized CompactFlash cards that have a minimum sustained write speed of 9MB per second and a read speed of 10MB per second. But the NEW Lexar 80x 1GB Compact Flash 1 GB PRO CompactFlash card delivers 16MB/sec read 12.0MB/sec write.
The Reason for this is I dont want my hard drive to be shaken about in my tiny roadster and screwing with the harddisks inside corrupting the data.
Looking into which CF-IDE adapter to buy
Im a bit confused between the differences with the old and new ide cables that SFiorito mentioned..
Old 12-10-2004, 12:28 PM   #135
SFiorito's Avatar
This http://www.robgalbraith.com/bins/mul...?cid=6007-6133 is the data I used to decide to go with the UltraII and Extreme cards. Take a look at the Extreme III cards up top!!! As far as IDE adaptor, the acscontrol one I have seems to work fine. I haven't tested out the other one yet because it takes the smaller 3V connector and my powersupply only has one (being used by my DVD drive). The acscontrol adapter takes the 5V connector. What I mean by the older IDE cables is ata33 cables (I guess that's what they are), not the udma ata100 cables.
Hibernation seems to be about 2-3 seconds faster booting up (16 - 17 seconds versus 18-20 seconds cold boot). Now, keep in mind that I haven't loaded up a frontend yet so depending on the startup times for the frontend, cold boot may be signficantly slower than hibernation (which will have the frontend already up and loaded). Knubile says the frontends don't handle hibernation very well so it may not even be an issue of whether we need to cold boot or not. How do the frontends handle standby? Because that's what I'm planning to use.
Will OPUS work with regular P4 Motherboard badandy4you Power Supplies 3 06-22-2004 01:55 AM
slim dvd vs. regular dvd cybermob2 Power Supplies 28 03-22-2004 01:47 PM
TM-701L & Geforce 4 also a regular TV!! Mp3Goose_Your King LCD/Display 3 03-25-2003 01:59 AM
Com Ports not working in WinXP on EPIA-M Defiler General Hardware Discussion 25 12-16-2002 03:26 PM
FV24 and WinXP BRINET General Hardware Discussion 3 04-19-2002 02:00 PM
