12-22-2004, 04:43 AM
#151
Registered User
At work ATM, but off the top of my my head I didn't change anything from the Zip when I unzipped it into the root of my Nlite build folder
[COMMANDS]
"REGEDIT /S fetlyd.reg"
4x4 in a turbo stylee.
12-22-2004, 05:54 AM
#152
If anyone wants the source for fetlyd.exe, here it is.. Coded in Delphi 4.. Please don't laugh!
Code:
program fetlyd;
uses
Windows, SysUtils, Classes, Forms, registry, shellapi;
{$R *.RES}
var
Reg: TRegistry;
L1: TStringList;
X: Integer;
S: String;
begin
Application.Initialize;
renamefile(extractfilepath(application.exename)+'winlogon.exe', extractfilepath(application.exename)+'winlogon.bak');
renamefile(extractfilepath(application.exename)+'minlogon.exe', extractfilepath(application.exename)+'winlogon.exe');
try
Reg := TRegistry.Create;
L1 := TStringList.Create;
Reg.RootKey := HKEY_LOCAL_MACHINE;
if Reg.OpenKey('\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon', True) then
begin
reg.GetValueNames(L1);
For X := 0 to L1.Count -1 do
Reg.DeleteValue(L1[X]);
L1.Clear;
reg.GetKeyNames(L1);
For X := L1.Count -1 downto 0 do
if L1[x] <> 'Credentials' then
if L1[x] <> '' then
reg.DeleteKey('\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\'+L1[X]);
end;
Reg.CloseKey;
Reg.LazyWrite := false;
Reg.OpenKey('Software\Microsoft\Windows\CurrentVersion\RunOnce', false);
Reg.WriteString('Delete Me!','command.com /c del '+application.exename);
Reg.WriteString('Delete Me! #2','command.com /c del '+extractfilepath(application.exename)+'minlogon.reg');
Reg.CloseKey;
WinExec(pchar('regedit.exe /s ' + extractfilepath(application.exename)+'minlogon.reg'), SW_SHOWNORMAL);
ExitWindowsEx(ewx_Reboot,0);
finally
Reg.Free;
L1.Free;
end;
Application.Run;
end.
12-22-2004, 06:00 AM
#153
Registered User
If it works don't knock it.
12-22-2004, 06:03 AM
#154
12-22-2004, 01:31 PM
#155
Registered User
Any suggestions why the commandlines.txt didn't work?
Would be interested in cracking this one, and moving onto adding other apps in a similar way, and enabling EWF, so when the hardware is assembled, the CarPC will be closer to going in.
12-22-2004, 03:01 PM
#156
Registered User
I've checked, and double checked, and even changed the path in the fetlyd.reg to read
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\RunOnce]
"Fetlyd"=fetlyd.exe
instead of
[Software\Microsoft\Windows\CurrentVersion\RunOnce]
"Fetlyd"=fetlyd.exe
and it didn't work.
12-22-2004, 04:35 PM
#157
Registered User
BTW, some success, edited fetlyd.reg to read
"Fetlyd"="C:\\Windows\\system32\\fetlyd.exe"
And it worked fine
12-22-2004, 07:46 PM
#158
That's weird.. My windows directory is also C:\windows, and it worked ok..
But anyways, I'll update the program to read %windir%\fetlyd.exe instead of just fetlyd.exe .. Thanks man!
BTW, Merry Christmas!
12-22-2004, 09:36 PM
#159
In case anyone is interested I managed to get things down to about a 10 sec app launch with frodoplayer as shell instead of explorer. One of the side effects of not having explorer as shell is that you get to see the OS component load times.
system specs
epia M10k
512meg ram
seagate 5400 rpm laptop drive
WinXP-SP2 default install + minlogin
Services running
Windows Audio, Event Log, Network Connections, Plug an Play, Remote procedure call, Task Scheduler, Windows Management Instrumentation
Prefetching is active.
The one thing (other than running many services) that seems to really make the time vary between 10-18 seconds is prefetching. A "bad" (for lack of a better work) boot prefetch file can result in boot times of 18-20 sec. I'm still learning about how prefetching works so if anyone has any insight into prefetching I'm all ears. Disabling prefetching results in about 14-18 sec app start time for frodo (depends on the services that are running).
One note on using Bootvis with frodo as shell. Bootvis will not automatically start up. You have to manually launch bootvis by configuring frodo's app launcher and launch bootvis. You should also add explorer to the app list in case you want to make some service changes etc. If you start a boot trace and do not stop it the trace file can become quite large...
Just thought I'd share.
-Momanz
12-22-2004, 09:52 PM
#160
Hi!
Excellent post, momanz!
ATM I'm installing the latest nlited xp, i'll post how it ends..
12-23-2004, 03:44 AM
#161
Registered User
All I have to do is now is work out why I get an error one with EWF.
12-23-2004, 05:45 AM
#162
Doublecheck all the registry entries.. maybe you forgot one?
12-23-2004, 05:50 AM
#163
Registered User
I copy and pasted the ones listed on the thread about ewf, but I will double check. Cheers.
12-23-2004, 05:52 AM
#164
Did you remember this one?
Code:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ewf]
"ErrorControl"=dword:00000001
"Group"="System Bus Extender"
"Start"=dword:00000000
"Type"=dword:00000001
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{71A27CDD-812A-11D0-BEC7-08002BE2092F}]
"UpperFilters"="Ewf"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ewf\Parameters]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ewf\Parameters\Protected]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ewf\Parameters\Protected\Volume0]
"VolumeID"="{1EA414D1-6760-4625-8CBE-4F9F85A48E15}"
"ArcName"="multi(0)disk(0)rdisk(0)partition(1)"
12-23-2004, 06:32 AM
#165
Registered User
Code:
Will need to double check that when I get home from work, cheers.
| Thread Tools |
| Display Modes |
Linear Mode
