Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Old 12-23-2004, 06:35 AM   #166
SlashEMc2k's Avatar
SlashEMc2k is on a distinguished road
Make sure you have the right ewf.sys its in the right directory system32/drivers
and you have the correct ewf manager in system32 dir.
I kept getting the error1 it was because I was using ewf FROM XPE SP1 and not SP2
SlashEMc2k is offline   Reply With Quote
Old 12-23-2004, 06:41 AM   #167
Registered User
Skraggy_uk's Avatar
Skraggy_uk is on a distinguished road
Yep
yep
I used the ones from the EWF.zip, EWF and minlogin archive that was posted to the thread.
4x4 in a turbo stylee.
Skraggy_uk is offline   Reply With Quote
Old 12-23-2004, 08:57 AM   #168
SlashEMc2k's Avatar
So you downloaded and used this file:
http://test.crimsonstain.net/EWF.zip
Did you read this forum aswell to see the problems I had?
http://www.mp3car.com/vbulletin/winnt-based/38484-new-ewf-minlogon-cf-instructions.html
Old 12-23-2004, 09:02 AM   #169
Registered User
Skraggy_uk's Avatar
Yesm think that was the ones I used.
Ah no, didn't see those. Wil read that thread.
Old 12-23-2004, 11:28 AM   #170
QuickCarl's Avatar
QuickCarl
Eureka!
Witched to safe mode and the winlogon.exe rename and minlongon.exe rename problem was overcome. Followed the rest of the directions. Piece of cake.
QuickCarl is offline   Reply With Quote
Old 12-23-2004, 08:14 PM   #171
momanz is on a distinguished road
Making things even faster?
So I've been sitting an airport for 5 hours and I decided to do a little more digging on possibly making things even faster (take a look at the bootvis trace results in a previous post).
The SMSS.EXE process is the session manager. Not sure if there is anything we can do with this one... perhaps the XPE analogue can be used here?
CSRSS.EXE is the Client/Server Runtime Server Subsystem... this one look like it controls part of the graphical interface for windows, it also creates and deletes threads so I think we need it...
LSASS.EXE <from a microsft website>
Quote:
The local security authentication (LSA) subsystem server component generates the process that authenticates users for the Winlogon service. The LSA also responds to authentication information received from the Graphical Identification and Authentication (GINA) Msgina.dll component. If authentication is successful, Lsass.exe generates the user's access token, which starts the initial shell. Other processes that the user initiates inherit this token.
Somewhere on the MSDN XPE website it states that minlogon does not use LSA, the question is do any other applications need or use it? If not let's get rid of it! I won't be able to attempt this until I return home (another week). Perhaps someone else would like to give it a try.
Good luck...
momanz is offline   Reply With Quote
Old 12-24-2004, 03:26 AM   #172
bigman1 is on a distinguished road
When I imported the regfile, I left out this line "LsaStart"="%SystemRoot%\\system32\\lsass.exe" , and all seemed to work fine without it. I did this in vmware, and I installed and played with a lot of different applications to find out if it caused any problems. So far so good.
Wayne
bigman1 is offline   Reply With Quote
Old 12-24-2004, 04:17 AM   #173
Registered User
Skraggy_uk's Avatar
OK, including the .reg file for EWF in commandlines.txt didn't appear to work, but I'm going to play with that in another install check later, but manually running the reg file did, so I'm going to see what went wrong with auto running it.
Have it installed using my C drive now, lets see if I can configure the bloody thing now.
A VMWare install on a duron 1.3 with 256 meg ram and VMWare tools loads to desktop in 30 seconds.
Old 12-24-2004, 06:23 AM   #174
Registered User
Skraggy_uk's Avatar
OK, problem fixed. It was down to VMWare tools being installed while the ewf was enabled.
After disabling installing VMWaretools and re-enabling, all good.
Time to fine tune the install of destinator, centrafuse and it reqs.
Old 12-24-2004, 11:00 AM   #175
mattdisaster is on a distinguished road
Hi everyone, I'm running winxp pro sp2 installed. A few problems arose when i tried doing this, first I couldnt find the ntldr file, and then right afterwards i couldnt set the file permissions for everyone in regedit. And when i try and run the .reg file I made it wont let me. Any ideas? Thanks so much in advance!
-matt
mattdisaster is offline   Reply With Quote
Old 12-25-2004, 09:48 AM   #176
FetLyd is on a distinguished road
I think EWF has to be installed AFTER windows is installed, otherwise I guess it wouldn't ever finish.. Unless we found a way to disable it during installation, then enable it after..
FetLyd is offline   Reply With Quote
Old 12-25-2004, 03:21 PM   #177
knubile's Avatar
knubile is on a distinguished road
I think the enable disable settings is in the registry. Not sure which setting, but I think you could adjust it and have it disabled right away.
knubile is offline   Reply With Quote
Old 12-25-2004, 04:10 PM   #178
i'll try it out later tonight..
Old 12-27-2004, 12:58 AM   #179
FLA
gospeed.racer's Avatar
gospeed.racer is on a distinguished road
Ok, I am still having issues getting this to take. Here are the steps I took so far...
Downloaded the required files and unzipped. Put the $oem$ folder in the same folder that I386 resides in, as with all my unattended cd's that I have made. Left the folders inside alone as they looked to be configured correctly. Added the 2 minlogon files to the System32 folder that was created in the prior unzip. Burned to a cd without running Nlite yet. Here is what I get:
Computer starts up normally but seems no different, log in screens are unchaged. I read that sometimes the winlogin.exe needs to be deleted and the minlogon.exe needs to be renamed to become the new winlogon.exe. I dont have a winlogon to start with, so I rename the minlogon.exe to winlogon.exe and reboot. Still no change. I figure that the reg tweaks may have not been installed so I ran both .reg files and the fetlyd.exe and from there i now get a login screen asking for a password. Any thoughts?
00 Focus LX soon to be boosted!
88 Escort GT Turbo DFI
gospeed.racer is offline   Reply With Quote
Old 12-27-2004, 01:27 PM   #180
-matt
I believe NTLDR is hidden, so you'll have to active the option to show hidden files.. Also, I think it needs to be set as readonly + hidden..
What happens when you try to allow everyone to access registry?
