Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Old 02-11-2008, 08:40 AM   #256
jonessc's Avatar
jonessc is an unknown quantity at this point
Quote: Originally Posted by blazini View Post
I just had a hard drive crash on my carpc, so I had to go through all of this again. I had the Minlogin working before, but I had to follow this thread cuz I couldn't remember how I got it to work before. I have the same problem with winlogon.exe reappearing as others have. To make it easy for noobs in the future, here is the simplest way of getting just the minlogon working:
1)Download this minlogon.cab file from here: (other links in this thread seem to be dead)
http://thuun.boot-land.net/index.html
2)double click the minlogon.cab file and copy the minlogon.exe file to your desktop, rename it to winlogon.exe
3)Open notepad, copy the text this text to the notepad, then save the file as "minlogon.reg":
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
"Config"=dword:00000017
4)Restart the system, tapping F8 to bring up the safe mode list, start in safe mode
5)go to \Windows\System32 and rename winlogon.exe to winlogon.exe.bak
and place the winlogon.exe file you renamed on your desktop into this folder
6)double click the minlogon.reg file to update the registry (if you don't do this you will fark your system.
7) restart and it should start with no login screen, but you will be logged in as system rather than administrator or whatever.
8)get your ctrl-alt-del working http://www.mp3car.com/vbulletin/winn...-minlogon.html
Followed these instructions to the letter, now i get a bluescreen saying 'thw windows logon process system process terminated unexpectedly with a status of oxc0000034, the system has been shutdown'
Could it have anything to do with Nlite? i set autologin as the Admin account when I did my last stripped XP disk.
Cant even get in with safe mode
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
jonessc is offline   Reply With Quote
Old 02-11-2008, 03:40 PM   #257
jonessc's Avatar
OK ive used the winlogin.exe from my repr directory.
Its now working a treat.
Thanks for the guide.
CarPuter Progress:
Old 05-12-2008, 09:49 AM   #258
Custommx3's Avatar
Custommx3
Just an FYI for those curious..
if you slipstream Xp SP3 into your nlite install, you can still use the minlogin from Sp2.
Im using it.
2007 Mazdaspeed 6
Custommx3 is offline   Reply With Quote
Old 06-08-2008, 07:20 PM   #259
plouche is an unknown quantity at this point
The link is dead please reup this.
plouche is offline   Reply With Quote
Old 06-24-2008, 05:13 AM   #260
Ces///M3
is anyone else getting an error message when shutting down RoadRunner now that they are using minlogon? Whenever I shut down I get the error "Roadrunner.dll failed to initialize" or something to that effect? And the chase for perfection continues.....
Ces///M3 is offline   Reply With Quote
Old 07-25-2008, 02:55 AM   #261
AllShowNoGo is an unknown quantity at this point
Simply using minlogon decreased my boot time from 45 sec to 30 sec. This is from cold boot to the time the hour glass dissapears and the hard drive stops churning.
An easy way to get around the Windows File Protection is to boot into safe mode. The only drawback is that it doesnt allow you to delete files.
I found a copy of minlogon.exe using this site: http://www.GreenMonkies.com/
1997 Grand Prix GTP - Pioneer Premier HU - Alpine 4ch for mids/highs - McIntosh separates in the rear (soon to be in front as well) - Custom Passive Xovers - Pioneer Class A 300wrms amp - 2.5 farad cap - The original RF "The Punch" Pro Series 12"
AllShowNoGo is offline   Reply With Quote
Old 10-12-2008, 08:07 PM   #262
smp4488's Avatar
smp4488 is an unknown quantity at this point
I used minlogon before my pc crashed and i had to reinstall, but it worked great. After the reinstall i put off installing minlogon. I had a problem with accessing vista network shares before the crash but after the re-install it worked. I installed minlogon today and now i cant access my vista share. I think i have narrowed it down to minlogon. Anyone else having this problem?
smp4488 is offline   Reply With Quote
Old 10-12-2008, 09:06 PM   #263
smp4488's Avatar
Ok so i think i have found a way to get this working. Open a command prompt and use the "net" command. Mine looked like this: "C:\> net use \\pc1\Shared" i then get promped for a user and pass. On my share on pc1 i have guest access so i used Guest with no pass. Go to my network places and view workgroup computers. Your network computer should be there and you should be able to browse the shares.
Old 12-19-2008, 03:46 PM   #264
Grrrmachine's Avatar
Grrrmachine is on a distinguished road
I noticed that most of the links to the minlogon files are invalid now. I downloaded it from here: http://hosted.filefront.com/jisaac
http://sticksout.blogspot.com
Grrrmachine is offline   Reply With Quote
Old 04-05-2009, 08:09 AM   #265
Rillee's Avatar
Rillee is an unknown quantity at this point
I'm thinking of putting minlogon.exe to my system. But will my M2-ATX power supplie still be able to power of my system?
Rillee is offline   Reply With Quote
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
