Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Old 12-05-2004, 11:13 AM   #16
SFiorito's Avatar
SFiorito is on a distinguished road
I don't see why not. You may want to try it in VMWare or VirtualPC first though.
SFiorito is offline   Reply With Quote
Old 12-05-2004, 11:24 AM   #17
SFiorito's Avatar
Okay, so who's tried this and have they checked things out? My VIA system seems fine. One thing I noticed reading through some documents on MSDN is that MSFT claims hibernation doesn't work with minlogon because of some security issues. But I've got hibernation working on my VIA system with minlogon and ewf fine. Standby works as well. But maybe that's because I had hibernation set up before I installed minlogon.
**EDIT**: okay, it seems in SP2 minlogon DOES support standby and hibernation. So ignore my last...
Old 12-05-2004, 11:28 AM   #18
CombatCQB is on a distinguished road
This mod would only improve cold boot times and would not affect resume from hibernation times correct? But I guess if the memory footprint is smaller with minlogon, then coming out of hibernation could be a little faster too.
CombatCQB is offline   Reply With Quote
Old 12-05-2004, 11:32 AM   #19
Rub One Out
Motoko's Avatar
Motoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of light
Ive ran into trouble, i followed the instructions, system boots up comes o the logon screen with Administrator as the only user to select, i click on it it says "logging on" (underneath) then changes to "Saving Settings" and dosnt logon and stays in the logon screen
CarPC status: iPod, 3,456,217 songs so **** you
Motoko is offline   Reply With Quote
Old 12-05-2004, 11:41 AM   #20
SFiorito's Avatar
Motoko: If you're getting the logon screen then you missed something. You said you were having problems copying minlogon so I'm willing to bet your system is still running winlogon. When the windows file protection dialog comes up you need to hit cancel overwise it'll restore the normal winlogon.
CombatCQB: that's correct. hibernation won't benefit from this unless you consider a smaller OS image as well as less ram being used up. This mod is purely for cold booting speed and footprint.
Old 12-05-2004, 11:44 AM   #21
Rub One Out
Motoko's Avatar
nah i manage to copy and rename minlogon to winlogon, "windows file protection" never came up.
Old 12-05-2004, 11:49 AM   #22
SFiorito's Avatar
you said winlogon was "reproducing" itself. that sounds like windows file protection to me. the file should be 17KB in size.
Old 12-05-2004, 11:51 AM   #23
Rub One Out
Motoko's Avatar
hmmm maybe ill import the back up registry file again, how can i do that with out logging on?
Old 12-05-2004, 12:01 PM   #24
SFiorito's Avatar
well, i warned you that you may hose your system if you weren't careful. try booting up and hitting F8 and select last known good configuration.
Old 12-05-2004, 12:13 PM   #25
Rub One Out
Motoko's Avatar
does anyone know how to import an exported reg key into the registry from the "windows recovery console" i saved the winlogon key to "c:\winlogon.bak" or "c:\winlogon.reg"
Old 12-05-2004, 12:18 PM   #26
camsgs3 is on a distinguished road
how much quicker are boot times using this method compared to using a "stock" XP build
camsgs3 is offline   Reply With Quote
Old 12-05-2004, 12:35 PM   #27
Registered User
mpattonm's Avatar
mpattonm
Quote: Originally Posted by SFiorito
Okay, so who's tried this and have they checked things out? ...
I will do tomorow when I am back home. And if I get it working first think I do them is measuring boot times "before" and "after"
mpattonm is offline   Reply With Quote
Old 12-06-2004, 01:49 AM   #28
AlienEclipse's Avatar
AlienEclipse
Damn!
I got minlogon working fine, so i decided to make Centrafuse the shell.
Big mistake that was. All it does is cause errors. And with minlogon not supporting CTRL+ALT+DEL i can't run regedit to change back. Last known good config doesn't work either. Safe Mode doesn't help.
I will see if the recovery console can help.
Just thought i would let you guys know.
We are, will have and forever will be...
But not tommorrow!
AlienEclipse is offline   Reply With Quote
Old 12-06-2004, 02:00 AM   #29
SWC
SWC is on a distinguished road
Quote: Originally Posted by AlienEclipse
Damn!
So is there a way to force quit apps with minlogin?
SWC is offline   Reply With Quote
Old 12-06-2004, 04:34 AM   #30
AlienEclipse
Not that i have found so far
But not tommorrow!
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
