Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Old 12-12-2004, 09:11 AM   #61
Rub One Out
Motoko's Avatar
Motoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of light
Quote: Originally Posted by Maukio
Hmmm, I'm having problems similar to the earlier dude. I followed the instructions exactly. I ran into a problem with Windows File Protection. I didn't get any kind of message or pop-up that alerted me about Windows File Protection (no window to hit cancel on). But I noticed that when I came back to the System32 directory, after going to where I had minlogin stored to copy it, winlogon.exe, which had been deleted, was back. I found a place online that showed me how to disable Windows File Protection, I tested it out and it worked. Then I continued with the minlogon instructions. I checked to make sure and it was 17KBs. I imported the registry key after deleting everything. Once I finished all that I rebooted and the classic login screen popped up. I tried logging in with my user name (no password) and it the screen would go away and just have a blue background, it would wait a few seconds, then the login screen would pop back up. After that I tried using my Administrator account and password, this produced a bit different results. The login screen disappeared, I got the blue background again, but this time the Windows login sound played (which I previously had disabled), but about 2 seconds after it finished, the shutdown song played and the login screen popped backup. Anybody have any ideas?
Exactly what i got. I think that guy left an instruction out, beause i swear i followed what he said.
CarPC status: iPod, 3,456,217 songs so **** you
Motoko is offline   Reply With Quote
Old 12-12-2004, 09:34 AM   #62
knubile's Avatar
knubile is on a distinguished road
Quote:
I tried replacing winlogon.ex_ in the i386 folder
Wouldn't you also need all the registry entries? Is there a way to customize the registry with nLite preinstall?
knubile is offline   Reply With Quote
Old 12-12-2004, 12:19 PM   #63
Registered User
mpattonm's Avatar
mpattonm
Well it works for me. I did nothing else but what SFiorito instructed us to do.
mpattonm is offline   Reply With Quote
Old 12-12-2004, 01:07 PM   #64
knubile's Avatar
Same here. I followed the instructions and it worked well. I had windows file protection disable right from the install though. It's an option in nLite.
Old 12-12-2004, 01:13 PM   #65
Maukio's Avatar
Maukio is on a distinguished road
Are you all running SP2? There's gotta be some difference in me and Motoko's setup from you all's b/c I was super careful at following the instructions. It sucked to fix it too.
'99 Accord LX
Pics of CarPC Setup
Maukio is offline   Reply With Quote
Old 12-12-2004, 03:05 PM   #66
Raw Wave
rando's Avatar
rando is on a distinguished road
I'm running SP2 and followed the OPs instructions and it worked the first time.
2004 4runner
rando is offline   Reply With Quote
Old 12-12-2004, 03:31 PM   #67
HoSS's Avatar
HoSS is on a distinguished road
I got that restart problem. It's because the winlogon file didnt copy properly (WFP or whatever)
I booted in recovery console and copied the file over winlogon again.
Then it works fine.
HoSS is offline   Reply With Quote
Old 12-12-2004, 03:53 PM   #68
Rub One Out
Motoko's Avatar
how do u turn the system file protection off?
Old 12-12-2004, 04:08 PM   #69
FetLyd is on a distinguished road
I used SP1. I forgot to mention it in my earlier post, but i also added the reg values.. To add this into an nlite'd version, you have to follow these steps:
By the way, this is done BEFORE building the image with nlite..
1. Create a new folder called " $OEM$ " in the root folder of your nlite project (same folder as i386)
2. Create a new file inside "$OEM$", and name it cmdlines.txt .
3. Copy the filed called" winlogon.reg " into the $OEM$ folder.
Content of cmdlines.txt :
[COMMANDS]
"REGEDIT /S winlogon.reg"
That's it!
Also, if you want some files copyed to the root of C:\, follow these steps:
1. Create a sub-folder in "$OEM$", called " $1 " .. All files/folders in here will be copied to C:\ during installation.. This will come in handy for EWF!
To copy files into windows/system32/etc. folder:
1. Create a sub-folder in "$OEM$", called " $$ " .. All files/folders in here will be copied to C:\windows.. To copy files into system32 folder, simply create another folder in "$$", called system32..
Sorry for the long and messy post!
FetLyd is offline   Reply With Quote
Old 12-12-2004, 05:00 PM   #70
SFiorito's Avatar
SFiorito is on a distinguished road
Good job FetLyd, that's a great tip! As far as those of you having problems with WFP and copying minlogon: I don't know what to tell you. Every machine I've tried (including a default SP2 install) I got a warning dialog from WFP which I was able to cancel. It looks like most other people got the same thing as well. The problem is that the file and registry entries go hand-in-hand, so if one is screwed up the whole logon process gets screwed up!
SFiorito is offline   Reply With Quote
Old 12-12-2004, 05:07 PM   #71
SFiorito's Avatar
Regardig bootvis: doesn't that just layout boot files on the hard drive to minimize seek time? I've run it a few times, but saw no difference at all on the CF card. I wouldn't expect to since the CF card has such small seek times. You guys all disabled the auto chkdsk, too right? That was eating up at least a second on my system.
Old 12-12-2004, 07:48 PM   #72
I'm sorry, and you are....?
frodobaggins's Avatar
frodobaggins will become famous soon enoughfrodobaggins will become famous soon enough
Quote: Originally Posted by AlienEclipse
also did a little research and i can't find anyway of enabling CTRL+ALT+DEL with minlogon.
Solution:
http://www.mp3car.com/vbulletin/winnt-based/38179-fix-ctrl-alt-del-minlogon.html
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 12-12-2004, 10:29 PM   #73
Raw Wave
rando's Avatar
I didn't get a WFP pop-up or anything. Presumably my nLite install killed WFP. I just tried to do the minLogon again on a stock SP2 install (i.e. no nLite) and did run into the WFP problem. It never warned me -- just silently replaced the new file with the standard winlogon.
2004 4runner
Old 12-12-2004, 10:33 PM   #74
SFiorito's Avatar
Hmmm... I wonder if it matters that (on the stock SP2 systems) I've always done it logged in as Administrator??
*EDIT*: I double-checked, and I have WFP enabled, so I don't know what it could be.
Old 12-12-2004, 11:21 PM   #75
knubile's Avatar
hmm. I just ran into the problem with my last attempt. nLite. Checked the disable protection checkbox that worked for me before.
This time it didn't work. I wonder if its something else. I wonder if there's a component that nLite removes that results in the file protection not working.
