Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Old 12-13-2004, 12:04 AM   #76
Maukio's Avatar
Maukio is on a distinguished road
Yeah, there's gotta be some other variable in here. WFP was turned off and I made sure it was the XPe 17Kb file and I followed the registry instructions very carefully. I wonder what else it could be? Maybe some services you all have disabled or enabled that I don't? Hardware? I really have no clue, just throwing out suggestions.
'99 Accord LX
Pics of CarPC Setup
Maukio is offline   Reply With Quote
Old 12-13-2004, 04:22 AM   #77
FetLyd is on a distinguished road
Quote: Originally Posted by SFiorito
Good job FetLyd, that's a great tip! As far as those of you having problems with WFP and copying minlogon: I don't know what to tell you. Every machine I've tried (including a default SP2 install) I got a warning dialog from WFP which I was able to cancel. It looks like most other people got the same thing as well. The problem is that the file and registry entries go hand-in-hand, so if one is screwed up the whole logon process gets screwed up!
Thanks alot man! I'll see if i have the time to put together a small program today, that'll copy the files over AFTER installation.. Should be able to get around that stupid BSOD then...
EDIT: BTW, I didn't delete any reg. entries before running the winlogon.reg file.. Still, it works fine..
FetLyd is offline   Reply With Quote
Old 12-13-2004, 04:32 AM   #78
HoSS's Avatar
HoSS is on a distinguished road
Just copy it over in recovery console mode (boot from Win CD), and leave file protection on, its easy!
HoSS
HoSS is offline   Reply With Quote
Old 12-13-2004, 07:26 AM   #79
Rub One Out
Motoko's Avatar
Motoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of light
What if you dont have a cd drive?
CarPC status: iPod, 3,456,217 songs so **** you
Motoko is offline   Reply With Quote
Old 12-13-2004, 11:59 AM   #80
knubile's Avatar
knubile is on a distinguished road
I get a write access denied error when I try to delete winlogon.exe. It says another program is using etc..
Is that what WFP does? Or is this something else?
knubile is offline   Reply With Quote
Old 12-13-2004, 12:10 PM   #81
SFiorito's Avatar
SFiorito is on a distinguished road
You have to rename winlogon.exe to winlogon.exe.bak, then rename minlogon.exe to winlogon.exe. You get that error because winlogon.exe is currently running. WFP should come up after you rename it to winlogon.exe.bak.
SFiorito is offline   Reply With Quote
Old 12-13-2004, 12:20 PM   #82
knubile's Avatar
Haha. That was dumb on my part. So nothing changed for me after all. You simply can't delete winlogon.exe. You have to rename it. Then replace it.
That's kind of odd, but that's it!
Thanks SFiorito
Old 12-13-2004, 02:38 PM   #83
SFiorito's Avatar
Okay, I found a machine with SP2 that was exhibiting the same behaviour some of you guys are experiencing. As long as you follow my original instructions you should still be fine though. I renamed winlogon.exe to winlogon.exe.bak. Waited a few seconds and WFP recreates winlogon.exe in the directory. I deleted the new winlogon.exe and put minlogon.exe (renamed to winlogon.exe) in its place. Then I did the registry entries. BEFORE YOU REBOOT ENSURE THAT MINLOGON IS STILL THERE. MinLogon is 17KB in size versus WinLogon's 520KB.
BTW, I also tried replacing the files without changing the reg entries and my system couldn't boot, so whoever that was that said the reg changes weren't necessary either WFP replaced minlogon with the original winlogon or you have some kind of anomaly that lets it somehow work on your system. Please let us know.
Old 12-13-2004, 03:31 PM   #84
If i throw together a quick program now (i mentioned it in my previous post), can someone test it quick?
Old 12-13-2004, 03:38 PM   #85
Rub One Out
Motoko's Avatar
yeh, if it dosnt kill my system
Old 12-13-2004, 03:40 PM   #86
That, we don't know yet..
Old 12-13-2004, 04:35 PM   #87
bigman1 is on a distinguished road
sure I've got vmware running anyway testing out an nlite config
bigman1 is offline   Reply With Quote
Old 12-13-2004, 04:40 PM   #88
Good.. I'll try to finish it soon.. Just got a few other things I have to work on.. Plus the time is 22:40PM here, and I've been working 14 hours..
So, sorry for all the typo's and slow work..
Old 12-14-2004, 06:20 AM   #89
It would be nice if someone could test this out in wmware (or something like that), and give me some feedback.. The program renames winlogon.exe to winlogon.bak, then renames minlogon.exe to winlogon.exe .. Then it deletes the winlogon values, and inserts winlogon.reg into the registry.. After it's completed, it will restart the machine.. Atleast, this is how it's supposed to work, but my coding skills are a bit rusty..
Anyways, here's the instructions:
Before making an nlite image, create a new folder called $OEM in your project folder (same folder as i386). In $OEM$, you'll have to create another folder called $$, and then another one called system32. Copy " fetlyd.exe ", " minlogon.exe " and " minlogon.reg " into this folder. Then, create a new text file in $OEM , and name it cmdlines.txt. It shall contain the following lines:
Code:
[COMMANDS] "REGEDIT /S fetlyd.reg"
Then, you'll have to create the file fetlyd.reg ..
It should only contain the following lines:
Code:
Windows Registry Editor Version 5.00 [Software\Microsoft\Windows\CurrentVersion\RunOnce] "Fetlyd"=fetlyd.exe
cmdlines.txt Fetlyd.exe and fetlyd.reg are inside the zip-file attached.. Only thing you need to do, is copy "minlogon.reg" and minlogon.exe inside the system32 folder as described earlier in this post..
* Fingers crossed! *
Btw, don't blame me if it doesn't work, or if it *****s up your os..
Old 12-14-2004, 10:23 AM   #90
3 views of the zip file, but no response..?
