The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Thread Tools Search this Thread Display Modes
Old 04-22-2008, 12:30 AM   #136
My Photos: (0)
Has someone got an easy way how to install tinyxp (without a cd or floppy in my laptop)?
ASH
ASH
ASH2 is offline   Reply With Quote
Sponsored Links
Old 04-22-2008, 07:36 PM   #137
jonessc's CarPC Specs
jonessc's Avatar
Vehicle: BMW 320D M-Sport
My Photos: (0)
ASH
http://www.mp3car.com/vbulletin/oper...loppyless.html
this seems to be best way
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
jonessc is offline   Reply With Quote
Old 04-23-2008, 12:11 AM   #138
Phatsacks's CarPC Specs
Phatsacks's Avatar
Vehicle: 2007 Corolla S
My Photos: (0)
If you are able to get TinyXP, you can get a usb install version as well...if your PC supports booting from USB~
Phatsacks is offline   Reply With Quote
Old 04-23-2008, 05:11 PM   #139
My Photos: (0)
Quote: Originally Posted by jonessc View Post
Yeh, but the tinyxp does not have the same folders as normal xp (or the correct setup files)
And no mate.. my laptop does not support booting from USB
Any other thoughts??
ASH
ASH
Old 04-24-2008, 08:03 AM   #140
Phatsacks's Avatar
My Photos: (0)
Yeah, quit using TinyXP. Just install a regular XP version (or whatever version you can get on the drive), then use the same author's (eXPerience) configuration files (a file you can double click to automatically import all the reg tweaks he uses). The install size will be different, but the ram usage will pretty much be the same. I even posted those configuration files on the forum.
You should be able to get around 50-55mb of usage with a fresh install of XP, and one of his higher tweaks (hardcore/maniac).
Sponsored Links
Old 04-25-2008, 01:37 AM   #141
My Photos: (0)
I have seen come coding about but how do I run it on the PC?
Thanks in advance
ASH
Old 04-26-2008, 02:44 PM   #142
nst6563's CarPC Specs
Vehicle: 2004 Nissan Maxima
My Photos: (0)
Thanks in advance
http://unattended.msfn.org/unattended.xp/view/web/1/ is your friend when it comes to customizing windows installations.
the reg files you've seen posted about on this site can be added by simply double clicking them.
Lastsession.ini files are used with NLite.
If you don't know what you're doing, I would suggest NOT attempting any of these tweaks on a system you rely on. Try it on a virtual machine or a spare system you don't mind re-loading the OS on in case something goes wrong.
nst6563 is offline   Reply With Quote
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
My Install in A Lexus IS200 UK Spec Brettster Show off your project 22 04-30-2007 08:20 AM
2002 Montero Limited Install... Squid Show off your project 33 09-22-2005 11:29 PM
this install is kickin my ***....i really need help nappyjim General Hardware Discussion 80 10-22-2004 08:22 AM
Lilliput 619GL-70NP Touchkit XP Home Install Windchsr LCD/Display 2 04-25-2004 07:23 AM
Where does ground loop isolator install? grandamp3 General Hardware Discussion 6 09-14-2000 08:10 AM
Sponsored Links
Ad Management by RedTyger
